Closed Thread
 Old 10-21-2008, 09:56 PM   #81
phailerider's Avatar
Posts: 4,639   (View Stats)
youre package shipped monday btw.....pnp standback on the way.
phailerider is offline
The Following User Says Thank You to phailerider For This Useful Post:
timv (11-19-2008)
 Old 10-21-2008, 10:18 PM   #82
timv's Avatar
Posts: 179   (View Stats)
timv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud of
Great, thanks. I was able to sell my AP on ebay so got a decent amount back out of it.....
Thanks again for all the help and explanation.....
timv is offline
The Following User Says Thank You to timv For This Useful Post:
phailerider (10-23-2008)
 Old 10-23-2008, 06:21 AM   #83
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
is it possible to get me a tune by this weekend? I am expecting to go to the track and would love a first tune to see what I can get my times down to.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 10-23-2008, 07:42 AM   #84
timv's Avatar
Got the package yesterday, already!!! I'm going to read all the directions and check out the software and hopefully install it this weekend.
Thanks!!!!
timv is offline
 Old 10-23-2008, 09:00 AM   #85
SgtP's Avatar
Groans: 106
the install with the pnp should take close to no time. Our ECU is pretty easy to get at. It will probably take you longer to mount the switch.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-23-2008, 01:17 PM   #86
timv's Avatar
Once I install this, what would be everyones recommendation for beginning to tune it?
Should I start with just the base 15 and 17 psi maps and get some dashhawk logs to post? If so, what PIDS should I monitor, same ones as others have posted here?
All I have right now is the CPE CAI but have a rpmc turbo inlet to install and my CPE FMIC I think is at the powder coaters now getting all stealthed out so I should get it next week.
Thanks for any advice....
timv is offline
 Old 10-23-2008, 02:16 PM   #87
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
Originally Posted by SgtP View Post
Finally installed the standback. I have 4 logs for you. There was a lot of traffic so I wasn't able to get the rpm range I would have like to get but here they are.
how far apart were these done? you car is all over the place af/timing wise
Laloosh is offline
 Old 10-23-2008, 03:37 PM   #88
SgtP's Avatar
Groans: 106
I made 8 pulls total and i thought i uploaded all the ones from my zeroed out 18psi map but i might have been wrong and some might be from the 15psi map. I loaded some from the dashhawk to my laptop on the side of the road so I could make a few more pulls and they probably got F'd up. They were all done within 10 minutes of each other though. I really wanted to get one from 3k to redline but traffic and other factors came into play so i couldn't. If you cant work with those I can log some new ones and ensure I stay on the 18 psi map. At the time I had no idea which light meant which map and I really couldnt tell the difference between the two. They both just pulled harder lol.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-23-2008, 05:03 PM   #89
Laloosh's Avatar
well u need to tell me what is what lol, cause to me that either looks like two different boost levels, 2 different temperatures, or two different cars lol
Laloosh is offline
 Old 10-23-2008, 05:11 PM   #90
SgtP's Avatar
Groans: 106
lol.... its two different boost levels. ill get some new pulls for you to work with. i was too excited that i didnt blow anything up after the install and the car was pulling harder than ever.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-23-2008, 05:54 PM   #91
Laloosh's Avatar
also do me a favor, send the actual dh file so i can real dial this bitch in for you to my liking.
All you gotta do is; once you upload the log and look at it, click file save. Save it to a folder on your desktop. once you save it you will see to files. .log and .lrp. Send me those two file for each log and i can open it up with my dh to scale it zoom it ect ect.
Laloosh is offline
 Old 10-23-2008, 06:11 PM   #92
SgtP's Avatar
Groans: 106
will do chris. you are on 2.5 correct? i dont think the 2.5 and 2.4 files are the same. at least i couldnt open my 2.4 files when i upgraded to 2.5. Ill get you at least 2 good 3k to redline pulls.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-23-2008, 06:14 PM   #93
Laloosh's Avatar
Laloosh is offline
 Old 10-23-2008, 06:18 PM   #94
SgtP's Avatar
Groans: 106
btw i just got confirmation that my asus Eee is shipped. it will be my personal tuning laptop. only thing i have to do now is run the usb extension to the glove box.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-23-2008, 09:40 PM   #95
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Hey Laloosh don't do anything with mine yet as I got the install bug and have installed my HKS Twin power Ignition and my FMIC and tomorrow will probably be installing my Corksport exhaust so let me finish this up and in a day or two will run some more logs to see where I'm at.
SneakyP86 is offline
 Old 10-24-2008, 06:01 AM   #96
Laloosh's Avatar
oki, np
Laloosh is offline
 Old 10-24-2008, 08:24 AM   #97
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
So the base maps you guys are referring to are the totally zeroed out maps with 17 PSI that come in the Standback...?
I got a CP-E base tune also... I just don't know how safe it would be to run with my mods. According to the notice, only CP-E CAI, DP, and CBE should run this map.
