 Old 07-02-2012, 05:49 PM   #1
grantmm's Avatar
Posts: 826   (View Stats)
Groaned at 8 Times in 5 Posts
Default TMM has separation between rubber and metal?
Just got the transmission mount from EdgeAutosport/CPE. Is this slight separation between the rubber and the center hole normal? The discoloring also makes me wonder if this was used already.
And here's my install buddy who desperately wants people to look at his non existent balls:
The Following User Says Thank You to grantmm For This Useful Post:
helmetface (07-02-2012)
 Old 07-02-2012, 08:38 PM   #2
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
That shouldn't cause you any issues, that jusy looks like some tooling marks when they cut the bushing. I wouldn't worry about it.
Fueled by the haters.
grantmm (07-02-2012)
 Old 07-02-2012, 10:01 PM   #3
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
it looks fine. that tapered lip of epdm is just there to keep the bushing close to where it needs to be. once you get this in, it'll tear and shift around a bit, but will still work fine. the epdm is much softer than the metal and the different elasticities will certainly cause the the epdm and metal to disadhere. it is designed to do that. the epdm is solid enough that it will hold the metal insert in place by pressure, not adhesion.
The Following User Says Thank You to tddvrrn For This Useful Post:
grantmm (07-03-2012)
 Old 07-03-2012, 10:02 AM   #4
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Thats fine it won't effect its performance. Sometimes the rubber with even serarate from the rubber, this is fine also, since the rubber isn't adhered to the center piece. It will definitely not effect the performance though.
The Following User Says Thank You to Grumpyjap For This Useful Post:
grantmm (07-04-2012)
 Old 07-04-2012, 04:35 PM   #5
grantmm's Avatar
Sounds good to me. I just wanted to get things clarified before many miles were put on it.
tddvrrn (07-04-2012)
Goodyear recalls 41,000 tires for potential tread separation Haltech Automotive News 0 02-27-2012 04:10 PM
Ford recalling 126,000 Fusions and Milans over wheel separation concern Haltech Automotive News 0 12-09-2011 09:10 AM
New Rubber Franconemo 2010 MS3 - Wheels & Tires 31 04-17-2010 08:43 PM
Got Some New Rubber: Kdawg207 MazdaSpeed 3/6 - Wheels & Tires 6 02-17-2010 04:53 PM
Chevy recalls 2005-2007 Corvettes over possible roof panel separation Haltech Automotive News 0 12-29-2009 08:10 AM
Page generated in 0.26520 seconds with 23 queries
