  • 1 Post By Haltech
 Old 06-06-2008, 06:16 AM   #1
Default Cobb Tuning Mazdaspeed 3 SF SRI - Short Ram Intake - Part 1: » Design 1: Velocity Stack
Table of Contents
1 - Cobb Tuning Mazdaspeed 3 SF SRI - Short Ram Intake - Part 1:
2 - Design 1: Velocity Stack
3 - Design 2: Air Straightener
4 - Design 3: MAF Housing Material
5 - Design 4: MAF Sensor Housing
At first glance, it appears to be a simple intake piece. We are all familiar with the assortment of intakes out for the Mazdaspeed 3 today. Some of the intakes on the market today are considered half baked concepts. The inside diameter of these MAF housing vary among intakes. Some, have been known to cause lean conditions within the ECU and created an assortment of driveability issues or MIL codes, which illuminate on your instrument panel. Some of them are just plain junk and are avoided among the community.
So what makes Cobb's so much different than everyone else? Well, if we look back at the 60's, a lot of top hot rodders used velocity stacks in their carburetors to smooth the incoming air. A velocity stack is a usually cylindrical tube of some type with a radiused inlet end device. When this device is added onto the air entry location or locations of an engines intake system, it will:
  1. Allow smooth and even entry of air into the intake duct with the flow streams boundary layer adhering to the pipe walls
  2. Modify the dynamic tuning range of the intake tract by functioning as a small reverse megaphone which can extend the duration of pulses within the tract
  3. Alter the dynamic tuning speed (dynamic engine compression) if the overall length is changed thereby changing the tuned length to a lower or higher rpm.
Look at the below image as an example how the Cobb SF SRI works to smooth incoming air into the MAF housing.
The next image below shows you an example of how air enters typical intakes.
Cobb's velocity stack:
Next Up: Air Straighteners, Build Material & MAF Sensor Housing
« Back 1 2 3 4 5 Next»
Juyoung likes this.
The Following 33 Users Say Thank You to Haltech For This Useful Post:
2008MS3H (11-09-2011), 3ONBOOST (08-29-2008), aaronc7 (06-06-2008), badams118 (06-17-2008), BlackMS3 (06-06-2008), cookieheadjenkins (03-15-2010), Detox_MS3 (02-15-2013), dkswim (06-14-2008), doubleflusher (02-18-2009), evidence01 (06-18-2008), FastAttack (06-13-2008), jahman (06-07-2008), Jayp (09-03-2008), jtspells (06-07-2008), KaiserSoze (06-08-2008), Ketchup (06-11-2008), killyoutoo (06-11-2008), kingpin748 (06-06-2008), kyspeed3 (06-27-2008), MadOzodi (06-08-2008), MazdaMan13 (06-06-2008), Micha (08-03-2011), neotide87 (06-16-2011), norcalcrx (02-08-2009), NYpest (06-06-2008), reddevil (08-07-2008), Renzokuken (06-18-2008), SLS MS3 (06-06-2008), thajones (06-30-2008), thejake (06-06-2008), vdgmcool (04-15-2011), Veet Voojagig (06-18-2008), xSP33Dx3x (06-15-2008)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f337/cobb-tuning-mazdaspeed-3-sf-sri-short-6375/
Cobb Tuning Mazdaspeed 3 SF SRI - Short Ram Intake | Kevin Pugh This thread Refback 11-08-2011 07:36 PM
Cobb Tuning Mazdaspeed 3 SF SRI - Short Ram Intake | Kevin Pugh This thread Refback 08-25-2011 06:49 PM
Cobb Tuning Mazdaspeed 3 SF SRI - Short Ram Intake | Kevin Pugh This thread Refback 12-20-2010 05:28 PM
Cobb SF SRI Intake Review - Autos - Cars This thread Refback 11-27-2010 05:20 PM
mazda3quebec.com - Sites Linking in - from Alexa This thread Refback 12-26-2009 02:36 AM
COBB AccessPORT for 2006-2009 Honda Civic Si Available NOW! - Page 21 - 8th Generation Honda Civic Forum This thread Pingback 06-10-2009 12:06 PM
Mazda3Québec.com • Voir le sujet - un switch pour une speed 2008.5 This thread Refback 08-12-2008 04:33 AM
Mazda3Québec.com • Voir le sujet - un switch pour une speed 2008.5 This thread Refback 08-11-2008 10:03 AM
Mazda3Québec.com • Voir le sujet - un switch pour une speed 2008.5 This thread Refback 08-11-2008 09:16 AM
Talk me out of a MazdaSpeed3 - The Something Awful Forums This thread Refback 07-22-2008 09:33 PM
Talk me out of a MazdaSpeed3 - The Something Awful Forums This thread Refback 06-12-2008 02:47 PM
Talk me out of a MazdaSpeed3 - The Something Awful Forums This thread Refback 06-11-2008 11:38 PM
Talk me out of a MazdaSpeed3 - The Something Awful Forums This thread Refback 06-10-2008 12:24 PM
Talk me out of a MazdaSpeed3 - The Something Awful Forums This thread Refback 06-10-2008 12:14 PM
COBB SRI Dyno. - COBB Forums This thread Refback 06-07-2008 11:14 PM
COBB SRI Dyno. - COBB Forums This thread Refback 06-07-2008 01:19 PM
COBB SRI Dyno. - COBB Forums This thread Refback 06-07-2008 12:20 PM
COBB SRI Dyno. - COBB Forums This thread Refback 06-07-2008 12:11 PM
Cobb Tuning FMIC justin. MazdaSpeed 3/6 - ECU Computer Tuning 230 11-07-2019 07:48 PM
DIY Short Ram Intake billyrohm MazdaSpeed 3 - How-To's 63 05-10-2012 09:24 AM
how NOT to install a TWM Short throw shifter CMESCOOT MazdaSpeed 3 - Engine, Transmission & Driveline 20 04-01-2008 09:06 AM
Page generated in 0.26033 seconds with 20 queries
