Closed Thread
 Old 04-28-2010, 05:53 AM   #1
MPSdriver's Avatar
Posts: 136   (View Stats)
MPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the world
Default Speed Pistons
Saw that CP-e is offering Wiseco pistons on their website. Anything CP-e about these pistons or are they the regular Wisceo's?
The site mentions that:
"With Wiseco forged pistons at the heart of a mazdaspeed powerplant utilizing the combination of the FullControl™ flashes and StandBack™ v2 tuning solution, not only will you be able to breach the 400whp mark, but you'll be able to enjoy it for years to come."
You'll no doubt need supporting mods to achieve 400whp, but weren't the rods our weak link or did your research reveal something to conclude the pistons need upgrading first. Or maybe the available aftermarket rods are good enough?
Just in for some extra info on this
Thanks
MPSdriver is offline
 Old 04-28-2010, 08:09 AM   #2
My guess is they will also sell rods. The rods should definitely be replaced.
Lex is offline
 Old 04-28-2010, 08:15 AM   #3
BUNGEEZZ's Avatar
Posts: 426   (View Stats)
BUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the world
Groaned at 49 Times in 36 Posts
piston's+rods... what about head studs? cams perhaps? we need to being this platform where it belongs. i believe its about time. im no fan-boy, im just a strong supporter of my car =)
Mazdaspeed6,2006, 46k miles.
COBB AP*
Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds.
I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW
BUNGEEZZ is offline
Closed Thread
Pistons ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-13-2009 06:22 PM
NEW PISTONS ARE HERE!!!! ptperformance Mazdaspeed3/6 General Discussion 30 05-27-2009 09:51 AM
Stock pistons Buildabong MazdaSpeed 3 - Engine, Transmission & Driveline 0 01-27-2009 08:10 AM
Page generated in 0.23744 seconds with 22 queries
