 Old 02-21-2019, 12:47 PM   #1
Coltzxli's Avatar
Posts: 45   (View Stats)
Coltzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to behold
Default Before and After Boost Controller (1 revision PD Tune)
Attached is the PDF. Much better numbers.
Mods: Intake, Exhaust, DP, BCS, HPFP, AP v3 tuned by PD
Coltzxli is offline   Reply With Quote
 Old 02-21-2019, 01:10 PM   #2
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
Looks like wheel spin or clutch slip to me.
Third gear likely wheel spin.
Try a 4th gear pull. The data to Will will be better.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
 Old 02-21-2019, 01:21 PM   #3
Coltzxli's Avatar
Dead on, the road was slick with some rain. I let him know it was spinning and told him I could redo the pull if I needed to
 Old 02-21-2019, 08:25 PM   #4
MSMS3's Avatar
Posts: 2,826   (View Stats)
If that torque was real and truly under load, there would have been a likely bent rod. That is slip. I would want to see the actual data log.
 Old 02-22-2019, 09:02 AM   #5
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
vDyno rules: dry, flat, AND smooth road with little to no wind.
If datalogging for a tune updates, the road only needs to be dry and smooth.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-22-2019, 10:10 AM   #6
Coltzxli's Avatar
Thank god that was artificial then, lol
Noted, thanks for the tip, Will try and replicate today since it is dry
Last edited by Coltzxli; 02-22-2019 at 10:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-22-2019, 11:40 AM   #7
Coltzxli's Avatar
Ahhhh, these numbers look better and realistic on a dry road!
Snow maf/boost controller boost Line question speed3gen1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 10-29-2012 07:29 PM
What boost controller? Fagwagon MazdaSpeed 3/6 - Big Turbo Builds 19 12-10-2010 07:54 PM
Page generated in 0.27873 seconds with 24 queries
