| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() | | #41 | ![]() |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
| Not Ranked : 0 score
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: |
![]() | | #42 | ![]() |
![]() Join Date: Jun 2013 Location: Charleston SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 235
| Not Ranked : 0 score If you can try to back it out slowly I thought one of my bolts to my PMM was cross threaded as fuck but I was able to thread it again and clear up the threads Sent from my phone whilst bojanglen.
__________________ Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads. Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges. |
![]() | | #43 | ![]() |
| Not Ranked : 0 score God I hope your right. Now if i could just find someone with a hydraulic jack and stands to help me out...
![]() | | #44 | ![]() |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
Sent from the lead
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci | |
![]() | | #45 | ![]() |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Was torque wrench used? Sent from my iPhone using sausage fingers
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
![]() | | #46 | ![]() |
Yes, but I wasn't able to get it to torque down all the way due to laying on my back with the car up on Jack stands. It was good and tight, but I never got it to 85ft lbs. it was fine for 4 days till I put it under heavy load on the Dyno.
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: Last edited by The Nut; 02-27-2014 at 08:14 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to The Nut For This Useful Post: | PUGENE (05-15-2014) |
![]() | | #47 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
We are also curious about what you mean by threaded
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe | ||
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | rfinkle2 (02-28-2014) |
![]() | | #48 | ![]() |
| Not Ranked : 0 score Are you sure the bolt is still in there? If you couldn;t get it to 85 ft/lbs then there's a good chance that it backed out. I'm assuming you're talking about the verticle bolt for the horse shoe part of the mount correct? If that bolt snapped or backed out then that would definitely explain the clanking. You should definitely get a look at this asap before the possibility of any more damage to your car.
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | Goodrich27 (02-28-2014) |
![]() | | #49 | ![]() |
Shitty welded on nut design to subframe is.
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
| The Following User Says Thank You to The Nut For This Useful Post: | rfinkle2 (02-28-2014) |
![]() | | #50 | ![]() |
| The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post: |
![]() | | #51 | ![]() |
| Not Ranked : 0 score Thanks and will do. Currently looking for someone local who has the tools and experience to do a helical fix.
![]() | | #52 | ![]() |
| Not Ranked : 0 score Can you cut/grind the bolt off? Sent from my iPhone using sausage fingers
![]() | | #53 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | trancehead (03-14-2014) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score I actually started a thread in the Nator SoCal section to see if anyone has ever done this and has the tools to do it. In the thread I included the same link. I've read through it, and as you've seen the guy that started that thread helped John fix his 2 yrs. ago. John helped me find that thread and helped me verify that the hole was stripped. He put me in touch with Bigriver and he got back to me today. Unfortunately, he doesn't do work on other people's cars anymore. I can't do this job myself as I don't have a drill, the tap tool that doesn't come with the kit, or a lift to put the car up high enough to get a drill with a long ass bit on it into a usable position. So the search for help continues. I'm prob gonna have to pay a shop to do it at this point.
| The Following User Says Thank You to The Nut For This Useful Post: | rfinkle2 (03-01-2014) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Can't even find a shop willing to do this...ugh!
![]() | | #56 | ![]() |
![]() Join Date: Sep 2013 Location: Winnipeg, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score wish i could try this mount. Ordered it from a local vendor in january and was informed it was on backorder for 2 months?!?! and now possibly a 3rd month?!? if thats the case i'll be seeking a refund and going elsewhere for a RMM
__________________ 2007 CWP MS3 Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks |
| The Following 2 Users Say Thank You to tytanium For This Useful Post: | 86AmishMs3 (03-14-2014), Royer366 (03-14-2014) |
![]() | | #57 | ![]() |
![]() Join Date: Mar 2012 Location: Westampton, NJ
Rep Power: 1412 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,551
Groans: 61
| Not Ranked : 0 score Willing to do what? Sent from my beard...
__________________ Precision: PTE 5858 Kozmic: Downpipe//Dumptube//Oil Return&Feed//EGR Delete Tial: 44mm EWG HTP: 3.5" Intake + 51r Battery Tray CPE: Stage 2 RMM//Manifold JBR: SSP//Shifter Bushings//Knob//TMM//OCC UR: CBE HKS: SSQV4 CS: Springs NGK 1-Step Colder POWERED BY PURPLE DRANK I'm from Jersey...the Drama State. |
![]() | | #58 | ![]() |
![]() Join Date: Aug 2013 Location: Bartlesville, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
| Not Ranked : 0 score Had mine since I went BT and all I can say is WOW.... great job CP-e....
