Like Tree21Likes
 Old 05-01-2014, 01:38 PM   #41
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
Thanks for posting your experiences everyone. I really like the initial bite of the OEM pads. I do not track my car so I don't really notice much brake fade. I will probably just stick with OEM pads when I'm ready to replace them. I am hesitant to put metal break lines on my car because I live in Vermont and they salt the fuck out of the roads in the winter. I've read about stainless braided lines rusting to shit in this kind of weather and then leaking, which completely defeats the purpose of getting them.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
 Old 06-09-2014, 10:49 AM   #42
RedMS3's Avatar
Posts: 46   (View Stats)
RedMS3 will become famous soon enoughRedMS3 will become famous soon enough
Thanks for the review...
RedMS3 is offline   Reply With Quote
 Old 06-10-2014, 07:46 AM   #43
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I kinda forgot about this thread. With the braided lines the initial bite is better but still not up to oem levels.
Sent from my gs5
Damond Built Speed 6
 Old 06-13-2014, 11:16 PM   #44
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I don't think you can get fade resistance and OEM bite at the same time. The better initial bite means that the brake pad material has some softer compounds that will grip better at lower temps but will tend to expand and/or liquefy above some temperature threshold.
So not liking a high performance brake pad (CS or any other) for not having OEM-like initial byte is like not liking the mazdaspeed3 for not providing Mazda 3 1.6 litre - like fuel economy IMHO.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-13-2014, 11:38 PM   #45
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
I have the hawk hps pads, and while the soft initial bite doesn't bother me too much, it's the fact that people look around for the bus that's stopping next to them, hell I'm pretty sure I have had bus drivers look at me like damn those are loud. Now the occasional pad resurface does help it doesn't make it go away completely. Might try these next.
The Following User Says Thank You to Hargarbl For This Useful Post:
Worbit (01-13-2016)
 Old 06-14-2014, 08:08 AM   #46
someguy's Avatar
Posts: 914   (View Stats)
I never had issues with noise on hps pads...did you slather the back anti-squeal? It seems to shut them up pretty well.
On the Corksport pads front...wow do they ever dust less than OEM, I can go a week or two without the brake dust turning my wheels black.
 Old 06-14-2014, 08:21 AM   #47
Hargarbl's Avatar
Groans: 51
Yeah, I put anti squeal on the back. I think my biggest problem is I am hard on my brakes, I have managed to get 1 or 2 heat spot on my powerslots.
 Old 06-15-2014, 01:41 AM   #48
mituc's Avatar
Groans: 111
The problem is not that you're hard on the brakes, the problem is that probably you're braking incorrectly - meaning you are bringing the car to a stop while maintaining a good amount of pressure on the brake pedal. Well, no!, this is exactly how you create heat spots on the disks.
Brake in any way you like but do it sooner so that 1-2 meters before the stopping point you can release the brake pedal almost completely. The passengers will also thank you.
On the track there's a totally different story as you never bring the car to a complete stop after braking hard.
 Old 06-15-2014, 02:00 AM   #49
Hargarbl's Avatar
Groans: 51
I do do that to let them cool a bit before coming to a complete stop, also lifting off the brake pedal when coming to a complete stop is also a good idea, it releases the pressure, and as always pressure = heat. Also I rarely drive hard with anyone else in my car.
 Old 06-15-2014, 02:38 AM   #50
WA_MS6's Avatar
Posts: 459   (View Stats)
Got these on my MS6. Great buy for the money! I have seen zero brake dust since the install and we all know how brake dust makes the stock wheels look...
 Old 06-17-2014, 08:18 AM   #51
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Uh yes you can. Corksport pads were just terrible. They aren't high performance pads, they are ceramics. Great for if you're trying to keep your wheels clean...but that's about it.
Slap on an aggressive street pad or light track duty pad and tell me how the first sentence holds up.
I have HP+. Squeal like no other dump truck you've heard, but they can stop one too, whether they are cold or hot.
I also believe the EBC yellow's might match the initial bite of oem. I'm sure if you can get some porterfield r4s' the same, or carbotch ax6's, the same result
Scoupe likes this.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
phate (06-17-2014), smurugby12 (06-20-2014)
 Old 06-17-2014, 01:05 PM   #52
Jason43's Avatar
Posts: 310   (View Stats)
Jason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the worldJason43 is the leader of the world
Groaned at 7 Times in 5 Posts
Neutral  +1 score
I run EBC yellows. Once hot, they do have damn near the bite of OEM.
Scoupe likes this.
2010 LSM
e85|cs intake/tip|cp-e tmic|internals|catless dp|magnaflow cb|forge bpv|cs rmm/inserts|cs springs|damond shift plate|ap|cs front lip|freektune|stuff...
Jason43 is offline   Reply With Quote
The Following User Says Thank You to Jason43 For This Useful Post:
86AmishMs3 (06-18-2014)
 Old 06-28-2015, 07:02 PM   #53
Jetfire's Avatar
Posts: 39   (View Stats)
Jetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to behold
HP+ are what I am running and my god have they saved my ass a few times. No fade ever. That being said they practically scream at you for trying to stop.
