| MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information. |
![]() Join Date: Mar 2019
Rep Power: 0 ![]() Thanks: 1
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score Plug it in your peepee
__________________ Stockish |
| The Following 3 Users Say Thank You to Db09ms3 For This Useful Post: |
| Not Ranked : 0 score the only way is to datalog carefully under specific conditions and plot is with vdyno software. You can search vdyno thread to figure out how to do it. At the end of the day, it is more usefull to compare the same car tested at the same place against new modifications than comparing different car at different places because the power units have some difference according to different conditions and cars. You have other device that read g-force or or calculator that estimate hp based on the time it takes to accelerate a specific mass but all of them are affected by measuring parameters. The best way is to put 2 car side by side on a track or strapped on the same roller back to back.
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Take a wot log and bake it in the oven @350f for 35 mins. Let cool off and cover in chocolate frosting. Make sure to let it cool before frosting it or it will rip and crumble.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following 4 Users Say Thank You to 5doorsoffury For This Useful Post: |
Groans: 211
| Not Ranked : 0 score Vdyno. Look it up on the Google thingamajig while eating your AP cake recipe from 5doorsoffury.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
| The Following 2 Users Say Thank You to Thor Hammer For This Useful Post: | Db09ms3 (04-17-2019), InkedInspector (04-17-2019) |
| Not Ranked : 0 score More specifically, let it cool slowly at room temperature. I cheated and put it in the fridge. Now I have low compression in cylinder 4.
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score If there is, it would be terribly inaccurate. You can, however, as stated, datalog the correct PID parameters and run it through Virtual Dyno with a 1.01 correction factor and get a general idea. Read the Virtual Dyno threads on what to log and how to do the log. Lots of such threads here.
| Throttle Body Spacer with 2 Meth Ports | cshunter | 2010 MS3 - Fuel, Nitrous & Water Injection | 145 | 08-05-2015 07:23 AM |
| Honda slowing US production due to ports dispute | Haltech | Automotive News | 0 | 02-19-2015 08:50 AM |
| NJSPEED3 ports my manifold-review | atvfreek | Gen2 MS3 General Discussion | 11 | 04-07-2013 10:08 PM |
| SYNC FTW: Ford adding mobile internet compatibility to USB ports | Haltech | Automotive News | 0 | 12-21-2009 12:10 PM |
| Toshiba Launches New L350 Notebook With Innovative USB Ports | Haltech | Computers & Technology News | 0 | 04-01-2008 01:10 PM |