__________________ 2013 MS3 Velocity Red - FLOW Tuned 25% E85 Mods - GTX2867R Turbo, Snow Meth Kit, Forged Manley Platinum pistons and Rods, Matt Dammond Balance Shaft Delete, Southbend Stage 3 Clutch, SPerformance Aux Fan Controller, 4" HTP Intake, Greddy FV BOV, Stratified Guardian Angel V2, Cobb AP V3, Tanabe Strut Tower Brace, Magna-flow CBE, HPFP Autotech Internals, CorkSport Shifter Bushings, CorkSport short throw shifter, CP-e Stage 2 RMM, CP-e Catless Downpipe, QTP Electric Exhaust Cutoff, NGK one step colder plugs, Cobb 3-port EBCS, Whiteline FSB, EBC 3GD Slotted Rotors, Hawk HPS Brake Pads, Goodridge Stainless Steel Brake Lines, HTP Small Battery Box, 51R Optima Yellow, SPC adjustable Rear Camber Arms, KW Variant 3 Coilover setup, Matt Dammond Passenger and Transmission mounts, Falken Azenis tires (street use), Defi Boost Gauge, AEM UEGO Wideband Gauge, AEM Water Temperature Gauge, AEM Oil pressure gauge, Corksport Short Shifter, Apexi Turbo Timer, Corksport Skid Plate, Threadstone TR8 core and crash bar, DOCRACE exhaust manifold, Reletnless Customs Ported IM, JBR 250 Competition Rear Sway Bar, Kuhmo V710 on RX8 wheels (track use), Matt Dammond OCC (VC and intake), Speed Performance Vented Oil Cap, Rice - 20% tint, Morimoto HID kit, Retrofit High Beams, Morimoto projector clear lenses, Corksport Hood Strut Kit, Corksport eyelids color matched, Ebay rear spoiler extension, Morimoto RGB Halos, LED Red Evil Eye, VG Shark Fin Antenna, Coil Cover, Blue Vacuum Hoses, Morimoto LED low beams, Cover King custom Seat Covers |
![]() | | #59 | ![]() |
| Not Ranked : 0 score Fix the trilogy of RMM bolt holes for the piece that attaches to the block. But it's getting fixed today by a SoCal Guy called "Eric the Bolt Guy". More info to come on the helicoil repair on the separate thread I have on here: http://www.mazdaspeedforum.org/forum/foru...t-hole-165402/
| The Following User Says Thank You to The Nut For This Useful Post: | rfinkle2 (03-14-2014) |
![]() | | #60 | ![]() |
![]() Join Date: Jan 2014 Location: Mesa, AZ.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
Groaned at 5 Times in 1 Post
__________________ | |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score @www.cp-e.com; These guys need their mounts. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #62 | ![]() |
| Not Ranked : 0 score Found mine used, only reason I got to rock it so quickly. But haven't even got to enjoy it yet due to RMM bolt hole fail. Tonight, we ride!
| The Following User Says Thank You to The Nut For This Useful Post: | Easter Bunny (03-17-2014) |
![]() | | #63 | ![]() |
![]() Join Date: Sep 2013 Location: MS/LA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score I ordered mine this month. It just says processing. I wish they would have said if it was back ordered. Tap tap tap.. Is this thing on? |
![]() | | #64 | ![]() |
| Not Ranked : 0 score Sorry for the delay guys. We are having some issues with the CNC machine that makes this part. It should be up and running shortly. We will keep you updated on this when we have a better eta.
![]() | | #65 | ![]() |
| Not Ranked : 0 score any guestimate atleast?
![]() | | #66 | ![]() |
| Not Ranked : 0 score We are hoping soon. The repairs have taken a little longer than we hoped/expected.
![]() | | #67 | ![]() |
| Not Ranked : 0 score Best RMM for out platform. Period.
