| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
(Thread Starter) | Not Ranked : 0 score I've asked time and time again and have been told CP-e won't separate the dp from the atmosphere kit. Perhaps we can drum up enough interest to make them change their mind. Let them know there's money to be had. Let them know that if they don't want that money, someone else will happily step up and take it. Who wants one?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 8 Users Say Thank You to Tokay444 For This Useful Post: | acousticdefbot (07-09-2015), Awal (07-13-2015), Easter Bunny (07-09-2015), littleloogy (07-08-2015), Mauro_Penguin (07-09-2015), Micha (07-10-2015), SIXual Panda (06-28-2016), WetzMS3 (07-09-2015) |
| The Following User Says NO Thank You to Tokay444 For This Un-useful Post: | Hammology (07-14-2015) |
Groans: 33
| Neutral : +1 score They truely are a work of art
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score LOL... They will never fall for this. They don't care about making money.
__________________ 2006 Black Mica MS6 - Sold 10/15 |
| Not Ranked : 0 score Too little, too late.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Awal (07-13-2015), Easter Bunny (07-09-2015) |
![]() Join Date: Dec 2013 Location: Wisconsin
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score i doubt this will ever happen |
| Not Ranked : 0 score After dicking around with my CPE manifold and CPE down pipe (non atmosphere do) I think it's STUPID they won't sell it separately. As everyone knows trying to install a normal CPE dp with the CPE manifold is next to impossible because of O2 sensor placement. Pretty idiotic designing on their part and idiotic purchase on my part. One would think two parts designed by the same company would work together. In the end, I would be down for just an Atmospheric dp. Then I would sell the current dp to recoup some of my mistake.
| The Following 4 Users Say Thank You to jdmage_mx5 For This Useful Post: |
| Not Ranked : 0 score yikes i have a new dp and mani to install from cpe... wish me luck |
| The Following User Says Thank You to Wolfmanstein For This Useful Post: | Awal (07-13-2015) |
| Not Ranked : 0 score If the dp is new send it back and get a different one. The O2 sensor placement is so damn close to the Tial EWG once fully assembled it makes me slightly uncomfortable. Both pieces are exceptional individually; together they suck big time.
| The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post: |
| Not Ranked : 0 score I have this exact setup and you just have to use the secondary bung, but I agree with your evaluation. you can't always make things either backward or forward compatible though.
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (07-09-2015), jdmage_mx5 (07-09-2015) |
But I do understand this would require recasting of the bell mouth.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with | |
edit: even with the entire kit there is very little clearance for an O2.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Awal (07-13-2015), Mauro_Penguin (07-09-2015) |
| Not Ranked : 0 score Ill just weld a bung in if it gives me a problem.... but cpe why no not sell separately |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score I'd be interested. So long as cpe doesn't try to strong-arm some ridiculous price hike.
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
| The Following 3 Users Say Thank You to Mauro_Penguin For This Useful Post: |
| The Following User Says Thank You to Wolfmanstein For This Useful Post: | Mauro_Penguin (07-09-2015) |
| Not Ranked : 0 score At this point we should just send one to China to be reverse engineered.
| The Following 14 Users Say Thank You to Easter Bunny For This Useful Post: | ASHMS3 (07-15-2015), Awal (07-13-2015), Big_Burd (07-16-2015), dagrimey1 (07-13-2015), Eric28243 (07-09-2015), HawkeyeGeoff (07-09-2015), jdmage_mx5 (07-09-2015), littleloogy (08-20-2015), Mauro_Penguin (07-09-2015), Micha (07-10-2015), rob ms6gt (07-14-2015), theschrum (07-16-2015), WAMBUSHHHH! (07-14-2015), WetzMS3 (07-09-2015) |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score It is definitely the best thing ever. I can confirms
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post: | Mauro_Penguin (07-09-2015), Mazdazilla6 (07-10-2015) |
Groans: 793
(Thread Starter) | Not Ranked : 0 score So what's that 3 of us? Maybe 4? Just on the first page.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Mauro_Penguin (07-09-2015) |
![]() | | #19 | ![]() |
Groans: 171
I'm pretty sure more people would be on if they realized what this thread was. It's been brought up a couple of times and unfortunately their response is always very bah hum bug. Which is silly because the manifold and downpipe are the best parts of that whole kit, everything else including their turbo options can be replaced with better competitor parts.
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow | |
| The Following 4 Users Say Thank You to Mauro_Penguin For This Useful Post: |
![]() | | #20 | ![]() |
| Not Ranked : 0 score I'm sure that China has a factory churning out knockoff engineering licenses so no worries there. Never.
