| Mazdaspeed Forums Performance Parts Reviews Mazdaspeed Forums takes a look at performance parts aimed for you Mazdaspeed vehicle. These are honest, thorough & unbiased reviews based off a manufacturers products. |
8Likes ![]() |
(Thread Starter) | Neutral : +1 score As many of you know, @Turbo_Steve; has been playing with fabrication of parts for us. He's also working to get vendor status here, and this thread will move there once established. I have received and installed the covers. These are aluminum panels that were powder coated wrinkle black. Initial review was of packaging. Packed nicely and no scratches. Both coated panels were plastic wrapped. Then they were wrapped in enough material to keep it immobilized in the box. Color instructions are nice and ended up easy to follow. ImageUploadedByTapatalk1445538636.777309.jpg ImageUploadedByTapatalk1445538672.526823.jpg ImageUploadedByTapatalk1445538681.264588.jpg For the install, total time was 15 minutes including pics and backing out my car. Before ImageUploadedByTapatalk1445538730.189556.jpg ImageUploadedByTapatalk1445538747.448093.jpg ImageUploadedByTapatalk1445538757.303077.jpg Because my piping is protege garage v1, it's own fitment is pretty much butthole. But I was able to remove the coil pack bolts without removing the hot pipe. ImageUploadedByTapatalk1445538839.278240.jpg Hardware consists of Allen bolts, a washer, a spacer, and a little rubber o-ring that just holds it in place for install which is great, when all 4 are hanging prior to install. ImageUploadedByTapatalk1445538907.862742.jpg ImageUploadedByTapatalk1445538980.715896.jpg ImageUploadedByTapatalk1445538991.987866.jpg Installed quickly. I slid into place, lining each bolt with the coil pack prior to tightening any. ImageUploadedByTapatalk1445539096.374563.jpg ImageUploadedByTapatalk1445539162.299217.jpg Hpfp was cake too. Same thing as before. Remove bolts, put plate and hardware on. This one used 2 spacers, but the little o-ring kept it right. Installed in a couple minutes. ImageUploadedByTapatalk1445539238.520808.jpg Fitment was spot on. I bet others will have a lot more clearance than I do. ImageUploadedByTapatalk1445539271.520627.jpg Covers the coil mess and looks clean. Not sure if this counts as another modification I have installed, but I'm claiming it. 6 now. ImageUploadedByTapatalk1445539345.326103.jpg ImageUploadedByTapatalk1445539356.279938.jpg ImageUploadedByTapatalk1445539377.841112.jpg Look for @Turbo_Steve; to be a vendor soon under Adapted Performance. |
| The Following 19 Users Say Thank You to Raider For This Useful Post: | Boost_creep (10-31-2015), Code Monkey (10-22-2015), dale_gribble (10-22-2015), DevinS (12-23-2015), Easter Bunny (10-22-2015), Finchee (11-06-2015), ItsNox (10-27-2015), John596 (04-08-2016), Justin@Freektune (10-24-2015), macdiesel (10-22-2015), Mauro_Penguin (10-22-2015), monkey.bones.007 (10-22-2015), robbspeed (11-28-2015), Scare Dem (10-22-2015), SofaKingAwesome (10-22-2015), therapist510 (10-23-2015), ToyCop (01-15-2016), Turbo_Steve (10-22-2015), Zoom66 (10-22-2015) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score Looks good! Nice writeup. Only sad part is the mazdaspeed logo is partially covered with this charge piping. I will offer versions with no logo cutout as well & lots of color options. Thanks!
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post: | DingoDave (12-05-2015), Easter Bunny (10-22-2015), ericrapp0507@gmail.com (06-16-2016), ItsNox (10-27-2015), jcolton (02-10-2017), Mauro_Penguin (10-22-2015), Raider (10-22-2015), Zoom66 (10-22-2015) |
(Thread Starter) | Not Ranked : 0 score The MPS logo would be badass too, or just blank. I am sure other piping kits wont be as suckballs as my kit. |
| The Following User Says Thank You to Raider For This Useful Post: | Turbo_Steve (10-22-2015) |
![]() Join Date: Aug 2013 Location: Bartlesville, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
| Not Ranked : 0 score Need me one of those sets in red with the mazda speed logo. It will be easier to install on mine with the fmic piping routed under the engine. This looks really good.