| The Following 2 Users Say Thank You to The Nut For This Useful Post: | Easter Bunny (03-17-2014), Goodrich27 (03-17-2014) |
![]() | | #68 | ![]() |
![]() | | #69 | ![]() |
![]() | | #70 | ![]() |
| Not Ranked : 0 score guess I should have ordered from edge as it appears everywhere else including CP-e directly doesn't have any of these mounts in stock
![]() | | #71 | ![]() |
| The Following User Says Thank You to The Nut For This Useful Post: | JgamB (03-18-2014) |
![]() | | #72 | ![]() |
![]() | | #73 | ![]() |
![]() Join Date: Aug 2013 Location: Jackson, NJ
JP
__________________ 2012 Mazdaspeed 3 CP-E Stage 2 RMM, Autotech Internals, Cobb Accessport V3, Corksport SRI w/tip, JBR Solid Shifter Bushings, JBR Short Throw Plate, JBR Cylindrical Shift Knob, Corksport Catted Downpipe, Corksport Cat Back Exhaust, NGK Plugs, Corksport TMM Insert, AEM V2 Meth Injection, TSW Nurburgring 18x8.5 Wheels FreekTuned To Be Installed: Rally Armor Mud Flags (Mazdaru Style) | |
![]() | | #74 | ![]() |
| Not Ranked : 0 score Well, I ordered one two weeks ago and they were out and the machine at CP-E hasn't been fixed so either you got lucky or I was unlucky. JP
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score I appreciate that very much @The Nut; but I totally understand the guys are not happy about not getting their mounts. I do know that there are guys who work closely with CP-E who are members of our forum and it doesn't go unnoticed that you guys need your mounts. The mount really is very nice, although I would be cranky about waiting too. |
![]() | | #76 | ![]() |
![]() Join Date: Apr 2013 Location: North Brunswick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 284
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score I recently picked up this mount after removing the JBR 88 which nothing against them it's a great mount possibly the best performance wise I've felt but the NVH was just too much being that I haz vagina mod and cant take the dashboard rattling to pieces. I didn't even get to choose between the black design and the steel which kind of disappointing me but then again I'm glad cause you never see it anyways and I'd be under there cleaning it lol. this thing right off the bat isn't as noisy and shaky right when you start it up and during toe in it was a bit harsh before break in but now you don't even know it's there. once in a while under WOT at the top end of 1st gear i'll get some wheel hop but thats about it. after the break in you barely even feel it during toe in unless you let your revs drop too much before letting off the clutch overall I couldn't be happier I'll be looking forward to upgrading the rest of the mounts in the future!! |
| The Following 2 Users Say Thank You to montyspeed388 For This Useful Post: | rfinkle2 (03-25-2014), www.cp-e.com (03-24-2014) |
![]() | | #77 | ![]() |
(Thread Starter) | Not Ranked : 0 score From CP-E's facebook page: Custom Performance Engineering Timeline Recent Liked We reaching out to you in regards to your backorder for a cp-e™ Stage 2 Rear Motor Mount for either the Mazdaspeed3 or the Focus ST. All of us at cp-e™ would like to thank you for your patience and continued support. As many of you may know, we have had some issues with our main CNC machine that mills these mounts. The repairs to this machine have recently been finalized and, pending successful testing, production will begin again very soon. Let’s keep our fingers crossed that we don’t see any more issues! We wanted to let you know that these mounts are our number one priority when these machines come back online, and we will be fulfilling orders as quickly as possible. With that being said, we are asking for you to help us - help you! We would like each and every one of you to contact us at orders@cp-e.com. We would like you to respond to this email by choosing one of the two choices below: 1. You would like to receive your mount as soon as possible. cp-e™ will skip the anodizing step, and skip the laser engraving step. cp-e™ will send you a raw billet mount that is 100% functional and will not perform any differently. 2. You would like to continue to wait for the mount. cp-e™ will send you a mount once it is anodized black and laser engraved. This will take an additional 2-4 weeks after machining has finished. Again, thanks for your patience and understanding! Please respond to this email by contacting orders@cp-e.com or calling us at 301-576-6142. If you do not respond to this email, we will fulfill your order as quickly as possible by sending you a mount that is raw billet with no anodizing and no laser engraving. We will take responses up until April 1st, after which all back orders will be filled with raw billet mounts. This announcement will also be posted on the cp-e™ Blog, the cp-e™ Facebook, the cp-e™ Section of FocustST.org, and the cp-e™ Section of MazdaspeedForums! |
![]() | | #78 | ![]() |
| Not Ranked : 0 score i passed the link with that info to my local vendor who ordered mine for them to let CP-e know my decision
![]() | | #79 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score I bought mine before they even started anodizing/laser engraving them... Skip that shit!
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | 08.5MS3 (03-26-2014) |
![]() | | #80 | ![]() |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ | |
| cp-e stage 2 RMM Review/walkthrough | Grumpyjap | Custom Performance Engineering (cp-e.com) | 180 | 06-07-2015 09:58 PM |
| Powerpath Stage 2 Review | Oni | JAMES BARONE RACING | 21 | 05-31-2013 04:06 PM |
| JBR Stage 3 Short Shift Kit Product Review | poqsccrkid | 2010 MS3 - Engine, Transmission & Driveline | 0 | 04-24-2013 08:47 PM |
| EM Stage III+ Clutch Review | Tomas | MazdaSpeed 3 - Engine, Transmission & Driveline | 44 | 09-16-2012 03:39 PM |
| Jbarone SSP Stage 2 Plus Knob install and review | asall667 | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 01-25-2011 09:50 AM |
