  • 1 Post By cld12pk2go
  • 1 Post By atvfreek
 Old 04-15-2012, 10:00 AM   #1
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Default Cld12pk2go's GTX3071 Dyno (415.4whp and 427.9wtq)
For comparison, here are links to my previous 2 dyno sessions:
http://www.mazdaspeedforum.org/forum/foru...58-0wtq-39636/
http://www.mazdaspeedforum.org/forum/foru...66-9wtq-53665/
2008 MS3
Mods: ATP GTX3071, CP-E 3.25'' MAF, CP-E Nviscid Intake, Ported IM, PG FMIC Piping with IC0035 core, PG V1 Exhaust manifold, CP-E DP with Cat, Alky Control Methanol injection, KMD V2, Denso ITV24, Cobb AP ATR
Notes: stock CBE and stock BPV, running 100% methanol with M10 nozzle, and 3.5 gal E85 with balance of tank being 93 octane.
Runs at 65°F ambient. SAE correction factor 0.99 on Dynojet dyno.
I did 3 runs each using a different tune.
Run 002 was with tune V109Y12
Run 003 was with tune V109Y13
Run 004 was with tune V109Y14
The only difference between the tunes is 1° timing increase from each version from 3000-7000 RPMs. V109Y13 has the ignition timing I had been running for a while and I wanted to map out the response on each side a bit.
Ignition Timing Curves:
Code:
3.00	5.00	7.00	8.00	9.50	11.00	13.00	15.50	16.50
Code:
4.00	6.00	8.00	9.00	10.50	12.00	14.00	16.50	17.50
Code:
5.00	7.00	9.00	10.00	11.50	13.00	15.00	17.50	18.50
Results:
Pull 002 Log:
Pull 003 Log:
Pull 004 Log:
Dyno video:
Observations:
  • My normal spool to 20 PSI RPM is 3200-3300 on the street from a 4th gear pull. During the dyno session it was delayed until ~3800 RPM due to reduced loading.
  • I was spinning through peak torque on every pull so actual peak torque was likely something > 427ft-lbs.
  • LCV2™ decided to rear its head and really hose my pulls above 6000 RPMs by closing the throttle and pulling WGDC, which likley cost me a good bit of power up top.
  • I appear to be below MBT from 4500-6000 as I am gaining power everywhere with the 2° of added timing. I would call the results inconclusive from 3000-4000 due to spinning and at 6500 RPMs as LCV2™ is really muddying the data.
  • I wonder how much of a restriction the stock CBE is >400whp? I would assume it is pretty non-optimal at this power level; however, my EGTs were still in check at ~1650°F.
Here is my best pull from each of my 3 dyno sessions plotted together:
It is obvious the GTX3071 simply obliterates the little K04 turbo.
The Following 37 Users Say Thank You to cld12pk2go For This Useful Post:
11cruzito11 (04-15-2012), 802MS3 (04-15-2012), 86AmishMs3 (04-16-2012), anavrinIV (04-15-2012), atvfreek (04-16-2012), BigjohnB20 (04-15-2012), BlueStreak (04-17-2012), Boost_creep (04-17-2012), BPASPEED (04-15-2012), Broxer (04-15-2012), Ckmazdaspeed3 (04-15-2012), ckMS3 (04-16-2012), djuosnteisn (04-17-2012), dougefresh_ (04-15-2012), Fail_6 (12-27-2012), franz (04-15-2012), fywdyl (04-17-2012), helmetface (09-12-2012), IshiKage (04-17-2012), jdeves (09-20-2012), jracer (04-15-2012), Lex (04-15-2012), Manny3 (04-15-2012), mazdafreak (04-15-2012), MS3-a(sore)ASS-rex (04-16-2012), ms3blackmica (04-10-2013), NJSPEED3 (04-17-2012), psychophyr (04-15-2012), rfinkle2 (04-16-2012), rghispanic88 (04-15-2012), SilverDemon (04-17-2012), speed23 (04-15-2012), superskaterxes (04-17-2012), Tabasco69 (07-21-2013), thepatient77 (04-15-2012), uncorked11 (04-15-2012), Ziggo (04-15-2012)
 Old 04-15-2012, 10:07 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
Kick ass man!
