| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
(Thread Starter) | Not Ranked : 0 score http://www.mazdaspeedforum.org/forum/foru...i-need-133719/ I'm currently running a Steedspeed T3 manifold, and in that thread it was suggested that I might consider upgrading to the CPE manifold to maximize my potential. I hadn't ruled it out, but, I was planning on doing that later rather than sooner. I had a few other things I was going to do first and then see if I needed the CPE manifold or not. I was going to upgrade my intake from 3" to 3.5", using the HTP intake. But, I can't get that intake to fit. The intake hits the bracket for the shifter lines. Here is a thread I created on the issue: Installing large intake - MS6 I guess conceivably a different bracket could be built that might route the shifter lines a bit further out of the way. But, at this point, I'm thinking that probably my problem is the Steedspeed manifold. I bought the swept-back version of the manifold, which I was told placed the turbo farther from the block, closer to the firewall, supposedly for more room. But, I'm thinking now it is placing my turbo too low. So the primary purpose of this thread is just to verify, if I go the CPE manifold, the shifter line bracket per the pictures in the above thread is safely out of the way?
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust |
| Not Ranked : 0 score its not the SS manifold, bend the bracket or buy a silicone intake, but dont remove it completely.
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score I think I had the same issue with shifter cable bracket on my inlet pipe I fabbed. It's been a while since I have been in that part of the engine bay so let me grab some pics this evening and post up what mine looks like and see if this problem exists with the speed 3. I do know that this problem did not pop up when I installed the CP-E manifold, so if there was a problem I worked through it when I did the original install of the SS manifold 2 years ago.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
But, tis true, the CPE intake did fit since it could deform. I will see about bending the bracket.
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust | |
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
(Thread Starter) | Not Ranked : 0 score Actually, my power goals are in the 500 range. It may not be immediate, and I may have to upgrade the manifold. But that is the eventual goal. And my current MAF, the ATP 3" MAF, is getting close to maxed out. And my current intake is also an ungainly collection of couplers. So, I was really wanting to make it one nice solid piece.
| The Following User Says Thank You to Speedie6 For This Useful Post: | superskaterxes (02-18-2013) |
| Not Ranked : 0 score @Speedie6; Here this the only pic I could find that shows the shifter cable holder. I just bent down and away to allow enough room for the inlet pipe. Although I am using a 3.5" - 4" reducing elbow with an 8" leg but it does not interfere with the elbow, so I am thinking that a solid pipe would fit with out interference.
| The Following User Says Thank You to SilverDemon For This Useful Post: | sidekick (02-18-2013) |
| HID Positioning | XuDynasty | 2010 MS3 - Troubleshoot/Diagnostics | 1 | 06-28-2012 10:21 PM |
| Cleaning IM & occ positioning | oh_yeams6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 10-07-2011 10:20 AM |
| High strength studs for turbo (manifold to head and manifold to turbo) | bnoon | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-11-2009 10:26 PM |
| Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold | nobmood | Mazdaspeed3/6 General Discussion | 18 | 03-01-2009 08:14 PM |
