| MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information. |
![]() Join Date: Sep 2014 Location: Gainesville, FL
Rep Power: 0 ![]() Thanks: 18
(Thread Starter) | Not Ranked : 0 score https://youtu.be/Ib0fY8-sP34
__________________ 2008 Mazdaspeed3 E48 fuel Cobb SF+TIH, CNT Catted DP, AP V3, Autotech HPFP Internals 369 WHP/ 410 WTQ 12/27/2017 Last edited by Speed2006; 01-03-2018 at 03:25 PM. |
| The Following 2 Users Say NO Thank You to Speed2006 For This Un-useful Post: | Fstrnyou (01-03-2018), voodoo2crue (01-03-2018) |
![]() Join Date: Feb 2017 Location: Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score Damn that is impressive. This just goes to show how much power can be gained with E85. What boost and timing are you running to get that kind of power?
__________________ 2007 Sunlight Silver Mazdaspeed3 Engine: \\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\ Tuning: \\Cobb AP V3\\ Freektune Custom Tune \\ Suspension/Brakes: \\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\ |
(Thread Starter) | Not Ranked : 0 score I've got the boost at 22-22.5psi, and my timing at 2 load is as follows: Timing: -2.75 0.5 2.80 6.45 8.75 10.35 11.5 15.50 18.50 19.50 RPM: 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000
__________________ 2008 Mazdaspeed3 E48 fuel Cobb SF+TIH, CNT Catted DP, AP V3, Autotech HPFP Internals 369 WHP/ 410 WTQ 12/27/2017 |
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
| Not Ranked : 0 score Either that dyno calibration is off or your driving a unicorn. Which is it?
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
| The Following User Says Thank You to voodoo2crue For This Useful Post: | sharksinspace (01-04-2018) |
(Thread Starter) | Not Ranked : 0 score The only reason why I don't question it too much is because it pretty-decently mirrors the Vdyno. I was personally expecting about a 350/400 kind of run, but I believe that this isn't all too far off.
(Thread Starter) | Not Ranked : 0 score Also attaching a datalog from the dyno for those interested. BAT's were in the 130's after sitting on the dyno.
![]() Join Date: Jun 2017
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score You have a jesus ko4 lol |
| Not Ranked : 0 score At first glance, the math didn't seem to add up. At 80% inj duty cycle with an E50 mix isn't that much fuel, but when compared to a max of around 255g/s...it's seems to match up. Napkin math says 255g/s is about 250-275 whp for pump gas. The E mix is allowing you to roll in about 10-11 degrees more timing. I've read on this forum that each degree of timing can add up to about 10hp. Up to MBT of course. That puts you exactly where you are.
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | Speed2006 (01-20-2018), Thor Hammer (01-04-2018) |
| Not Ranked : 0 score Unicorn it is Sent from my SAMSUNG-SM-G890A using Tapatalk
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Damn I thought the K04 was only good for 320-330 whp on an E mix. That torque must feel great but are you on a stock block?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score Dynojets read higher than mustang dynos. Adjust your vdyno correction factor to 1.01 and report back Sent from my SM-G930T using Tapatalk .
__________________ 3rd rebuild on the way...maybe... |
Also, why are you revving out to 7200 on stock block/k04? That's high risk/0 reward with the k04.
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ Last edited by voodoo2crue; 01-03-2018 at 06:22 PM. | |
| The Following User Says Thank You to voodoo2crue For This Useful Post: | Thor Hammer (01-04-2018) |
(Thread Starter) | Not Ranked : 0 score I wasn't the one revving to 7200 lol I know there's no power up there. That was the dyno guys. I just made 7200 my rev limit in Accesstuner just in case I missed a gear or wanted to show off
| The Following User Says NO Thank You to Speed2006 For This Un-useful Post: | voodoo2crue (01-23-2018) |
(Thread Starter) | Not Ranked : 0 score [QUOTE=voodoo2crue;3135906]When I put this into v dyno it comes up 293/296 which is more of what to expect out of a solid running K04 on an e mix. I'm going to conclude that it's not a unicorn afterall. Wait... A 50/50 e85 Speed3 running 22 PSI, and 296 ft-lbs of torque seems more reasonable? Most OTS Cobb Stage 2 Speed3's running 93 can surpass that. Running 14.5 PSI putting down 295: First dyno pulls on Stage 1 and Stage 2 Cobb Maps And almost every car on stage 1 or 2 on the COBB database puts down at least 300 ft-lbs of torque running only 15 or 16 PSI. https://www.cobbtuning.com/dyno-database/ Please, 410 might have been a high-reading, but I'm certainly not making 120 ft-lbs less than that.
| Not Ranked : 0 score [quote=Speed2006;3137094]
I didn't make those numbers up, I used your data log with the CF 1.01 factor that everybody else uses on this forum. It's not perfect but should give you a good idea of power/torque made. Even if it was off 20-30 hp/tq your still not close to what that dyno said. It's a VERY happy dyno, you believe whatever you want to.
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ | |
| The Following 2 Users Say Thank You to voodoo2crue For This Useful Post: | Cheapspeed (01-23-2018), sharksinspace (01-23-2018) |
| Not Ranked : 0 score My personal take on dynos, use them for testing/tuning. The actual accuracy of the number is rubbish, but they're great for comparative analysis.
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | Speed2006 (01-23-2018), Thor Hammer (01-23-2018) |
(Thread Starter) | Not Ranked : 0 score Okay. Is the Vdyno corrected for e85? or is it just gasoline predictions? If it's basing off gasoline numbers, I could understand that, just based off g/s of air. With e85 running much richer, the amount of air needed for combustion is much lower compared to 93, which could skew the numbers. Still don't know why I'm getting groaned at for posting numbers and video. Not making outrageous claims, just reporting what the machine told me.
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score you don't have to calibrate vdyno for different fuel types. at least not that i have ever heard of. we do need to know your tire size and weight numbers, though. fwiw, my stock block CS turbo on e30 vdyno'd at 365whp, and ran on a dynojet at 375whp. to approach that on k04 is far from the norm.
__________________ Genpoo stuff |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will admit that the HP appears to be high; that much is certain. But I do not believe that the TQ number is very far off. Phate with almost the exact same mods, running similar timing with just full e85 rather than 50/50 was putting down 430 ft Lbs. I know that the torque is there, because I beat JB4 335i's, 5.0's and S3 Speed3's. E85 Discussion - HPFP lubrication and Flow issues
![]() | | #20 | ![]() |
| Not Ranked : 0 score vDyno measures the rate of acceleration and uses weight, gear ratio, tire size, etc and uses physics to calculate torque required to do X amount of work. Horsepower is calculated like always from the calculated torque and RPM. Engine size, VE, BSFC, fuel type, ignition timing, boost, etc are irrelevant to the calculation.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Thor Hammer (01-23-2018) |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score What gear did you do the calculation in? When I put my run into Vdyno on 4th gear, smoothing at 4, and CF=1.01 I get this
| 2013 Speed3 Dyno | NCspecV81 | 2010 MS3 - Dyno Sheets/Discussions | 5 | 07-07-2015 07:25 AM |
| Mustang Dyno my Speed3 (Part 2) | mleblond | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 20 | 09-21-2009 03:33 PM |
| Mustang Dyno my Speed3 | mleblond | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 39 | 10-15-2008 11:37 AM |