2013 Scion FR-S (Whiteout)
Less parking more racing
 Old 04-15-2012, 10:19 AM   #3
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Looks good man, but I makes me re think my expectations for my own 400 hp. Im not running Meth, or ported anything. BTW thanks for you BT write up, it was very helpful.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 04-15-2012, 10:35 AM   #4
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
good stuff. I plan on a similar setup (minus meth and eth...want to run pure 93) and I'd like to get close to 400. thanks for the hope
Blue Pu.
 Old 04-15-2012, 11:53 AM   #5
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Any chance of doing a log w VD w your final tune? I would love to see the comparison.
 Old 04-15-2012, 01:32 PM   #6
Eth/Meth Junkie
cld12pk2go's Avatar
Here is a log and VD plot that is essentially with the same map parameters as V13's tune (only changes to fuel injector latency):
I was making a fair amount of extra power on the street at the cooler ambient temps (as per MAF g/s) and LCV2™ wasn't biting nearly as hard as it did on the dyno.
Essentially, the data suggests that a VD CF of 1.01 is pretty darn close to the real thing.
Great results! I see your throttle DBW tables are at 85. Set them above 90 - that may prevent throttle from closing.
I have tried 100% and it didn't make any difference unfortunately, so I reverted to 85%.
Originally Posted by m4tic View Post
You should buy DNP EWG mani
Why would I want to do this?
Last edited by cld12pk2go; 04-15-2012 at 01:32 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
 Old 04-15-2012, 01:43 PM   #7
NoLeftTurn's Avatar
Posts: 188   (View Stats)
NoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the worldNoLeftTurn is the leader of the world
Hey I see you are not checking the "Boost Tune" check box for hybrid tune. It seems that most people are checking it. Do you find that you have better results without checking it? Also I think the person that recommended the EWG was thinking the blips in your dyno chart were boost related not tire spinning. I can't believe the power you are putting down. Great work and thanks for all of the documentation you have provided over the years.
NoLeftTurn is offline   Reply With Quote
 Old 04-15-2012, 11:59 AM   #8
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
This forsure
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 04-15-2012, 12:11 PM   #9
m4tic's Avatar
Posts: 4,928   (View Stats)
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 04-15-2012, 12:28 PM   #10
atvfreek's Avatar
Posts: 7,787   (View Stats)
Good stuff man. She must be fun to drive!
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
cld12pk2go (04-15-2012)
 Old 04-15-2012, 01:02 PM   #11
 Old 04-15-2012, 01:47 PM   #12
m4tic's Avatar
I see you are running above the creep area.. Carry on.
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 04-15-2012, 02:02 PM   #13
atvfreek's Avatar
Huh? He ported his IWG and had no creep what so ever.
Tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 04-15-2012, 02:23 PM   #14
m4tic's Avatar
Tappin
go up a few more posts
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 04-15-2012, 02:23 PM   #15
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
stock bpv? no shit?
dayum
 Old 04-15-2012, 04:15 PM   #16
Eth/Meth Junkie
cld12pk2go's Avatar
Tappin
Very fun.
I have not found that the boost targeting tuning was very satisfactory other than for WOT in high gear. It is certainly better for avoiding LCV2™ than LT, but I wanted to be able to use my first 3 gears and I have been back on LT for about 2 weeks or so with good luck avoiding LCV2™ until the last few days (bummer).
Nothing I do in Boost Targeting mode will let me control power in the first 3 gears. When the BT isn't checked I can use the DBW tables to close the throttle to limit power.
I have zero creep issues with the ported turbine housing. I have been able to hold spring pressure to redline in the past.
Tappin
Yeah, what he said.
stock bpv? no shit?
dayum
Yep. I found no difference in performance with my Forge, so I sold the Forge and put the stock BPV back on.
atvfreek (04-15-2012), rfinkle2 (04-16-2012)
 Old 04-16-2012, 05:06 AM   #17
NoLeftTurn's Avatar
[QUOTE=cld12pk2go;1362299] I have not found that the boost targeting tuning was very satisfactory other than for WOT in high gear. It is certainly better for avoiding LCV2™ than LT, but I wanted to be able to use my first 3 gears and I have been back on LT for about 2 weeks or so with good luck avoiding LCV2™ until the last few days (bummer).
