Closed Thread
 Old 03-06-2011, 10:43 AM   #1
blackwidow's Avatar
Posts: 85   (View Stats)
blackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud ofblackwidow has much to be proud of
Default spark plug
Hi Sanders , i will go at your facility in April for my Standback Dyno tuning , i would like to know which spark plug you recommend ? Right now i a have new set of the Mazda stock plug. I would like to have 2 maps 16psi & 18 psi , i have the BNR stage 2 turbo .
Please i want the CP-E answer only .
Thanks CP-E !
Mazdaspeed6, CP-E dyno 275WHP/255 WT ,BNR turbo ,CP-E intake,CP-E turbo inlet,CP-E flash,CP-E standback,CP-E fuel pump,CP-E mount,Turbosmart bov,Corksport catback,ATP catted downpipe,ETS tmic ,Saikou Michi OCC, Turbinetech mounts,TWM short shifter stage II + bushings + shifter plate ,Aem boost et wideband gauge,Dashhawk,Autoexi tower bar, Apexi turbo timer,Mazdaspeed mags,huiles Amsoil,Fiberimages CF hood & truck ,Speedline CF grill, R1 concept disques de freins,EBC red stuff pads,Hankook tires,Megan racing coilover ,Kicker amplifier .
blackwidow is offline
The Following User Says NO Thank You to blackwidow For This Un-useful Post:
4G63 (03-06-2011)
 Old 03-06-2011, 10:45 AM   #2
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
Please i want the Sanders answer only .
Thanks CP-E !
Hey newbie... Why don't you send him a message? Don't create threads for stupid shit like this.
Oh, and get an AP. It's better.
You also want ITV22s.
Fuckin' brownies.
jwilkins88 is offline
The Following 2 Users Say Thank You to jwilkins88 For This Useful Post:
4G63 (03-06-2011), manelscout4life (03-07-2011)
 Old 03-06-2011, 10:52 AM   #3
blackwidow's Avatar
I'm in the CP-E section so fuck off the COBB AP . I wrote (CP-E answer only) so keep your fucking answer for you !
I didn't ask you anything .
 Old 03-06-2011, 10:53 AM   #4
jwilkins88's Avatar
Groans: 126
That's still more of a private message thing. Just saying
The Following User Says Thank You to jwilkins88 For This Useful Post:
 Old 03-06-2011, 11:22 AM   #5
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Keep it going Joel. You're on a roll!
Tapatalk
08.5MS3 is offline
 Old 03-06-2011, 08:20 PM   #6
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Let's keep it easy guys, please.
OP, you will want to purchase this plug listed here, an ITV22 (Denso).
Sparkplugs.com - Application Search Results
If you feel compelled, you are able to cross reference different plug models with the listed information there. It's a helpful tool if you want more options of the same spark plug.
You can always contact me directly at smarques@cp-e.com also.
Website: www.cp-e.com
www.cp-e.com is offline
 Old 03-07-2011, 04:24 AM   #7
blackwidow's Avatar
Ok thanks for the link , do i need to regap them to 0.028 ?
 Old 03-07-2011, 10:05 AM   #8
Unless you have a plug gapping tool, don't worry about it. It is hard to do it accurately with out it.
 Old 03-07-2011, 10:10 AM   #9
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
I think this is a terrible statement to make. If you are doing spark plugs you should always check the gap and set it to the correct spec, especially on these cars. It's not like they are expensive.
bova is offline
 Old 03-07-2011, 12:22 PM   #10
08.5MS3's Avatar
Groans: 89
I think those plugs come pre-gapped to spec.
08.5MS3 is offline
 Old 03-07-2011, 12:27 PM   #11
bova's Avatar
Groans: 45
when I got my denso's i thought the same thing and they were not gapped correctly so I had to fix them.
bova is offline
The Following User Says Thank You to bova For This Useful Post:
08.5MS3 (03-07-2011)
 Old 03-07-2011, 03:46 PM   #12
Please read what I wrote.
I did not say, "Do not to check gap".
I basically said you should not adjust the gap on iridium based spark plugs with out a gapping tool that will let you gradually bring down the gap with a feeler gauge between the electrode tip and the ground. This is the proper way to gap plugs.
I personally don't like bringing down the gap by "tapping" the ground down closer to the electrode because it leaves the opportunity for bringing the gap too close, then leaving you in a bad spot if you need to open the gap back up. Iridium plugs are very fragile in respect to the electrode.
 Old 03-07-2011, 04:08 PM   #13
blackwidow's Avatar
OK , but what is the gap for the ITV22 on our car ? 0.028 like stock ? I have the tool btw !
Closed Thread
spark plug how to? IndianOutlaw MazdaSpeed 3 - How-To's 22 03-02-2011 06:10 PM
best spark plug? soulefx 2010 MS3 - Engine, Transmission & Driveline 12 12-22-2009 10:35 PM
Spark Plug Question? QKRTHNU Mazdaspeed3/6 General Discussion 2 04-13-2009 09:08 AM
Spark Plug Gap khaydin
Cobb Access Port/Maps
5 12-01-2008 10:17 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
Page generated in 0.34373 seconds with 24 queries
