> Cobb Tuning >
Cobb Access Port/Maps
  • 1 Post By Vansquish
 Old 02-17-2016, 07:23 PM   #1
Passon13's Avatar
Posts: 102   (View Stats)
Passon13 is a name known to allPasson13 is a name known to allPasson13 is a name known to allPasson13 is a name known to allPasson13 is a name known to allPasson13 is a name known to all
Groaned at 8 Times in 4 Posts
Default Another "which map should I run"
I know you guys probably get this all the time. But I have my AP installed and running a stage one 93 on stock everything except bpv,test pipe, and MAZDASPEED CAI which I believe is 2.75 in diameter.
I have my internals, one step spark plugs, rmm, 3inch tmic at the house. And waiting for my atp down pipe to come in in a week (on back order). Did some logs, right now holding 1600-1700psi on fuel at 16-18psi on boost. I plan on installing all at once, I will be using stock catback, is there an ots map from my ap I can run with all that until I get a custom tune? All stage 2 I see says I need tih (which the previous owner may have put in, haven't checked yet) and says I need an upgraded catback. Any suggestions? Sorry for the long read!
Passon13 is offline   Reply With Quote
 Old 02-18-2016, 07:29 AM   #2
Tifosi42's Avatar
Posts: 179   (View Stats)
If you want an OTS before getting a full tune get an OTS map from Freektune or Stratified, $75 & $50 respectively. These maps will be dialed to your exact mods and be safer than the COBB OTS. I wouldn't waste any time putting those fuel pump internals in either, that is your key to success or failure, Gen 1 cars aren't as picky as Gen 2, but still.
BNR S3 - FREEKTUNED on E33
 Old 02-18-2016, 07:49 AM   #3
Passon13's Avatar
Thanks for the help! A buddy used freektune so I might do that. Putting the internals couldn't hurt could it?
 Old 02-18-2016, 09:02 AM   #4
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Ummmmm...put the internals in. Do not put on the TMIC or the DP without them, the more airflow you have the more fuel you need and right now, your fuel pump is pretty close to maxed out (it doesn't take a lot with these cars, gen 1 or gen 2). +1 for the tuning recommendation though. -7184 on internals advice.
The Following 2 Users Say Thank You to Bingo For This Useful Post:
robbspeed (02-18-2016), Vansquish (02-18-2016)
 Old 02-18-2016, 09:13 AM   #5
Tifosi42's Avatar
I guess I should have worded it differently. How bout, you're stupid if you don't put your internals in immediately, that's what I meant by not wasting any time and getting them in ASAP. Freektune is great, you won't regret it.
 Old 02-18-2016, 09:24 AM   #6
Bingo's Avatar
Ah ok, ya that is a bit ambiguous. +7185 for internals advice
 Old 07-22-2019, 06:40 AM   #7
karim3400's Avatar
Posts: 2   (View Stats)
karim3400 has a little shameless behaviour in the past
karim3400 is offline   Reply With Quote
The Following User Says NO Thank You to karim3400 For This Un-useful Post:
Vansquish (07-22-2019)
 Old 07-22-2019, 07:16 AM   #8
Police - Grammarhead
Vansquish's Avatar
Like I said, go look at COBB's website. There are map notes including mod requirements for every single OTS map they offer.
Jeff23spl likes this.
 Old 07-22-2019, 09:05 AM   #9
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
but when looking at a tune that would work, you need to know what could really make a change.
On top of the list is the air intake size where the maf is installed that must match the tune because it drives everything else.
Exhaust: you can play around having any sort of catback and it won't change enoughn to be out of range but as soon as you get a down pipe or you reduce the restriction there, the turbo wastegate tables must account for the changes or you will overboost cut and/or break your engine. (This also include HPFP upgrades requirement)
IC setup can play in the game too but it won't drive you near of a towing as much as the above.
I won't say a tih wont change anything but the map will work fine if you don't change it.
Your tuner won't bother about motor mount, bpv (as long as it is a bpv) and other parts that doesn't change engine power.
Fuel pressure will likely read ok during hot summer days because you need less fuel but it is useless for how it will react on cold weather...unless you check it each time you get wot, you'd better change the internals....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-24-2019, 06:50 AM   #10
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I've seen this type of activity a lot this past month. An account gets created and they copy and paste old posts.
Not sure if it's someone trolling or BOT activity?
Disgruntled ex-speed owner?
Subbie or Evo people getting their feelings hurt?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-24-2019, 07:16 AM   #11
Vansquish's Avatar
It's bot activity. I've been trying to get rid of them as they pop up, but it's a losing battle.
Report: Mitsubishi boss labels French minister a "retard" for "ruining the lives of motorists" Haltech Automotive News 0 10-25-2012 06:00 PM
LaHood: Getting Toyota to recall took "enormous effort," calls automaker "a little safety deaf" Haltech Automotive News 0 02-02-2010 06:10 PM
Page generated in 0.32297 seconds with 26 queries
