Closed Thread
 Old 09-28-2008, 06:16 PM   #41
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
when did you install the standback?
was the initial log with the standback installed and all zeroed out at 19 psi?
Laloosh is offline
 Old 09-28-2008, 06:22 PM   #42
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
I installed it before my o2 sensor went bad about 2 months ago and yes everything was zeroed out
Gotta Love The Turbocharged Wagon
oskinosmee is offline
 Old 09-28-2008, 06:23 PM   #43
Laloosh's Avatar
ok so everythign was zeroed out and boost was set at 19 or was it set to 15
Laloosh is offline
 Old 09-28-2008, 06:28 PM   #44
oskinosmee's Avatar
It was like this
Boost =19.5
Fuel restore tps= 1.00
Fuel restore rpm= 2000
Fuel cut volt= 1.50
Maf voltage clip= 4.90
Min Map fc enable= -04.00
control kp=30.000
control ki= 00.090
control kd= 220.000
boost clip = 8
Map filt len= 05
wg filt len= 09
 Old 09-28-2008, 06:33 PM   #45
Laloosh's Avatar
i would put it back to that untill i contact the cpe guys and figure out why the car is going rich when im taking fuel away.
The reason why i asked if your boost was at 19 orginally was because if it was set to hit \15 it might have not been activating the meth. Now that its at 19 the meth was in full swing making you run rich/bog. But thats not the case.
Laloosh is offline
 Old 09-28-2008, 06:42 PM   #46
oskinosmee's Avatar
Ok thanks man keep me posted
 Old 09-28-2008, 10:06 PM   #47
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
I did another log tonight with some cooler temps.Still getting shitty knock so i kinda let off the gas before redline,plus i saw a cop lol.
Grim is offline
 Old 09-30-2008, 08:43 AM   #48
Laloosh's Avatar
i cant do anything about it if you dont have a SB lol
Laloosh is offline
 Old 09-30-2008, 09:03 AM   #49
Grim's Avatar
Groans: 70
i know lol,but i just wanted to know if you could help any when i get mine.i just need that damn pnp!
Grim is offline
 Old 10-02-2008, 03:49 PM   #50
oskinosmee's Avatar
Hey loosh any word from CP-E?
 Old 10-02-2008, 03:56 PM   #51
Laloosh's Avatar
nope, didnt approach them about the problem. What has your car been doign since?
Laloosh is offline
 Old 10-02-2008, 04:12 PM   #52
oskinosmee's Avatar
Running normal again
 Old 10-02-2008, 04:19 PM   #53
Laloosh's Avatar
have u tried the map i sent you since?
pm me ure number, this posting shit takes forever to get some info across
Laloosh is offline
 Old 10-09-2008, 09:57 AM   #54
oskinosmee's Avatar
Hey Chris i talked to Jordan and he helped me out but when using the grid for boost it only builds 15 psi no spike or nothing and it would be great if it went to what its set for, so i was thinking if i use the desired boost would it throw my AFRs off?
Now its running good tune with 11s and low 12s AFR no knock i will post a log later.
 Old 10-09-2008, 12:16 PM   #55
Laloosh's Avatar
so what was the original problem? Why was the car doing the opposite of what i told it?
Laloosh is offline
 Old 10-09-2008, 12:40 PM   #56
oskinosmee's Avatar
i have no idea i will send you the tune if you want
 Old 10-09-2008, 12:42 PM   #57
Laloosh's Avatar
send it to me, cause we took away fuel and it ran richer...wtf lol
Laloosh is offline
 Old 10-09-2008, 12:48 PM   #58
oskinosmee's Avatar
I sent it.
 Old 10-09-2008, 12:52 PM   #59
Laloosh's Avatar
looks to be the sample principle as my tune....maybe ure car was having a freak day. Who knows, but it doesnt make sense to me
Laloosh is offline
 Old 10-09-2008, 12:55 PM   #60
oskinosmee's Avatar
Me either but why doesnt it boost right?
 Old 10-09-2008, 02:05 PM   #61
Laloosh's Avatar
what do u mean?
Laloosh is offline
 Old 10-10-2008, 02:14 AM   #62
oskinosmee's Avatar
Latest log Chris Still only getting to 15psi and i have it set to 19
 Old 10-10-2008, 03:39 AM   #63
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
could your boost gauge be off?
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 10-10-2008, 04:52 AM   #64
Laloosh's Avatar
try to not use that boost table and just set the boost to be steady. This turbo will not hold 19 psi.
Laloosh is offline
 Old 10-10-2008, 08:01 AM   #65
oskinosmee's Avatar
I know it wont hold 19. How does that graph look to you? I'm going to use the the desired boost.
Thanks
 Old 10-10-2008, 08:04 AM   #66
Laloosh's Avatar
im at work, its saved on my personal comp.