__________________ 2013 MS3 Velocity Red - FLOW Tuned 25% E85 Mods - GTX2867R Turbo, Snow Meth Kit, Forged Manley Platinum pistons and Rods, Matt Dammond Balance Shaft Delete, Southbend Stage 3 Clutch, SPerformance Aux Fan Controller, 4" HTP Intake, Greddy FV BOV, Stratified Guardian Angel V2, Cobb AP V3, Tanabe Strut Tower Brace, Magna-flow CBE, HPFP Autotech Internals, CorkSport Shifter Bushings, CorkSport short throw shifter, CP-e Stage 2 RMM, CP-e Catless Downpipe, QTP Electric Exhaust Cutoff, NGK one step colder plugs, Cobb 3-port EBCS, Whiteline FSB, EBC 3GD Slotted Rotors, Hawk HPS Brake Pads, Goodridge Stainless Steel Brake Lines, HTP Small Battery Box, 51R Optima Yellow, SPC adjustable Rear Camber Arms, KW Variant 3 Coilover setup, Matt Dammond Passenger and Transmission mounts, Falken Azenis tires (street use), Defi Boost Gauge, AEM UEGO Wideband Gauge, AEM Water Temperature Gauge, AEM Oil pressure gauge, Corksport Short Shifter, Apexi Turbo Timer, Corksport Skid Plate, Threadstone TR8 core and crash bar, DOCRACE exhaust manifold, Reletnless Customs Ported IM, JBR 250 Competition Rear Sway Bar, Kuhmo V710 on RX8 wheels (track use), Matt Dammond OCC (VC and intake), Speed Performance Vented Oil Cap, Rice - 20% tint, Morimoto HID kit, Retrofit High Beams, Morimoto projector clear lenses, Corksport Hood Strut Kit, Corksport eyelids color matched, Ebay rear spoiler extension, Morimoto RGB Halos, LED Red Evil Eye, VG Shark Fin Antenna, Coil Cover, Blue Vacuum Hoses, Morimoto LED low beams, Cover King custom Seat Covers |
![]() Join Date: May 2012 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score I need one in MattDamond gold. looks good
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score That is sweet.
__________________ 2013 'speed3, silver Stage Bro |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Is it possible to do a smaller mazdaspeed logo and align it to the left? Looks great though.
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! | |
| The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post: | Easter Bunny (10-24-2015), ericrapp0507@gmail.com (06-16-2016), macdiesel (10-22-2015), Mauro_Penguin (10-22-2015) |
![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Wow those really look good for engine dress up I like them but the only problem is that those of us who have TMIC won't get the benefit of this nice piece of work! Great work Steve!
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
(Thread Starter) | Not Ranked : 0 score I do want to follow up that it passes the wheel hop/spin test with the JBR high duro trilogy mounts. Had some fun, wheels spun, a little hop in 2nd and no banging heard or damage seen after. |
| The Following User Says Thank You to Raider For This Useful Post: | Turbo_Steve (10-28-2015) |
| Banned ![]() ![]() Join Date: Jun 2011 Location: Boston, MA
Groaned at 212 Times in 84 Posts
| Not Ranked : 0 score sex |
| The Following User Says Thank You to MY DICK IS SMALL-beautfpowers@gmail.com For This Useful Post: | Raider (11-30-2015) |
![]() | Not Ranked : 0 score I want a set with logos |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score @Partiesplayin; It is generally frowned upon to resurrect 2 year old threads without adding useful content. |
![]() Join Date: Jun 2010 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score At least he searched lol but It would be better not to revive such an old thread though. Just send the guy a private message. |
| The Following User Says NO Thank You to darkmx-6 For This Un-useful Post: | JSmith (11-08-2017) |
| Display Modes | |
