Closed Thread
 Old 10-04-2008, 04:20 PM   #1
Poohster's Avatar
Posts: 353   (View Stats)
Default StandBack LED Question
Quick question on the SB LED. Is it suppose to light up when the car is off? I just installed the V2 today. Thanks all.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline
 Old 10-04-2008, 04:38 PM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
it stays lit for like 5 mins after the car shuts off. its wierd and jordan and i couldent figure it out. it has something to do with residiual power.....
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
Poohster (10-04-2008)
 Old 10-21-2008, 10:24 AM   #3
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
Does this LED become an issue while driving at night? Is it bright? Does it flash constantly? Etc...?
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline
 Old 10-28-2008, 12:47 PM   #4
Porch_Monkey's Avatar
Posts: 24   (View Stats)
Porch_Monkey is an unknown quantity at this point
Mine is in the dummy switch plate by the DSC button. It's not bothersome at all.
Porch_Monkey is offline
 Old 10-21-2008, 10:27 AM   #5
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
it would depend on where you put it but its not that bright.
bova is offline
 Old 10-21-2008, 10:29 AM   #6
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
its just residual power in the system..
gsrtype1 is offline
 Old 10-28-2008, 10:29 PM   #7
SneakyP86's Avatar
Posts: 1,162   (View Stats)
I put mine in the coin change compartment along with my wot box.
SneakyP86 is offline
 Old 10-28-2008, 10:31 PM   #8
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
It's not bright at all. Mine never blinks red Only green. It doesn't blink at all when in Map 2
-JEWBERT
jhershorin is offline
 Old 11-07-2008, 03:05 PM   #9
kopf's Avatar
Posts: 327   (View Stats)
kopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the world
Mine only blinks green and it does it at the same rate no matter what position the switch is in. Any other way to tell which Map I'm running?
kopf is offline
 Old 11-07-2008, 05:24 PM   #10
AutoXRacer's Avatar
Are you sure you wired it right? Mine blinks red and green in the 2nd map. Do you have it grounded...?
 Old 11-07-2008, 05:46 PM   #11
kopf's Avatar
Grounded and wired correctly. Only blinks green, never red. Jordan from CPE wanna chime in if you see this?
kopf is offline
 Old 11-07-2008, 06:36 PM   #12
mazdaj's Avatar
Posts: 369   (View Stats)
mazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the world
jordan and the rest of the crew are at sema....
mazdaj is offline
 Old 11-07-2008, 06:06 PM   #13
btkrausen's Avatar
Posts: 48   (View Stats)
btkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nice
mine slowly blinks green in map 1, and then a fast red blink on map 2
-bryan
CP-E CAI | CP-E FMIC | CP-E Standback v2 | CP-E PnP | CP-E Flash | CP-E SSQV BOV Kit | Cobb STS | Cobb Shifter Weight | SU MM | SU Test Pipe | Boost Gauge | Black out Side Markers | SU Bushings | DashHawk
To Be Installed: DNP Turbo Manifold
btkrausen is offline
 Old 11-07-2008, 06:34 PM   #14
mazdaj's Avatar
+1 mine is wired the same. the faster blinking red (secondary map) indicates "danger" to me...lol. im getting it worked into the sb v2.5 software right now to have an option to swap the green/red 1st/secondary map colors since it appears everyones switch is wired differently....
mazdaj is offline
Closed Thread
Standback V3 phailerider MazdaSpeed 3/6 - ECU Computer Tuning 73 10-30-2008 06:13 PM
Cp-e standback oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 2 08-03-2008 06:28 PM
CPE Software question for anyone who is running the standback V2 Joshj84 MazdaSpeed 3/6 - ECU Computer Tuning 7 06-12-2008 06:29 AM
Page generated in 0.32861 seconds with 30 queries
