![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Hi all, I am new to the MSF and new to the Gen II Mazdaspeed 3 as I just picked up a used 2010 with 100k miles. Now this may be a noob question, but the car came with a Accessport and is running a stage 1+ sf 93v234 map. Now the car also looks to have a cp-e top mount, a cork sport bpv, and a cork sport air intake and turbo inlet house, cork sport cutback exhaust. I am not sure what else has been done to the car or if the fuel pump internals have been upgraded. I recorded some data logs and was just looking for some help to see if the tune currently running is ok, and what I could be running for maps instead. As I am new to the mazdaspeed 3, any help or ideas would be very appreciated. I want to make sure afr is safe, boost numbers are safe as I have seen spikes around 18psi, and the knock retard is ok. I know these are noob questions, and trust me I have spent countless nights researching data and safe numbers but I am still lost as the car came with this mods and I have no no way of contacting previous owner. |
![]() Join Date: Jan 2017 Location: Buffalo NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score Start reading. Check for HPFP internals. but with those mods, it probably already has them. google how to install HPFP and check yours ASAP. if you have them, you should be good. find a professional e tuner. Start reading. and most everything youll need is in your welcome PM.
__________________ 2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned 2011 mazda 6 |
| The Following User Says Thank You to danb For This Useful Post: | Meadman49 (09-18-2017) |
![]() Join Date: May 2014 Location: Bloomsburg PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
| Not Ranked : 0 score 1. Please research the proper way to datalog, the ones provided are atrocious. 2. Take your fuel pump internals out and check them as this is the only way to know for sure. 3. Get an OTS tune from Freektune or Stratified to hold you over until you get a full tune or just get a full tune. 4. Read more as all of this has been covered a lot.
__________________ BNR S3 - FREEKTUNED on E33 |
Thanks for the advice, I will check the internals, learn the right way to datalog, and check those OTS tunes. Planned on doing more research just didn't want to go zoom zoom boom before I could really figure everything out. | |
| Anyone running the Stage 3 Pistons? | chapy18 | Custom Performance Engineering (cp-e.com) | 0 | 01-06-2016 09:41 PM |
| Anyone running CP-e Stage 3 Pistons? | chapy18 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 01-04-2016 12:37 PM |
| Anyone running COBB AP stage 2 OTS | bbjoy | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 01-25-2014 08:19 PM |
| Anyone here running the BNZR stage 1? | platinum07 | Mazdaspeed3/6 General Discussion | 22 | 11-15-2010 05:02 PM |
| my dyno results running cobb ap stage 1 | GFish | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 18 | 02-10-2009 03:31 PM |