I have:
MS CAI with straightener
RPMC INLET
ETS 3.25 TMIC
HKS BPV
CP-E catted DP
CS CBE
It shouldn't be detrimental right? I mean its probably a mild tune... Just curious.
I'm installing the Standback this weekend, actually all I need to do is route the switch wire through the hood release grommet and plug in the Standback.
I'll post a log Monday...
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline
 Old 10-24-2008, 08:26 AM   #98
Laloosh's Avatar
just post a log all zeroed out at the boost level you choose to run.
better yet send me the log files
Laloosh is offline
 Old 10-24-2008, 08:36 AM   #99
AutoXRacer's Avatar
OK...
I'll post something on Monday...
 Old 10-25-2008, 09:38 PM   #100
AutoXRacer's Avatar
OK, so I finally installed the Standback and went for a ride... Everything was fine until!!!!!!!!
My car died... I thought I had blew the engine... There was no throttle responce... The RPMs were just decreasing... I gave it throttle and nothing still decreasing RPMs... Now I was sure my engine was dead...
Then all of a sudden, I saw lights behind me (it was night time)...I thought it was a cop, but it wasn't, it was a giant flame!!!! I've never seen anything like that!!! It lit up the whole street, I thought my car was on fire!!!!!
Then it went away... I was still decelerating... I slowly gave it throttle and it responded again... I drove it home slowly and parked it in the garge... I'm afraid to turn it back on. Everything seems normal again...
I don't know what to do with the Standback now... My car was running perfectly before...
Notes to keep in mind. I was noticing that the car was running lean...high 12s into the low 13s. And it was knocking in the low 2.0-3.2. This data was prior to the incident.
Oh and my popping, crackling, and burbling from my exhaust went away too... That was so weird!!!
I now have zeroed out everything in the Standback other than the boost which I have the primary set on 18 and secondary on 17.
I don't know what the hell happened!!! I was running a MAP Jordan gave me to try out. But it seems its too lean or something wrong with that MAP.
Laloosh, I need your expertise!!!!
 Old 10-26-2008, 12:01 AM   #101
Laloosh's Avatar
like i said 100 times, ots maps dont work on these cars
Laloosh is offline
 Old 10-26-2008, 06:28 AM   #102
AutoXRacer's Avatar
Whats ots...?
So any idea what might have happened...? Too lean perhaps...?
Do you suggest I give the stock ECU a couple of days to adjust itself since I had to disconnect the battery, before I log some runs?
 Old 10-26-2008, 06:38 AM   #103
mazdaj's Avatar
Posts: 369   (View Stats)
mazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the world
ots=over the shelf
u need to log and tune based on your mods...
my suggestion is dont jump into things too quickly. i have my map switch with the base map w/ stock boost and zeroed out so i can always switch back and a zeroed out 17.5 psi map. ive been running it for a while just to make sure there are no problems. do one thing at a time or else your gonna get confused as to what is doing what and why its not working.
zero every thing out and just start with upping the boost to your choice.
do 4th gear logs from 3k-6.5-7k w/ the boost of your choice and post them and loosh can help you from there.
tuning is not a simple process, u have to gradually change shit and see what works for your car.
mazdaj is offline
 Old 10-26-2008, 06:55 AM   #104
mazdaj's Avatar
love the asus eee.....i just picked up the lenovo s10 (pretty much same specs but w/ a 10 inch screen, 80gb upgradeable hd, sturdier case) as a tuning laptop and i friggin love it. i just put in 2gbs of ram so it runs nicely. i couldnt pass it up because i got a shit ton of discounts and ended up paying 300 for mine total, cant beat that
mazdaj is offline
 Old 10-26-2008, 06:56 AM   #105
AutoXRacer's Avatar
Thanks
Jordan has sent me this map to try... I was under the impression he made up something mild for me as a base map to work from according to my mods...
But I have zeroed out everything and set the primary boost to 18 and secondary to 17; everything else is zero!!
One question regarding the v2 software, why can't you close the stupid tables once you open them? I can only minimize... And do you have to upload the configuration, then upload the tables? Why doesn't it do it automatically?
I like v3 a lot better, its so much simpler to work with...
 Old 10-26-2008, 06:58 AM   #106
AutoXRacer's Avatar
Originally Posted by mazdaj View Post
love the asus eee.....i just picked up the lenovo s10 (pretty much same specs but w/ a 10 inch screen) as a tuning laptop and i friggin love it. i just put in 2gbs of ram so it runs nicely. i couldnt pass it up because i got a ton of discounts and ended up paying 300 for mine total, cant beat that
Damn you guys... I just got my DELL Mini this week... I love mine, but the screen is a little too small and v3 doesn't display correctly; half the table is not viewable. I would have preferred a 10" instead of 9".
I also upped my RAM to 2gb from 1gb. Its so tiny!!!
