![]() Join Date: Mar 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 510
Groaned at 7 Times in 5 Posts
__________________ BONE STOCK. |
| The Following 7 Users Say Thank You to 94jedi For This Useful Post: | aaronc7 (07-25-2008), boostjunkie (07-25-2008), FreeFlyFreak (07-25-2008), gamblore (07-25-2008), itzl0l (07-25-2008), Raglem (07-27-2008), skeeter149 (07-25-2008) |
Groans: 370
| Not Ranked : 0 score and stage 1 + SF FMIC! no stage 2 FMIC lol "1.02 - Further optimized boost control, and made power improvements in 1st through 5th gears. Increased ignition advance at higher RPM." |
![]() Join Date: Jun 2008 Location: Sarasota FL
| Not Ranked : 0 score are these the same maps hal posted ?
__________________ Z32 Specialist 07 Sport Cobb AP - V103f map Cobb Sri ETS 3.25 TMIC Vibrant Catted midpipeback exhaust Forge BPV CS inserts Dashhawk logger Soon to follow SSR Wheels and wider tires CS downpipe Check out http://ztuner.com/newdyno.htm |
(Thread Starter) | Not Ranked : 0 score no, these are official release maps for the general public
(Thread Starter) | Not Ranked : 0 score yea, I think they must be working on that....
![]() Join Date: Mar 2008 Location: Oklahoma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
| Not Ranked : 0 score Is it really a 15 percent increase or a 15HP increase?
__________________ Best to date - 13.802@104.16 (I/MP/MM/W) |
![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() Thanks: 5
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
| Not Ranked : 0 score Are these maps the same as the last beta maps or are there further changes. I don't want to flash if its not necessary
__________________ [SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC] 2007 ms3 sport black mica completely stock |
(Thread Starter) | Not Ranked : 0 score Christian emailed me and said that the MSCAI maps had boost pressure specifically raised compared to the 102c betas. He made it sound like the other maps were the same as the v102c's. He said he was especially interested in feedback from those with an MSCAI. He suggested I flash to the latest release map even though I had the v102c beta's.
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score You always refer to beta-c, but someone else was talking beta-e - typo? Whatever, if you think the 102 has better midrange than even the 101msf, I'm real curious to try it since midrange is what the 101msf is about mostly. |
| Not Ranked : 0 score sweet I will do that then. I was confused by his initial email.
| Not Ranked : 0 score Definately does have a better midrange, I am going to do some driving right now on the new map. By the beta c was for stage 1+ beta e was for 2+ to get more power up top.
| Not Ranked : 0 score just flashed to the 102 ms cai map and I got boost cut in second gear. I lost traction and then got boost cut. I did some more pulls and no more cut but I am spiking to 20 psi in second but it immediately drop to 16.X. Not sure about the other gears yet. My fuel trims still need to add a bit more fuel so this issue may have been a one time thing. usually after 100 miles any hiccups I have in the map get ironed out by the ecu so I am not worried about it. Just be careful until your car has time to learn.
| Not Ranked : 0 score Ah, okay, I was feeling for you having to load 5 beta maps |
| Not Ranked : 0 score Do you have a stock BOV? |
| Not Ranked : 0 score Switching maps does suck because the car always needs time to adjust and I usually get shitty gas mileage until the ecu works out the kinks.
(Thread Starter) | Not Ranked : 0 score same here. The first tank on a new map gets me 230~ miles(w/ lots of "map testing" type driving). After that, I can get 330 if I'm really nice lol.
![]() | | #19 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Dread, the v102 maps are they 'full throttle' as well? |
![]() | | #20 | ![]() |
![]() Join Date: May 2008 Location: Nashville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
![]() | | #21 | ![]() |
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
| Not Ranked : 0 score I really dont think they are or it would be in the notes i bet..
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn |
![]() | | #22 | ![]() |
| Not Ranked : 0 score I don't think they are full throttle, but you will notice that the map notes say boost only drops to 12 psi by redline, on the 101 maps it dropped to 8 psi.
![]() | | #23 | ![]() |
| Not Ranked : 0 score I haven't logged it, so I really don't know for sure.
![]() | | #24 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score I logged in the 2+ beta-c and it wasn't full throttle. |
![]() | | #25 | ![]() |
| MSF maps are only full throttle.
![]() | | #26 | ![]() |
![]() Join Date: Jun 2008 Location: Seacoast, NH
Rep Power: 0 ![]() Thanks: 8
| Not Ranked : 0 score Just curious - not intended to put any pressure on anyone - does this mean that there will be a new round of MSF maps coming out soon? I'm thinking ahead to track day on Aug 5, and would like to give the car at least a week to adjust before I beat the crap out of it. If MSF maps are imminent, I'll hold off on the Cobb stuff. |
![]() | | #27 | ![]() |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #28 | ![]() |
| Not Ranked : 0 score I haven't had anything fuel pump related done. Will that keep me from using the new MSF map? |
![]() | | #29 | ![]() |
| Not necessarily.. i tossed that out there because every car may be different. Last thing i want to see is someone screwing up the motor because they ran out of fuel.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score oh man...that's what I'll be waiting for. can you give us anymore map related updates Haltech? FMIC/TMIC Maps? Can we maybe expect a balls out FT Stg2+ SRI/MSCAI + FMIC/TMIC MSF map soon???