If you are tying to reach 19.5 anywhere after 4800 it probably wont happen. However you should be higher then 15....if it doesnt move from 15, i dont know what to tell you. You have issues that make no sense to me, unless ure maps are switching by themselves....is that map switch secure??
Laloosh is offline
 Old 10-10-2008, 08:20 AM   #67
oskinosmee's Avatar
i didnt wire in the switch, should i do that today?
 Old 10-10-2008, 08:34 AM   #68
Laloosh's Avatar
Call jordan...why wouldnt you wire in the switch....that could very well be why ure using odd result...who know what map your even on. Once again, i dont how it works when u dont do certain things. My switch is wired in and my maps and boost hold hold well
Laloosh is offline
 Old 10-10-2008, 08:40 AM   #69
oskinosmee's Avatar
I didnt have wire at the time. But that no big deal i will wire it up ASAP
 Old 10-10-2008, 08:49 AM   #70
Laloosh's Avatar
Before you end up wasting time, give cpe a call and ask them what happens when u dont wire in the switch. It might be ok, it might not. But if you have time, wire it in anyway lol
Laloosh is offline
 Old 10-10-2008, 09:01 AM   #71
oskinosmee's Avatar
Jordan said that it would stay on the primary table without the switch.
 Old 10-10-2008, 10:05 AM   #72
Laloosh's Avatar
then im officially out of excuses, your on ure own
Laloosh is offline
 Old 10-18-2008, 04:34 PM   #73
SgtP's Avatar
Groans: 106
Finally installed the standback. I have 4 logs for you. There was a lot of traffic so I wasn't able to get the rpm range I would have like to get but here they are.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-18-2008, 04:40 PM   #74
SgtP's Avatar
Groans: 106
btw which is the primary map, red or green?
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-18-2008, 07:04 PM   #75
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Actually Josh out of the box that doesn't look too shabby! If you're just using the base map then I can send you over a cooked one based on that DH info on Monday. Otherwise shoot me the map you're currently using and I'll just tweak it a little for you (jgartenhaus@cp-e.com).
Slow blinking green is the primary map, and fast blinking red is the secondary. If you're ever unsure of which map you're in you can also open the real-time graphs. There should be a live floating cursor in the table that you're currently using. In other words, if you're in the primary map and you open the primary fueling table then you'll see the floating cursor. The cursor indicates where you are in the table at any given moment.
www.cp-e.com is offline
 Old 10-19-2008, 08:22 PM   #76
SgtP's Avatar
Groans: 106
i emailed you my tune. i was noticing very little difference between the 15psi map and the 18 psi map. both were holding boost around the same for the first few pulls. Then after a little bit of driving the 18 psi one started to feel much stronger. what do you think is max efficiency for our turbo?
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-19-2008, 11:44 PM   #77
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Well I've been following this thread for awhile now and finally got my Standback in and played with it for a couple days.Now that I think everything has settled in I ran a couple different logs the last week.Here are 2 I did Friday evening temp was between 66-68 and the only differences were that one was on the primary map at 15 psi and the other was on the secondary map at 18 psi both were zeroed out other than that.By the way laloosh originally posted these over on your other thread but after the reception you got over there today I fidured you might not come back for awhile so I figured I'd post them here.By the way mine is a Standback2 and the software version on my computer is
ALPHA! V 2.11.0
SneakyP86 is offline
 Old 10-21-2008, 06:00 PM   #78
SgtP's Avatar
Groans: 106
is anyone working on that tune? i want to have something to go with when i hit the track this weekend.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-21-2008, 07:56 PM   #79
Laloosh's Avatar
ill get every1 here i promise, its just be hetic latly and i have zero time
Laloosh is offline
 Old 10-21-2008, 09:30 PM   #80
timv's Avatar
Posts: 179   (View Stats)
timv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud of
Hey, your comparison thread got locked now so you'll have more time.
It's pretty annoying that a thread that actually had some good data and discussion gets locked because people want to argue back and forth.
I figure look at the data and decide for yourself and if you're not happy with the data, go get your own data.....
Also, the same thread on the other forum is gone because they lost all there data since the 14th.......
Anyway, I just sold my AP and have a PNP standback coming from palerider so will have my view comparison at some point. I don't have dyno's or time slips, it would just be some dashhawk comparisons and my personal opinions but I think I can be fairly unbiased.
I will be taking you up on the tuning help soon....
Should us newbies just start with the base 15 and 17psi maps already on the SB and get some logs?
What PIDS do you want?
Thanks in advance for the help and for the information and numbers you have shared with everyone....
timv is offline
Closed Thread
Standback Tuning Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 60 10-04-2013 05:59 AM
PnP Standback? Anklh Custom Performance Engineering (cp-e.com) 3 08-07-2008 08:38 PM
Cp-e standback oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 2 08-03-2008 06:28 PM
Page generated in 0.53152 seconds with 27 queries