 Old 10-26-2008, 07:06 AM   #107
mazdaj's Avatar
Originally Posted by AutoXRacer View Post
Thanks
that is just how lou wrote the program....dont worry, im beta testing the new sb software right now and its going to look way more slick and be much more user friendly and have some nice new options/features incorporated. the logging is way more improved and easier to read, there will be tabs instead of having to minimize everything, red/green colors for primary/secondary maps to avoid confusion, etc. that has always been one of my gripes too as well as many others here, just how crude the v2 software looks. the v3 software is going to look very professional soon, just working some bugs out right now...
mazdaj is offline
 Old 10-26-2008, 07:22 AM   #108
AutoXRacer's Avatar
Yeah, I really like v3 better... I've been testing/playing with it and I did report back a few bugs or small issues. Definitely 100X better than v2.
 Old 10-26-2008, 08:01 AM   #109
23 marine's Avatar
Posts: 131   (View Stats)
23 marine is a splendid one to behold23 marine is a splendid one to behold23 marine is a splendid one to behold23 marine is a splendid one to behold23 marine is a splendid one to behold23 marine is a splendid one to behold23 marine is a splendid one to behold
Thumbs up
thank you guys for this thread, keep up all tha good work with your tunnings.
23 marine is offline
 Old 10-26-2008, 08:34 AM   #110
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
Wait V3 is ready?
Gotta Love The Turbocharged Wagon
oskinosmee is offline
 Old 10-26-2008, 09:08 AM   #111
mazdaj's Avatar
Originally Posted by oskinosmee View Post
Wait V3 is ready?
no, its still in beta...it will be released soon though hopefully....
mazdaj is offline
 Old 10-26-2008, 12:14 PM   #112
SgtP's Avatar
Groans: 106
im patiently waiting for it. Unless Jordan wants to send me a copy to screw around with
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 10-27-2008, 06:51 AM   #113
AutoXRacer's Avatar
Just email Jordan and I'm sure he'll send you a copy.
 Old 10-31-2008, 07:30 AM   #114
AutoXRacer's Avatar
I increased my boost to 19 PSI this morning. While driving to work, I noticed that on a 4th gear pull that there is a slight delay on power...
I noticed that my AFRs upon WOT take a few seconds to reach low 12s where there is a sudden burst of power. Prior to that, you just feel a slight pull, then when the AFRs hit low 12s, BAM she just takes off...
I don't know if this also happened at 18 PSI... I will change it back as see...
But is this just a need for tuning, is there something wrong, or is this just the nature of the CDFP...? My fuel pressure does hit 1600-1700 PSI at WOT instantly and holds steady.
Oh and another quick question... What is the best method for boost control, the configuration page setting or using the boost table?
 Old 10-31-2008, 08:11 AM   #115
oskinosmee's Avatar
For me when I use the boost tables its builds boost to slow, when I use the desired boost it jumps up to 20 and stays there for a while then it tapers down of course. But if ya didn't know I run meth too so i hope I helped a lil
 Old 11-04-2008, 04:11 PM   #116
btkrausen's Avatar
Posts: 48   (View Stats)
btkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nice
Ok, so I installed the Standback today, all 0'ed out and 16psi. Below are the logs. One thing that I noticed is that when I was in 6th, and WOT, it only held a bit less than 13 psi, but the lower gears hit higher I believe.
-bryan
CP-E CAI | CP-E FMIC | CP-E Standback v2 | CP-E PnP | CP-E Flash | CP-E SSQV BOV Kit | Cobb STS | Cobb Shifter Weight | SU MM | SU Test Pipe | Boost Gauge | Black out Side Markers | SU Bushings | DashHawk
To Be Installed: DNP Turbo Manifold
btkrausen is offline
 Old 11-04-2008, 04:16 PM   #117
btkrausen's Avatar
oh yeah, when i logged this, i didn't have the map switch, led, ground thingy connected.
-bryan
 Old 11-06-2008, 05:33 PM   #118
kopf's Avatar
Posts: 327   (View Stats)
kopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the worldkopf is the leader of the world
4th gear, needs some work
kopf is offline
 Old 11-06-2008, 06:18 PM   #119
Laloosh's Avatar
maf primary
2.1 on the x axis
i 4got what the exact rpms the standback uses but anything close to 3200 through 4000. 2.1 and right put the number 6 in there
4200-5000 -1.5
5400-5800 -3.0
5800-7000 -4.0
timing pull 1 degree from the lowest rpm available to 3200
after 5500 rpm add 1
next rpm after 5500 available add 2 till 7000
Laloosh is offline
 Old 11-06-2008, 06:21 PM   #120
Laloosh's Avatar
u need to either send me the log and lrp files for each log or rescale the af line and post again. There is not enough detail for mee to see what the actual af reads
Laloosh is offline
Closed Thread
Standback Tuning Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 60 10-04-2013 05:59 AM
PnP Standback? Anklh Custom Performance Engineering (cp-e.com) 3 08-07-2008 08:38 PM
Cp-e standback oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 2 08-03-2008 06:28 PM
Page generated in 0.56997 seconds with 31 queries