Thanks. I am now in pure LT mode. I have a 14 psi spring I still get too much in first but I will keep closing the throttle until it holds. I am at 80 percent now and still spin. I will drop to 70 percent next to see how that goes.
PS. I can't Quote properly apparently.
The Following User Says Thank You to NoLeftTurn For This Useful Post:
 Old 04-16-2012, 06:22 AM   #18
driver311's Avatar
Posts: 1,769   (View Stats)
Very fun.
Yeah, what he said.
I have personally bolted the forge up on the dyno and see gains. Without a doubt there are gains using it. I thought the exact same thing until I did it on the dyno and got pretty substantial gains. I posted this info along time ago with the standard gt3071 I thought. Anyways good numbers man and I for one think your catback and forge kept you from making 430-440whp like I was expecting at 24psi from a setup like yours.
Mazdaspeed
 Old 04-16-2012, 08:29 AM   #19
Eth/Meth Junkie
cld12pk2go's Avatar
FYI,
I saw no WGDC shift before/after swapping the Forge/stock BPV while maintaining the same massflow.
From this I concluded their was no significant leakage. I certainly do not mean to suggest that your data isn't valid; however, I would question if it is applicable in my case based upon my testing/observations.
Perhaps my stock BPV is just a "good" one...
The one caveat is that that test was a couple of PSI lower than what I have been recently running.
I had a leaky BPV on my Mustang, and the difference was very obvious when putting on a replacement as were the symptoms of not being able to run above a certain PSI threshold (12 PSI in the case of the stang).
I am currently targeting 1.2 load in 1st gear on the TRL tables and calling for mid-upper 20% throttle opening on my DBW tables around this load to actually achieve it.
In 2nd gear I am targeting 1.45 load on my TRL Tables calling for and low 30% throttle opening on the DBW tables around this load to actually achieve it.
In 3rd gear I am targeting 1.75 load on my TRL Tables calling for and around 50% throttle opening on the DBW tables around this load to actually achieve it.
These will obviously have to be dialed in cell by cell, but those are the general levels required for me.
Of course your requested WGDC will impact where you need the throttle to be to obtain a certain load.
I have the DBW tables set to 85% for loads of 2.00 and above which means that in 4-6th gears the throttle is always at 85%.
Last edited by cld12pk2go; 04-16-2012 at 08:53 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (04-16-2012), Broxer (04-16-2012), rfinkle2 (04-16-2012)
 Old 04-17-2012, 09:49 AM   #20
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Great numbers 12pk!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
cld12pk2go (04-17-2012)
 Old 04-17-2012, 06:22 PM   #21
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Very nice ice cold!
 Old 04-17-2012, 08:41 PM   #22
D08SPEED3's Avatar
Posts: 266   (View Stats)
D08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the worldD08SPEED3 is the leader of the world
Awesome number!!!!!
2008 MS3
COBB AP (ICECld Tuned: E85 20%), UltraGauge, CS TMIC, Denso ITV22, HPFP Internals, HKS Hi-Power CBE, SURE Areos SRI, SU Test Pipe, Turboxs Downpipe, Turbosmart Dual Port BOV, TRZ RMM, JBR SSP+Shifter Bushings+Heavy Shift Knob, Eibach Springs, F2 Drilled and Slotted Rotors + Hawk HPS Pads, Sparco Seats, Rota Slipstream, HID Yellow Fogs, Autometer Cobalt Boost Gauge
D08SPEED3 is offline   Reply With Quote
GTX3071 build JacksonMS30 MazdaSpeed 3/6 - Big Turbo Builds 767 05-18-2013 12:49 AM
Cld12pk2go's ATP GTX3071 Build cld12pk2go MazdaSpeed 3/6 - Big Turbo Builds 210 12-31-2012 08:03 PM
Sleeperhatch's gtx3071 build SleeperHatch MazdaSpeed 3/6 - Big Turbo Builds 224 10-23-2012 02:50 AM
Drivers gtx3071 driver311 MazdaSpeed 3/6 - Dyno Sheets/Discussions 3 10-22-2011 03:08 PM
Stock Turbo Screams for Mercy II (297.3WHP/366.9WTQ) cld12pk2go MazdaSpeed 3/6 - Dyno Sheets/Discussions 34 06-16-2010 03:13 AM
Page generated in 0.46319 seconds with 35 queries
