Closed Thread
 Old 09-23-2008, 08:20 PM   #1
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
Default Standback Tuning
Want your tune to look like this
start posting logs and well get it done together.
Laloosh is offline
The Following 3 Users Say Thank You to Laloosh For This Useful Post:
gsrtype1 (09-24-2008), SneakyP86 (10-21-2008), whoosh@Realtune (09-24-2008)
 Old 09-23-2008, 08:28 PM   #2
phailerider's Avatar
Posts: 4,639   (View Stats)
i WANT you involved in the tuning process of my car. That log is insane. How consistent is the car with holding those a/fs?
phailerider is offline
 Old 09-23-2008, 08:31 PM   #3
Laloosh's Avatar
steady enough to do 5 logs
I did a pull to 4000, made changes
did a pull to 4500, made changes
to 5000, made changes
5500 made change
redline, made changes
I was going to do one more to add a lil of fuel after 6200 but i was low on gas
So from 3000 to 4000 to 5000 to 6000 nothing changed once it was set
Another thing i figured out, once you nail your tune, you can lean out or richen the entire thing, basically dropping the af line i made up or done with the maf transfer function. Now why would this be good? When it hot as balls out and the car runs a lil richer, lean it out using the maf xfer, when its cold out, and it runs leaner, richen it up using the maf xfer.
Laloosh is offline
The Following User Says Thank You to Laloosh For This Useful Post:
gsrtype1 (11-04-2008)
 Old 09-23-2008, 08:35 PM   #4
JimmyMac's Avatar
Posts: 558   (View Stats)
JimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the worldJimmyMac is the leader of the world
How about this, you say you do 3 logs, and tweak the tune in between each right? How about posting each log. Then post the map you started with. Then after each log, you show which changes you made. This'll teach us what you are doing/looking at and changing. Then you have the final log with the final map. Some of us can "reverse engineer" the info to learn what you are doing. Just a thought. I'm still waiting on my PG manifold to come in. That thing is taking forever at the coaters!!
Thanks for taking the time to do this for us.
2012 MX-5 SE
JimmyMac is offline
 Old 09-24-2008, 03:31 AM   #5
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
that looks so good its crazy. i think you used a ruler to draw that afr line though.... lol what where ambient temps when you were logging?
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 09-24-2008, 05:03 AM   #6
Laloosh's Avatar
in the 60s
Laloosh is offline
 Old 09-24-2008, 10:00 AM   #7
Does the SB set target AFRs directly or do you adjust the MAF/RPM map to achieve the desired AFRs?
Lex is offline
 Old 09-24-2008, 10:22 AM   #8
Laloosh's Avatar
you adjust the maf
Laloosh is offline
 Old 09-24-2008, 10:29 AM   #9
Originally Posted by Laloosh View Post
you adjust the maf
So then your tune may have to be updated based on changing conditions such as temperature, humidity, altitude? How sensitive is the Maf calibration you are doing to changing environmental conditions?
I know the ECU makes adjustments based on those conditions - just want to know how well these adjustments work with your scaled Maf.
Lex is offline
 Old 09-24-2008, 12:08 PM   #10
Laloosh's Avatar
i seem to have no problems. I just started messing with the maf xfers so the car has seen noting but 50-60 degree weather nights. What happens when it gets into the 30s? Ill let you know lol
Laloosh is offline
 Old 09-27-2008, 06:16 AM   #11
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
Aye Chris im sure ur getting pissed at me lol but this is my first time playing with the dashhawk like this, so it was a learning process but i did max it like you said this is about 3k to redline
Gotta Love The Turbocharged Wagon
oskinosmee is offline
 Old 09-27-2008, 07:30 AM   #12
Laloosh's Avatar
Perfect, Ill make you up a tune by noon
Laloosh is offline
 Old 09-27-2008, 10:28 AM   #13
Laloosh's Avatar
Make your standback look like this and do another datalog to see what we have to adjust.
your car didnt really need much adjusted, it seems to be running pretty spot on, just added a lil timing since im not sure if your meth is working and pulled some fuel up top, added some down low. Nothing drastic, grim on the other hand, lol he needs work
Laloosh is offline
The Following 2 Users Say Thank You to Laloosh For This Useful Post:
gsrtype1 (10-23-2008), oskinosmee (09-27-2008)
 Old 09-27-2008, 10:42 AM   #14
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
=p lol,do you think its my top mount also thats making me get some shitty konck?
Grim is offline
 Old 09-27-2008, 10:58 AM   #15
oskinosmee's Avatar
I showed loosh where my meth was tapped its spraying but how can i further tell?
BTW Thanks
 Old 09-27-2008, 12:02 PM   #16
Laloosh's Avatar
I dunno if its spraying or not, does your level regulary drop when you get on it?
You said its activated at 19psi, this turbo wont hold 19 psi, maybe try activating it at 15 to be sure
Laloosh is offline
 Old 09-27-2008, 12:06 PM   #17
A lot of it is due to heatsoak.
Lex is offline
 Old 09-27-2008, 12:08 PM   #18
Loosh, do all the adjustment tables in the Standback use TPS for measuring load?
Lex is offline
 Old 09-27-2008, 12:14 PM   #19
Laloosh's Avatar
thats the way i have it tuned....you can change it maf if you want.
