| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
7Likes ![]() |
![]() Join Date: Mar 2011 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 414
(Thread Starter) | Not Ranked : 0 score I've seen and heard the Triton in person. Like it alot but I would want something a little quieter. Would just like to know where this "additional muffler" would be installed at. Any pictures, price and sound clip of the triton with the additional muffler would be awesome. Nothing on the website about it
__________________ 2011 Mazdaspeed 3 - Black Mica NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage |
| The Following User Says Thank You to DaDoctor For This Useful Post: | rfinkle2 (12-06-2012) |
![]() Join Date: Feb 2012 Location: Dana Point, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,483
Groans: 107
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score You could try a resonated test pipe? I don't see a TP in your mod list. I've seen a few people with UR CBE & Resonated Test Pipe say there is very little drone. Honestly though, the drone isn't that bad for me, and I have a catless TP. The only time the drone gets pretty crazy is on the freeway, during engine decel, at around 3400RPM
__________________ 2012 MS3 Stratified 91 Cobb AP | UR FMIC, TP, CBE | Autotech Internals Forge v2 BPV | Denso ITV22 | SURE Aeros Full3 ID283* JBR 88a RMM/TMM, 70a PMM, OCC, RSB, TIGs, Coolant bypass, EGR delete, Bushings, Knob Aeroforce Interceptor | Defi Boost gauge *Product is advertised as ID300 |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Upgrade the sound system.
__________________ |
| The Following 3 Users Say Thank You to helmetface For This Useful Post: |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score U just need to add a dumped 44mm gate to your set up, no more drone. |
| The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post: | doubleflusher (12-06-2012), kritz (12-24-2012), MarineMazda (12-22-2012), Monotonous ONE (12-06-2012), rfinkle2 (12-06-2012) |
(Thread Starter) | Not Ranked : 0 score TP won't work, I already have a CP-e DP. I'm just getting old and cunty. It bothers the shit out of me. It's also not a good look at work, when ur setting of alarms in the basement parking deck and your boss with 4 supervisors walks by. I had the magnaflow and it wasn't loud enough. Would like to find something in the middle with no drone. Does that exist?
__________________ 2011 Mazdaspeed 3 - Black Mica NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage | |
![]() Join Date: Dec 2009 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
| Not Ranked : 0 score I couldn't take the drone of my mscbe so I added a high flow cat and two vibrant resonators. Still didn't get it quiet enough. Cobb cbe was my final solution. I couldn't be happier with it. |
| The Following User Says Thank You to NoLeftTurn For This Useful Post: | DaDoctor (12-05-2012) |
Groans: 107
I'm not familier with too many CBE, but I know the Cobb has an amazing sound, and is a bit more quiet than some other CBE. It is also advertised it is in compliance with sound restrictions:
__________________ 2012 MS3 Stratified 91 Cobb AP | UR FMIC, TP, CBE | Autotech Internals Forge v2 BPV | Denso ITV22 | SURE Aeros Full3 ID283* JBR 88a RMM/TMM, 70a PMM, OCC, RSB, TIGs, Coolant bypass, EGR delete, Bushings, Knob Aeroforce Interceptor | Defi Boost gauge *Product is advertised as ID300 | ||
| The Following User Says Thank You to Keko For This Useful Post: | DaDoctor (12-05-2012) |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score Our triton exhaust actually doesn't come with any mufflers. There are only 2 resonators We don't offer an option for a muffler.
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
![]() Join Date: Mar 2010 Location: BOCA RATON FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Groaned at 60 Times in 18 Posts
| Not Ranked : 0 score Time to update the Triton page on your website then. "Options include an additional muffler as well as our stealth Black Chrome tips. This additional muffler will quiet down the exhaust significantly while not adding additional backpressure".
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) |
(Thread Starter) | Not Ranked : 0 score I wish I knew what this meant. I'm guessing its a BT inside joke. ![]() Sent from my HTC_Amaze_4G using Tapatalk 2
| The Following User Says Thank You to DaDoctor For This Useful Post: | rfinkle2 (12-07-2012) |
Groans: 113
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | rfinkle2 (12-07-2012) |
(Thread Starter) | Not Ranked : 0 score Oh well! I just want to confirm how much I really like the construction, appearance and sound of the Triton. In my opinion, It's def the best sounding option we have for the Gen2. Since that "additional muffler" doesn't exist, Cobb is looking better and better. Sent from my HTC_Amaze_4G using Tapatalk 2
| Not Ranked : 0 score I stand corrected. The muffler option is actually placed in the front section of the exhaust. We've only sold 1 or 2 for german customers. If you'd like to order one with the muffler option please give us a call 301 576 6142
(Thread Starter) | Not Ranked : 0 score Thx for clarifying about the additional muffler. How much more is it? I shouldn't have to call to get the price...its not like it should be considered a secret. Other members might be interested in this option as well. Sent from my HTC_Amaze_4G using Tapatalk 2
| Not Ranked : 0 score The muffler option is an extra $150 for the triton exhaust
| The Following User Says NO Thank You to www.cp-e.com For This Un-useful Post: | Monotonous ONE (12-23-2012) |
(Thread Starter) | Not Ranked : 0 score Installed the triton with the additional muffler yesterday. Not too loud, Not too quiet. Great quality as well. Had a little issue with fitment for the exhaust tips. The passenger side exhaust tip sticks out a bit too much. Haven't searched to see if anyone else has had this problem. Will try to get a sound vid up within the next two weeks.
| The Following 4 Users Say Thank You to DaDoctor For This Useful Post: |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | Monotonous ONE (12-23-2012) |
| Not Ranked : 0 score Where is the additional muffler placed? I have 2 resonators but am considering adding the muffler. |
![]() | | #19 | ![]() |
| Not Ranked : 0 score In the front part of the mid pipe
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | rfinkle2 (12-21-2012) |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
![]() Join Date: Oct 2012 Location: Ft. Huachuca, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,541
| Not Ranked : 0 score Is there a picture of the flange that connects to the test pipe? I have the CS 80mm test pipe and wanted to see if the triton would fit up all nice like.
__________________ Stock as fook. |
| The Following User Says Thank You to agentgordon27 For This Useful Post: | rfinkle2 (12-23-2012) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score I'm sure we could arrange something If the CS 80mm test pipe fits up to the OEM cat back then yes.
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | rfinkle2 (12-24-2012) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Hmm, might have to migrate over to Corksport area to ask that one.
| MazdaSPEED3 Gen2 Triton™ 3" SS Cat Back Exhaust System | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 4 | 05-09-2012 06:01 AM |
| MazdaSPEED3 Gen2 Triton™ 3" SS Cat Back Exhaust System | Grumpyjap | Custom Performance Engineering (cp-e.com) | 17 | 03-19-2012 05:20 PM |
| looking for a sound clip of a ms3 with 3" exhaust with NO cats, resonators, or muffler | TWOptSL0W | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 06-10-2011 05:43 PM |
| looking for a sound clip of a ms3 with 3" exhaust with NO cats, resonators, or muffler | TWOptSL0W | 2010 MS3 - Engine, Transmission & Driveline | 1 | 06-08-2011 04:50 PM |
| 3" Manderel Bent Exhaust with Apexi N1 Muffler | Death-From-A-Mile | MazdaSpeed 3 - Engine, Transmission & Driveline | 30 | 09-15-2008 09:29 PM |