![]() | | #31 | ![]() |
| They will follow like the others, FMIC included... adding timing, tweaks to the wastegate solenoid, adding fuel down low, etc.
![]() | | #32 | ![]() |
__________________ BONE STOCK. | |
![]() | | #33 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Just installed the v102 maps. Took her out for a little drive afterwards. I hit 18psi in 2nd then it immediatley went down to 17.2. Boost stayed around 17psi for 3rd and 4th. Didnt have enough road to test 5th or 6th. My ltft stayed at 0 the whole time and my afrs were at 12.1 wot. Its a little lean but i bet it smoothes itself out after logging some miles on it.
__________________ 2008 CB ms3 : SU MM, Cobb SRI, AP, Twm bushings, cobb shifter weight, 20% tint269whp 299wtq |
![]() | | #34 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
| Not Ranked : 0 score been running the stage 1+mscai 102 all night....so far i like them, an improvement in every regard. ltft's are -1 at idle, 5 under light throttle, 3 under mid throttle-wot. Boost seems to spike a little high 19-20 then settles to 17ish. Id like to see less spike, when the car is hot it seems like it yanks timing when the boost spikes (however i show no knock), but it just feels a little "odd". The stock map seems to have less spike unless u really load the car up. Id like less spike. sometimes when i stand on it and the boost hits high, I'll get one pop out of the exhaust, not really a studder, and i show no knock, just one pop....some1 else mentioned this as well with the older maps, and i had it too and still do.
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+ |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Yeah I get that some times, and I get the boost spike as well if I floor it around 4k, but I am not holding 17ish in 4th still. Most of the time I am in the 15's. I am thinking the ms cai is holding the boost back still. The new map is pretty sweet though.
![]() | | #36 | ![]() |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
| Not Ranked : 0 score I read the map notes while I was loading the Stage2 + MSCAI. It says the boost targets are 18.2psi peak, tapering to 15.5psi @ 6700 rpm.
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle |
![]() | | #37 | ![]() |
| Not Ranked : 0 score I headed out tonight to check out the new RSB so loaded S1+ v102 just because. Didn't pay too much attention, but I noticed LTFT in cruise was a point less (-3 vs. -2) than a fresh msf map. At 6K WOT 4th gear timing is 11 vs 12 msf and 13 stock. The most interesting data was it seemed to hold boost longer before tapering at high rpm. Boost was maybe .5 higher, but holding it longer was cool. No knock retard that I noticed. I don't know if the v102 S1+ is FT or not and I officially don't care - it blows past 6K in 4th, so if it's not FT that's a good thing to me. It might have accelerated from sub-3K high gear situations better, but that's not really part of my driving style, just noting it. Maybe even more peppy in the midrange. 3rd gear felt stronger, but might be my imagination. It caught me by surprise though, so maybe something there. Overall, it feels like a natural progression form the msf map, definitely worth living with for awhile. |
![]() | | #38 | ![]() |
| Not Ranked : 0 score ok did some more driving....the boost spike i have is only in 3rd and its bad...if i floor it at 3k its about 20-21psi and i get 1-3 degrees of knock retard for just a monent then boost goes to 15-16. Floor it at 4k and 18-19 spike and no KR then boost goes to 15-16 Then if im a fool and load it up at 2.5k rpms i get 23+ psi, audible detonation (only did this once...eek). In 4th gear however i get ZERO spike at all from ANY rpm....it snaps to 17 holds for a moment and then goes to 15-16 and holds that till 6000 plus. WGDC in 3rd from 3k rpms is over 80%, but in 4th from 3k rpms its only 72-74% the map is trying WAY to hard to bring on boost quickly in 3rd stage 1+ mscai v102 ltft's are fantastic but....maybe i should try the SF map?
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+ Last edited by itzl0l; 07-25-2008 at 11:43 PM. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score some1 else see if they get a big initial spike in 3rd from 3k rpms..keep an eye on knock...make sure ltft's are established b4 hand too. i tried the stage 1 sf map and it does it too in 3rd....not as bad tho. All the maps have always had some spike, but i've never seen over 20 until now. oh yea...stock map...no spike...3rd gear 3k rpm's gas it and bam 15 then tapering off. Spools a little slower, but i dont like such a high spike on spool up.
![]() | | #40 | ![]() |
| Not Ranked : 0 score sub |
| 1/4 mile times on AP or MSF maps | rodrigo | Cobb Access Port/Maps | 230 | 08-04-2008 07:37 PM |
| I got the new AP maps for you! | Haltech | Cobb Access Port/Maps | 471 | 07-23-2008 02:32 AM |
| 101 maps are out | subparpunk03 | Cobb Access Port/Maps | 21 | 07-08-2008 02:58 PM |
| ap v101 maps | ms3boost | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 07-06-2008 01:54 PM |
| Where to get the updated maps? | Death-From-A-Mile | Cobb Access Port/Maps | 5 | 06-11-2008 07:19 PM |
