  • 2 Post By DumbDave
 Old 04-12-2015, 10:34 AM   #1
DumbDave's Avatar
Posts: 57   (View Stats)
DumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond repute
Default 328hp k04
3 pulls on a dynojet, 85+ ambient temp, 130+ BAT's from the stock top mount and idling waiting for dyno crew to strap her down.
50/50 E85, ebay downpipe, Cobb SRI, autotech HPFP internals, self tune @ 24psi.
First pull was the strongest, then heatsoak, and more heatsoak. I waited a year to post to make sure it didn't blow up on this tune. IMO a dyno doesn't prove a whole lot if you can't consistently make the power.
cbmms3 and travelle1311 like this.
DumbDave is offline   Reply With Quote
The Following 14 Users Say Thank You to DumbDave For This Useful Post:
Agent_Orange (04-12-2015), AZST (04-12-2015), btstarcher (04-12-2015), Cheapspeed (04-12-2015), Code Monkey (04-12-2015), Hush (04-12-2015), InkedInspector (04-13-2015), MD1032 (04-13-2015), mxlplx71 (04-12-2015), RalliartRsX (04-12-2015), SarcasticOne (04-12-2015), snailD (04-12-2015), travelle1311 (04-14-2015), Vansquish (04-13-2015)
 Old 04-12-2015, 02:14 PM   #2
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
Looks good man!
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
The Following User Says Thank You to Colepidd55 For This Useful Post:
DumbDave (04-13-2015)
 Old 04-12-2015, 04:25 PM   #3
sheston's Avatar
Posts: 1,847   (View Stats)
Need some Meth to combat that heat soak :-)
Looks good. Glad to see people getting the most out of the K04
 Old 04-12-2015, 04:44 PM   #4
btstarcher's Avatar
Posts: 4,852   (View Stats)
Looks similar to my results, but lower; I think I made power a bit sooner, and torque was 424wtq. Then again that was VD, but I was also at 24psi. What do you taper down to?
SnailTune in progress
 Old 04-13-2015, 05:47 AM   #5
DumbDave's Avatar
Tapers down to 18, tried to keep tq below 400 lb-ft for the sake of my stock internals
The Following User Says Thank You to DumbDave For This Useful Post:
btstarcher (04-13-2015)
 Old 04-13-2015, 06:16 AM   #6
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Great results, dude. Good job. How much airflow are you achieving in the top end, and at what pressure? I'm going to have a very similar setup pretty soon. I have an intake and ebay DP ready to install. Also, how much air pressure are you running in the low end?
2007 Mazdaspeed3 GT
 Old 04-13-2015, 06:37 AM   #7
DumbDave's Avatar
I'll upload my map when I get home this evening.
 Old 04-13-2015, 07:10 AM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
After plenty of TMIC fail at NDC dyno days, we found it was best if you just put 1 intercooler fan on top of the TMIC on the hotside. After that we were able to keep it consistent pull after pull.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 04-13-2015, 02:04 PM   #9
DumbDave's Avatar
Map added to OP.
 Old 04-13-2015, 02:10 PM   #10
MD1032's Avatar
Groans: 143
I can't open that file because I have a Gen2.
2007 Mazdaspeed3 GT
 Old 04-13-2015, 02:25 PM   #11
DumbDave's Avatar
send me a pm with which charts you want, i'll take some screens for ya
MD1032 (04-13-2015)
 Old 04-14-2015, 12:32 PM   #12
Chriss's Avatar
Posts: 92   (View Stats)
Chriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond reputeChriss has a reputation beyond repute
Or maybe a log ?
Chriss is offline   Reply With Quote
The Following User Says Thank You to Chriss For This Useful Post:
MD1032 (04-14-2015)
 Old 04-14-2015, 01:45 PM   #13
Coats's Avatar
Posts: 580   (View Stats)
Coats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the world
Much respect to you guys that tune. I think you might have some room to play with
Some freeky dude tuned me on 3 gallons of E85 resulting in 337whp
2013 Dodge Ram Laramie
GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI
SOLD 2009 FREEKED Mazdaspeed3 GT
Coats is offline   Reply With Quote
Page generated in 0.32598 seconds with 27 queries
