Like Tree13Likes
 Old 01-29-2013, 07:48 PM   #41
mdd5148's Avatar
Posts: 303   (View Stats)
mdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the world
Would consider their mani/dp option.
Also local and do not daily my car so could do test fitting.
2005 Porsche 911 - Pure Sex
Staggered 19" HRE P47's
2007 Mazdaspeed6 GT - #10318 - Sold
AWR Passenger Side Mount | AWR Transmission Mount | CPE RMM | CPE Intake | CPE Inlet | CPE Downpipe | CPE Catback | CPE Fuel Pump | CPE Manifold | TIAL 44mm Wastegate | Grimmspeed EBCS | Custom FMIC | HKS BOV | GT3076 | Cobb AP | Labonte Stage 2 meth | TWM Stage 2 Short Shifter | VEI boost gauge | CPE Tow Plate | LED Tail Lights | LED Mirrors | CX7 Antenna | 18x8.5 Rays Gram Light 57F
2006 Miata Sport - She took it...
Stock For Now...
mdd5148 is offline   Reply With Quote
 Old 01-29-2013, 07:51 PM   #42
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
poohster might be helping us out but ill let you know mike!!!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
mdd5148 (01-29-2013)
 Old 01-29-2013, 08:15 PM   #43
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I would be down for a kit like this, but never for 6k. Am i local? No, far from it hehe.
From what i understand this kit comes with HOTSIDE of the turbo, not the rest of the turbo?
Anyway im very interested
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 01-29-2013, 08:21 PM   #44
Must Have Teh 10's!
comes with turbo, DP, manifold, TIP, oil/coolant lines, big MAF, EWG.
MazdaSPEED3 Atmosphere? Turbo Kit | Custom Performance Engineering
SpeedRebirth (01-29-2013)
 Old 01-29-2013, 08:28 PM   #45
stuntz89's Avatar
Posts: 169   (View Stats)
stuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the world
Curse both my nervous pockets.....and my distance from cpe
#3527. On genpus for winter >=)
5zigen Hyper 5ZR for summer
Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ...
Tune in progress 8)
im on my way
h
stuntz89 is offline   Reply With Quote
 Old 01-29-2013, 09:06 PM   #46
Groans: 33
Thanks thats great!!
Would it be possible to add a cat? Wont pass the emissions without one (dont even know if i will with my current CPE DP). Would be a PITA if i had to change setup
Mazdaspeed6 -06
290 AWHP / K04
 Old 01-29-2013, 09:08 PM   #47
Must Have Teh 10's!
PM sent mike
 Old 01-29-2013, 09:15 PM   #48
Groans: 33
Also, i have a discount on "my next purchase" due to the problems i had with cpe delivery and quality control. Would that apply on a pre-order?
Mazdaspeed6 -06
290 AWHP / K04
 Old 01-29-2013, 09:19 PM   #49
Must Have Teh 10's!
im sure something can be worked out!!!
 Old 01-30-2013, 02:38 PM   #50
cletusb's Avatar
Posts: 488   (View Stats)
I'm waiting on this kit too, I'm no use for test fitting being in Australia tho
Also interested (need) catted dp for emissions although I guess I could always get on welded in locally
 Old 02-13-2013, 05:00 PM   #51
Groans: 33
My monies are screaming for this kit to be released NOOOW!!!
Mazdaspeed6 -06
290 AWHP / K04
 Old 02-13-2013, 05:12 PM   #52
Must Have Teh 10's!
i am currently working with @mdd5148; to get this kit together!!!
we should see results in 3-4 weeks!!!
BrianB6 (03-06-2013), cletusb (02-14-2013)
 Old 02-13-2013, 05:47 PM   #53
Groans: 33
Sounds awesome!!
Good job getting cool stuff like this out there
Mazdaspeed6 -06
290 AWHP / K04
superskaterxes (02-13-2013)
 Old 02-17-2013, 07:40 PM   #54
Speedie6's Avatar
Posts: 1,838   (View Stats)
Basically, the part that is missing is an MS6 compatible DP, right? Everything else you could get right now, and have a custom fabbed DP, no?
Basically, I already had a DP fabbed to match my Steedspeed manifold. But, I'm probably going to have to start from scratch on that, get it fabbed again to match the CPE manifold, or wait for them to release one.
 Old 02-18-2013, 03:08 AM   #55
cletusb's Avatar
Why I was looking at the kit and I assume will be different to the MS3 kit is the...
Wastegate coolant lines
Oil circulation lines
Necessary gaskets, screws, clamps, couplers, and fittings
that are included
 Old 02-18-2013, 06:29 AM   #56
Must Have Teh 10's!
the oil drain line and coolant drain line will be different along with the DP.
we should be getting mikes car in this weekend for fitment so stay tuned!!!
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
cletusb (02-18-2013), Poohster (02-18-2013), SpeedRebirth (02-20-2013)
 Old 02-26-2013, 09:35 AM   #57
Must Have Teh 10's!
so just a little update for you guys,
mike dropped his car off this past weekend so @RichieRichness; and i went to CPE yesterday to put a nice base tune on the car. We will use this to compare the two setups by doing an after-kit dyno to show the gains/advantages of switching to this kit.
here are some teaser picts of the custom drain line from software rendering to 3D printing to check for fitment before production.
BoominChu likes this.
The Following 7 Users Say Thank You to superskaterxes For This Useful Post:
cletusb (02-26-2013), Downmented (02-26-2013), mdd5148 (03-01-2013), RichieRichness (02-26-2013), sidekick (02-27-2013), SpeedRebirth (02-27-2013), The Panda (03-01-2013)
 Old 02-26-2013, 02:09 PM   #58
cletusb's Avatar
Thanks for the update. Can't wait to see the results.