Laloosh is offline
 Old 09-27-2008, 12:48 PM   #20
oskinosmee's Avatar
No it comes on at 14 psi
 Old 09-27-2008, 12:51 PM   #21
Laloosh's Avatar
ok than thats good. Data log again, if your knock stays kewl then ill start fucking with timing more...that takes feedback from you cause anythign over 3 degrees is a pita to dial in
Laloosh is offline
 Old 09-27-2008, 08:29 PM   #22
oskinosmee's Avatar
Hey loosh on the MAF map at 6031 (the table before the -4) is that a -3 or 3?
 Old 09-27-2008, 09:44 PM   #23
Laloosh's Avatar
Laloosh is offline
 Old 09-28-2008, 05:27 AM   #24
oskinosmee's Avatar
On your graph your boost temp drop a lot a mine doesnt, Is my meth not spraying in a good spot? The pump psi to low? I always thought it should drop but it never has. Im using that peak shit, i have a gallon of 50/50 mix in the fridge made at IAG in baltimore, but when i was using that i didnt see the temps drop either. WTF
 Old 09-28-2008, 08:10 AM   #25
Laloosh's Avatar
i think it depends on which DH version you are using. im using 2.5 beta 7 i think
Laloosh is offline
 Old 09-28-2008, 01:38 PM   #26
oskinosmee's Avatar
Alright loosh heres log 2, i got a max of 0.4 knock and boost temps drop when i let off the gas to about 68. I got some hesitation doing the log too.
Boost 12, 1st and 2nd and around 14 the rest.
BTW Thanks for your help
 Old 09-28-2008, 02:26 PM   #27
Laloosh's Avatar
1. did you put my fuel pump in yet?
2. Are you sure you changed everything as shown cause your car is alot richer now, even though we took out fuel. You had to ask me if certain values were negative or not, can you see the tune clearly?
3. change boost temps to fuel pressure on your dh.
i have a feeling you added fuel instead of subtracting it, thus asking too much of whatever pump your running.
Dropping pressure explains the low boost, rich a/f ratio, and stuttering.
Laloosh is offline
 Old 09-28-2008, 02:40 PM   #28
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
doesn't he have meth sounds like he's bogging
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 09-28-2008, 02:40 PM   #29
Fux Wit It
Darksun280's Avatar
Groans: 175
my temp are about 94 now on stock top mount what are your temps at
 Old 09-28-2008, 03:41 PM   #30
oskinosmee's Avatar
I put your pump on i will check again.
The 3 tables you showed me didnt say Fuel pressure. I will check again tho.
In first and 2nd gear meth doesnt come on boost is to low.
I can really see your charts well either loosh
 Old 09-28-2008, 04:01 PM   #31
Laloosh's Avatar
like i said, it looks liek your dipping into the 9s which makes no sense. Dipping into the 9s in the midrange will cause stuttering cause no fuel pump will catch up.
If your sure you changed the numbers correctly, run your 2nd map (zeroed) and see what the car is doing. Flip the switch to the map i gave you and see if it remains to run like shit.
Better yet, give me the standback version you are running and ill send you a tune.file, all you gotta is upload it. Problem is that if we are running different versions, it might not work. I think i will just call cpe and have them email me all their different versions so i can send files instead of posting pages that are hard to read.
If you want to see the tune i posted for you just right click and save each image and open it up on your computer to make it bigger
Laloosh is offline
 Old 09-28-2008, 04:04 PM   #32
Laloosh's Avatar
btw, i posted 4 tables, not 3. The first config page is vital if your going to hit the desired boost levels
Laloosh is offline
 Old 09-28-2008, 04:19 PM   #33
oskinosmee's Avatar
Thanks im running v2 im about to do another run now brb
 Old 09-28-2008, 04:22 PM   #34
Laloosh's Avatar
there are muliple versions of 1 and 2. Like i said, see what happens with it after you made sure all the numbers are correct. If it still runs like shit, send me your actual standback software to laloosh@optonline.net. I will make a file using your software. All you gotta do is open it and load it
Laloosh is offline
The Following User Says NO Thank You to Laloosh For This Un-useful Post:
 Old 09-28-2008, 04:48 PM   #35
oskinosmee's Avatar
Hmmm how do i do that?
Edit log 3 i had to get off because of an animal i didnt want to hit but i got back on til redline
 Old 09-28-2008, 04:50 PM   #36
Laloosh's Avatar
take your standback cd and copy it onto your desktop. Then send me those files
Laloosh is offline
 Old 09-28-2008, 05:11 PM   #37
oskinosmee's Avatar
I sent it
 Old 09-28-2008, 05:25 PM   #38
Laloosh's Avatar
i should be home in about 45
Laloosh is offline
 Old 09-28-2008, 06:09 PM   #39
Laloosh's Avatar
just got your tune. everythign seems correct. As to why your car is doign the exact opposite of what we want it to do. I'm not sure. Try uploading it again just to make sure it was originally uploaded. IF it still acts up, i would seriously check your connections to make sure nothing is backwards. But thats a longshot.
If it still runs liek shit, zero everything out to the way you had it before. I will be there either next weekend or the one after to tune randys car and ill personally take a look at yours just to see wtf is going on.
Laloosh is offline
 Old 09-28-2008, 06:15 PM   #40
oskinosmee's Avatar
I did run again and it doesnt hesitate,it runs like the log i just did, it still doesnt boost right when i installed the the standback i did the voltage test and everything came up right.
Closed Thread
Standback Tuning Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 60 10-04-2013 05:59 AM
PnP Standback? Anklh Custom Performance Engineering (cp-e.com) 3 08-07-2008 08:38 PM
Cp-e standback oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 2 08-03-2008 06:28 PM
Page generated in 0.53667 seconds with 28 queries