Jetfire is offline   Reply With Quote
 Old 01-13-2016, 11:46 PM   #54
Worbit's Avatar
Posts: 2,552   (View Stats)
Worbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the world
Groans: 142
Groaned at 58 Times in 37 Posts
shit, I am torn as to what pad I should get and this thread has made it even harder for me to make up my mind
Zoom-Zoom-Coons on 05/10/16
2011 Mazdaspeed3 Celestial Blue Mica
BUILT BY CORKSPORT
CP-e Catted Downpipe || CP-e HPFP || Corksport Turbo || Corksport 3-bar Map Sensor || Corksport EBCS|| Corksport SRI || Corksport TIP || Corksport CBE || Corksport Boost Cut Killer || Corksport FMIC || Corksport SSP || Corksport MM Inserts || Corksport Blue Shift Knob || Corksport Injector Seals || DM Full EGR Delete Kit || Corksport License Plate Relocation Kit || Snyapse Engineering Synchronic BOV || Cobb V3 Accessport (PD Tune in progress)
Worbit is offline   Reply With Quote
 Old 01-14-2016, 12:33 AM   #55
EvoFire's Avatar
Posts: 389   (View Stats)
If you are looking for bite, don't get these pads. They are very very nice on the rotor though, my rotors barely show any wear, and they almost do not dust at all.
I would say SS lines are almost a must and a flush will be mandatory, and even then it'll take you some time to get used to them coming from stock pads.
I have not been to the track so I can't comment on fade resistance.
 Old 01-14-2016, 08:18 AM   #56
Worbit's Avatar
Groans: 142
well I dont track so I went ahead and bought these. Should I bother with the SS lines if this is just my DD for carting around town?
BUILT BY CORKSPORT
 Old 01-14-2016, 08:52 AM   #57
EvoFire's Avatar
It's mostly about how the brakes feel, made a big difference for me when I did it even just on the street. Ultimately you can still stop without them, but you may feel more confident about your brakes if you do the whole shebang.
Did you just get the front pads or all 4? The MS3 is very front biased in terms of brakes, with just the front CS pads it balances out the brake bias a little and wears the rears a little bit more than before.
PS: I noticed you are selling your car, just wondering how worn were the brakes and why didn't you just wait until it was sold and let the new owner decide what brakes to get?
 Old 01-14-2016, 10:50 AM   #58
Worbit's Avatar
Groans: 142
I'm getting new brakes since I drive the car daily and I'm really not in a rush to sell it anymore. If I find a buyer, cool. If not, I might try and bring it to Japan with me in a month or two. I ended up buying these since the brake dust wasn't a real issue. My current OEM set makes it look like I did the shittiest spray job with plasti-dip.
BUILT BY CORKSPORT
 Old 01-14-2016, 09:22 PM   #59
EvoFire's Avatar
Should really pick up whatever weird machinery you find in Japan and bring that back with you instead of shipping the MS3 over.
The Following User Says Thank You to EvoFire For This Useful Post:
Worbit (01-19-2016)
 Old 01-19-2016, 05:32 PM   #60
Worbit's Avatar
Groans: 142
I'm torn, I abosolutely love what Corksport has done to this car and would love to keep a LHD in Japan, but then again finding something like a Cosmo would be awesome (and from what I hear these are semi-common over there)
In other news, I got my brakes in yesterday! Everytime I order something from Corksport I always leave a math problem in the comments box and ask them to show their work. So far they (Vincent) have yet to fail me
QUESTION:
There was a party and everyone shook everyone's hands. There were 66 handshakes!! How many people were at the party?
BUILT BY CORKSPORT
The Following User Says Thank You to Worbit For This Useful Post:
prosper0 (01-21-2016)
 Old 01-19-2016, 05:52 PM   #61
#theydidthemath
sent from my Nexus 6P
CorkSport Vincent likes this.
Worbit (01-19-2016)
 Old 08-08-2017, 04:59 PM   #62
Coltzxli's Avatar
Posts: 45   (View Stats)
Coltzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to behold
Did corksport discontinue this line? Dont see it on their site
Coltzxli is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f337/corksport-brakes-pads-mazdaspeed-3-a-145381/
What brake pads are recommended - Page 3 - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 01-09-2014 09:44 AM
Meilleur front brake pads pour speed - Mazda 3 Quebec This thread Refback 10-01-2013 06:40 PM
OEM vs CS Brake Pads This thread Refback 05-15-2013 09:28 AM
Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads CorkSport CorkSport 54 03-07-2014 07:50 PM
Replaced front pads - squeal when I let off brakes?? TheRealDefman 2010 MS3 - Suspension & Brakes 0 02-27-2013 09:01 PM
Page generated in 0.42095 seconds with 34 queries