What turbo will be used on the kit you and rich tuning?
 Old 02-26-2013, 06:20 PM   #59
Must Have Teh 10's!
mike has a GT3076
 Old 02-28-2013, 01:23 AM   #60
cletusb's Avatar
Awesome. Interested in seeing the spool with the whole set up. I'm tossing up between the 3071 - 3076 turbos
I pretty much have money waiting assuming there is a decent intro price :-)
 Old 02-28-2013, 03:06 AM   #61
Groans: 33
^^ Same here! 71 or 76... been thinking about it for a loooong time now
Mazdaspeed6 -06
290 AWHP / K04
 Old 02-28-2013, 02:21 PM   #62
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
I feel as if you have a MS3 you go 3071 if you have a MS6 you go 3076
The Following 2 Users Say Thank You to Jh8909 For This Useful Post:
Downmented (03-01-2013), SLOWHATCH (05-10-2013)
 Old 02-28-2013, 02:27 PM   #63
shadesofgray19's Avatar
Posts: 794   (View Stats)
GTX3576 is what you want.
The Following User Says Thank You to shadesofgray19 For This Useful Post:
Voltwings (02-28-2013)
 Old 02-28-2013, 02:40 PM   #64
Jh8909's Avatar
Groans: 130
I've thought about it before. Would rather set the 3076 on kill mode though.
 Old 02-28-2013, 02:57 PM   #65
Highestrich4's Avatar
Posts: 259   (View Stats)
Highestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond reputeHighestrich4 has a reputation beyond repute
Groaned at 7 Times in 2 Posts
will this require the changing of internals? pistons and rods?
2006 ms6 titanium grey - sold
2006 ms6 liquid platnium - Sold
Tmic, Intake, Inlet pipe, Test Pipe, BPV, H.I.D. Fogs, Cobb Ap
2006 ms6 velocity red mica - daily driver
2005 c6 corvette black - daily driver
Highestrich4 is offline   Reply With Quote
 Old 02-28-2013, 07:01 PM   #66
Must Have Teh 10's!
not if you dont want to. depends on how much power you want to make on the stock block.
 Old 03-01-2013, 02:09 AM   #67
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Man I wish i would have had the money to when this was offered...
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
 Old 03-01-2013, 05:11 AM   #68
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Dafuq? Future and past tense?
 Old 03-01-2013, 05:27 AM   #69
Must Have Teh 10's!
i think he means he wishes he could have bought it when it was sold at the intro price.
 Old 03-01-2013, 05:31 AM   #70
Fatguy729's Avatar
Groans: 82
Ah... For the 3.... I was confused considering the kit doesn't even exist yet!
Him < reading comprehension. This is not a fail wheel drive thread.
The Following User Says Thank You to Fatguy729 For This Useful Post:
sidekick (03-08-2013)
 Old 03-01-2013, 08:11 PM   #71
The Panda's Avatar
Broski I also own a ms6 I knew about the kit for the ms6 for awhile. Now as I am local to cp-e
2011 BLACK MS3
 Old 03-06-2013, 04:47 AM   #72
Groans: 33
How's that production coming along?
Mazdaspeed6 -06
290 AWHP / K04
 Old 03-08-2013, 11:55 AM   #73
Must Have Teh 10's!
so close guys!!!!!!
the entire kit should be complete by the end of next week for @mdd5148; and i. After that they just need to start cranking out a few DP's and fittings to get some kits on the shelf. Is anyone ready to purchase this thing ASAP? if so send me a PM
BrianB6 (03-08-2013), mdd5148 (03-08-2013), SpeedRebirth (03-08-2013)
 Old 03-08-2013, 12:27 PM   #74
mdd5148's Avatar
Looking forward to see how the tial housing spools compared to the atp
Stock For Now...
 Old 03-08-2013, 12:35 PM   #75
Must Have Teh 10's!
the more i read about it the more i believe that we're not actually going to loose any spool because it flows so well lol
 Old 03-08-2013, 12:59 PM   #76
sidekick's Avatar
Posts: 3,093   (View Stats)
so close guys!!!!!!
Why did you think you were going to spool slower with this kit?
CPE offered this kit to me and it was really fucking hard to say no. Lol. If I had the money, I'd be all over this. It makes life so easy when everything just bolts up...
 Old 03-08-2013, 03:08 PM   #77
aviator79's Avatar
Posts: 3,934   (View Stats)
Great time to be unemployed...
sidekick likes this.
 Old 03-08-2013, 03:39 PM   #78
robertof's Avatar
Posts: 405   (View Stats)
robertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the world
or to recently have had twins...
robertof is offline   Reply With Quote
 Old 03-08-2013, 03:59 PM   #79
so close guys!!!!!!
Intro price like the MS3 kit when it was released?
 Old 03-08-2013, 05:28 PM   #80
Must Have Teh 10's!
some more teasers!!!
a quote from cpe:
Here are some pics of our prototype DP. Keep in mind this is strictly a prototype, and is obviously not driveable. The final one will be one piece mandrel bent with welds at the flexes, the flanges, and where the wastegate tube meets the DP. The cut in the middle is not going to be the final downpipe. It was only there so that we could be sure that we were getting the correct rotation at the exhaust end, and then we tacked it.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
ASHMS3 (03-11-2013), BrianB6 (03-21-2013), magicka (03-09-2013), Poohster (03-08-2013), SpeedRebirth (03-08-2013)
CP-E Atmosphere Turbo Kit 08.5MS3 Custom Performance Engineering (cp-e.com) 126 02-26-2013 05:55 AM
venting to atmosphere X lady killer X CX-7 > Engine, Transmission & Driveline 14 04-02-2011 10:28 AM
Page generated in 0.55704 seconds with 34 queries