__________________ I hugged rfinkle2 Last edited by Easter Bunny; 07-09-2015 at 03:53 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 9 Users Say Thank You to Easter Bunny For This Useful Post: | Awal (07-13-2015), Big_Burd (07-16-2015), impossible (06-03-2016), jack_hammer (07-14-2015), Mauro_Penguin (07-09-2015), Raider (07-09-2015), rob ms6gt (07-09-2015), Tokay444 (07-09-2015), WA_MS6 (07-14-2015) |
![]() | | #21 | ![]() |
![]() | | #22 | ![]() |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1702 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
| Not Ranked : 0 score This will release right after the intake manifold..... I bought a vband dp from fj for my precision. Dump tube wasn't plumbed in obviously and Was a little short...but may have been bc of my manifold. Who knows. SHOULD fit all stock location turbo setups
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() |
| The Following 2 Users Say Thank You to 865ms3 For This Useful Post: | Easter Bunny (07-09-2015), Justin@Freektune (07-13-2015) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score When does the IM come out? |
![]() | | #24 | ![]() |
![]() Join Date: Oct 2014 Location: sugar land, texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
__________________ guzzlin' a guinness stout. |
| The Following 4 Users Say Thank You to acousticdefbot For This Useful Post: |
![]() | | #25 | ![]() |
Groans: 793
(Thread Starter) | Not Ranked : 0 score Sell the fucking downpipe @www.cp-e.com;
![]() | | #26 | ![]() |
Groans: 793
![]() | | #27 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
| The Following 5 Users Say Thank You to WetzMS3 For This Useful Post: | chaser27 (07-24-2015), Easter Bunny (07-16-2015), MattyP617 (09-01-2015), Mauro_Penguin (07-16-2015), Tokay444 (07-16-2015) |
![]() | | #28 | ![]() |
Groans: 33
| Not Ranked : 0 score When I bought the atmosphere kit cpe told me that the v-band hotside had to be machined a little bit to fit the kit. Im not 100% sure what they acually machined off though. It is a bit tight to get the o2 sensor on yes, but it works. Taking the plastic/metal cowel off makes it 10 times easier. And doing it before the wastegate is also a good idea
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | Mauro_Penguin (07-09-2015) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score lol I had to "machine" my v-band flange on the EM just to get the cap for the EWG to seal. IMO vband is not what it's cracked up to be, or maybe it's just CPEs implementation.
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #30 | ![]() |
Groans: 793
(Thread Starter) | Not Ranked : 0 score I hand lapped all the mating faces of my setup. Tial needs to adjust their machining practices. Even the flanges that hadn't been welded to anything weren't flat, and there was obvious distortion in the form of a tri-oval, which is dead give away that they just squish them in a 3 jaw chuck to face the critical mating surfaces.
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #31 | ![]() |
so IMO v-band is not the end all, be all of connectors.
![]() | | #32 | ![]() |
| Not Ranked : 0 score It's funny this is getting brought up. My EWG to manifold vband will NOT fully seal and I'm starting to get a build up of exhaust crap around it. I need to quit being lazy and try to fix it.
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | Awal (07-13-2015) |
![]() | | #33 | ![]() |
Groans: 793
(Thread Starter) | Not Ranked : 0 score I'm pretty sure they buy the flanges from tial.
![]() | | #34 | ![]() |
| Not Ranked : 0 score well then fuck tial
| The Following User Says Thank You to Dano For This Useful Post: | jack_hammer (07-14-2015) |
![]() | | #35 | ![]() |
Groans: 793
![]() | | #36 | ![]() |
Groans: 793
| The Following User Says Thank You to Tokay444 For This Useful Post: | Mauro_Penguin (07-19-2015) |
![]() | | #37 | ![]() |
![]() Join Date: Sep 2011 Location: Canada
| Not Ranked : 0 score Why don't you just get some other vendor to build one? Obviously cp-e doesn't give a shit about the mazdaspeed community.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
![]() | | #38 | ![]() |
Groans: 793
(Thread Starter) | Not Ranked : 0 score I'm surprised Just Borrowed Racing hasn't copied it yet.
| The Following 11 Users Say Thank You to Tokay444 For This Useful Post: |
| The Following User Says NO Thank You to Tokay444 For This Un-useful Post: | Gr8Speed (07-13-2015) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Can you make a silicone downpipe?
![]() | | #40 | ![]() |
| Not Ranked : 0 score In all seriousness I wish someone would.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Koke382 (07-16-2015) |
| Display Modes | |
| cp-e Atmosphere vs ATP | Baloo | MazdaSpeed 3/6 - Turbo Induction | 16 | 05-17-2014 08:42 AM |
| Who wants to see an MS6 Atmosphere Kit From CP-e? | superskaterxes | Custom Performance Engineering (cp-e.com) | 109 | 05-13-2013 10:56 AM |
| venting to atmosphere | X lady killer X | CX-7 > Engine, Transmission & Driveline | 14 | 04-02-2011 10:28 AM |
