  • 1 Post By Poohster
 Old 12-21-2012, 08:18 PM   #1
Poohster's Avatar
Posts: 353   (View Stats)
Default Thanks goes out to CP-e, Chunie and Darren
I know the job is not completed yet. But I wanted to give Chunie, Darren and CP-e a big Thank You. Long story short: I had a rattle at moderate load, 2500-3300 RPM. Sounded like the VVT or timing chain issue. Ordered a DCR VVT, timing chain and tensor. Directed CP-e to install while re-flashing my ECU. Test drive proved that was not the issue. After numerous diagnostics, CP-e found cylinder 3 was dead. Found a valve sitting in the cylinder. The valve train had finally failed during diagnostics. Speculated the valve may have slightly stuck open and was hitting the piston during load. This could account for my KR issue.
I assumed the cylinder is now toast and proceeded to do a stage 2 build for reliability. CP-e is working with me to make this happen. Starting with a stage 2 short block, service the cylinder head, move my engine stuff over, black crinkle VC and timing cover and maybe a new clutch while everything is a part. Also finally going AP. My wallet maybe a little lighter but I will have a bigger smile on my face in the new year. Sorry, I didn't have a detailed shot of the broken valve.
Thanks CP-e for the great customer service and Merry Christmas and Happy New Year!
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
The Following User Says Thank You to Poohster For This Useful Post:
www.cp-e.com (12-24-2012)
 Old 02-07-2013, 06:44 PM   #2
Poohster's Avatar
Some pics of their work. I'm so Happy!!!!!!!!!!!!
DaDoctor likes this.
The Following 4 Users Say Thank You to Poohster For This Useful Post:
Code Monkey (02-07-2013), DaDoctor (02-11-2013), SpeedRebirth (02-09-2013), www.cp-e.com (02-14-2013)
 Old 03-14-2013, 07:44 PM   #3
Poohster's Avatar
CP-e completed a dyno tune and here are results: 258 hp and 292 ft-lbs at 18 lbs of boost.
Big thanks to Chunie&Grumpyjap markos213 Custom Performance Engineering (cp-e.com) 5 10-03-2012 07:21 AM
Journalist Sue Mead, racer Darren Skilton become first U.S. team to win a class in Dakar Rally Haltech Automotive News 0 01-17-2011 03:30 PM
Page generated in 0.24073 seconds with 21 queries
