Like Tree5Likes
  • 1 Post By MikeTheCheek
  • 1 Post By Thepedigree13
  • 2 Post By WetzMS3
 Old 05-24-2016, 07:17 PM   #1
MikeTheCheek's Avatar
Posts: 9   (View Stats)
MikeTheCheek has a spectacular aura aboutMikeTheCheek has a spectacular aura about
Default Corksport Turbo with Freektune
Had to replace the turbo due to a broken compressor wheel. Went with the Corksport turbo and now being tuned by Freektune. Car is a 2007 Mazdaspeed3, mod list is as follows
Mod List:
Cobb SF Intake
cpe TIP
cpe RMM
cpe HPFP
cpe FMIC
cpe catted DP
HKS 3" CBE
Corksport Turbo
Corksport Radiator Shrouds
Corksport EBCS
Corksport 3.5 Bar MAP sensor
Cobb AP V3
94 Pump gas
55000km on the dot at time of turbo install and tuning process beginning.
I'm not going to be posting the logs from the base map. I will begin with the 1st revision.
Datalog 4 was done on a slight turn in the road causing the lower numbers.
V Dyno graph
2007 Mazdaspeed3 CWP
Cobb SF Intake, AP v3, cp-e TIP, JBR bov tube, cp-e fuel pump, cp-e catted DP, HKS CBE, cp-e FMIC, GFB Respons, cp-e RMM, Corksport Turbo, Corksport EBCS, Corksport 3.5 map sensor, BC coilovers, Corksport front swaybar endlinks, Corksport rear sway bar, Corksport mid chassis brace, Moog rear endlinks, Corksport radiator shrouds, Corksport Aluminum shift knob, DG Motorsports CF front lip, Enkei TS9 18x8.5 +35, Michelin Pilot Super Sports 225/40/18, FREEKTUNED
MikeTheCheek is offline   Reply With Quote
The Following 2 Users Say Thank You to MikeTheCheek For This Useful Post:
impossible (06-02-2016), KiwiFlavor (06-02-2016)
 Old 05-24-2016, 07:23 PM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
you should use the 1.01 correction and 3 smothing, subd
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
impossible (06-02-2016), MikeTheCheek (05-24-2016)
 Old 05-24-2016, 07:26 PM   #3
Noted, will do that for the next revision
 Old 05-24-2016, 08:23 PM   #4
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Subbed for results. A CS turbo may be in my near future.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 05-24-2016, 08:33 PM   #5
mxlplx71's Avatar
Groans: 128
i just bought one to, building my engine now.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-24-2016, 08:47 PM   #6
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
why wait? you can do it with the logs you have now.
Mods: stock
 Old 05-25-2016, 08:21 PM   #7
Good point. Graph has been updated on the first post using Datalog3
faeker likes this.
 Old 06-01-2016, 07:33 PM   #8
Just got the 2nd revision loaded yesterday and had time to do logs today. You can definitely feel more punch now and the power is still coming on smooth
 Old 06-01-2016, 09:49 PM   #9
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
I wonder what kind of gains you would make with a larger diameter intake.
Let that puppy breathe.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
 Old 06-02-2016, 01:10 AM   #10
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Same thing I'm thinking. I'm also curious if 320whp on pump gas and FBO is possible with this turbo. Can't wait for final revision VD results
 Old 06-02-2016, 05:17 AM   #11
I wanted to grab the HTP 3.5 intake but couldn't afford to drop that money at the time with the turbo, map sensor, ebcs, and tune. Bigger intake will most definitely be one of the first purchases for next year
 Old 06-07-2016, 06:43 PM   #12
Revision 3 came in so here are the logs. Not sure why log1 came out the way it did, I thought it was the best log when I did it but if someone with more knowledge than me can chime in go right ahead! I will say the car may have been a bit heavier than other days as the trunk was a bit more full if it makes any difference...
When the tune is finally done I will do my best to get out to a dyno day and get some proper numbers for everyone.
 Old 06-15-2016, 02:43 PM   #13
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
Keep us posted on the improvement you gain from a 3.5' intake.
Unfortunately I live in a place where cops are nasty when it comes to moding your car.
I kept my intake and cat back stock so its quiet and not noticeable. So far so good, no defects as yet.
Believe it or not, I got booked for having LED fog lights.
Although by just reading and learning from this forum and other sources, I was able to come up with a good power figure which I'm happy. My internal is bone stock.
I'll probably start looking into mixing e85 and ran more timing and boost later on.
Wish you all the best in getting the most out of your ride. This is a really good hobby.
By the way, I ran a CS turbo which led me to this post. With your intake, you should be able to hit higher numbers than me.
MRR is offline   Reply With Quote
 Old 06-15-2016, 03:15 PM   #14
Police - Grammarhead
Vansquish's Avatar
Why does your car weigh 3904lbs? The OE specs for the MS6 are 3586lbs...
KiwiFlavor (06-16-2016), WetzMS3 (06-15-2016)
 Old 06-15-2016, 03:35 PM   #15
Neutral  +1 score
Car full o hoes bruh.
allservice and MRR like this.
KiwiFlavor (06-16-2016), Speed3Pedro (10-06-2016), Vansquish (06-15-2016)
 Old 06-15-2016, 03:36 PM   #16
MRR
MRR's Avatar
Took into consideration the wt of my tow bar, tool box, my self and my old buddy who shits himself every time I go WOT.
The tow bar is heavy due to the fact that it was custom built. There are no aftermarket tow bars for this car. This is probably the worst mod I've done to my car LOL.
Unfortunately I use this car for work and I tow a trailer at times and carry my tools. Wish have the luxury of having 2 vehicles.
The Following User Says Thank You to MRR For This Useful Post:
 Old 08-09-2016, 07:42 PM   #17
Sorry I never came back and updated this everyone, life happens.
I don't have access to V Dyno so I won't be posting the final graphs. The logs are attached however.
According to Justin I should be at about 330-340 with 350tq. He believes that I will pick up around 5-10hp from a 3.5 or 4" intake. For the cost of an HTP intake I think my money is better spent elsewhere for those gains.
Car feels wonderful. Turbos been in for about 2500km with no issues. Been driving the car pretty aggressively and it definitely is keeping up. Looking to do a track day later this month so we'll see how she does there!
damnnewt likes this.
 Old 08-09-2016, 08:39 PM   #18
blackms3_71's Avatar
Posts: 2,250   (View Stats)
looking at the logs, you are starting to run out of injector (92) and maf volt is getting high at 4.7-4.8. the sensor will only read to 5v and around 4.9 u will start getting fuel cut, so intake is deff a mod you want to get if you want more power
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
Atticaz (10-05-2016), MikeTheCheek (08-09-2016)
 Old 08-09-2016, 08:46 PM   #19
The numbers/power I have is what I had set for my goals. What I meant is right now my money will be better spent on more suspension parts. Once I get tired of the power I have now then the first thing I'll pick up is a larger intake
The Following User Says Thank You to MikeTheCheek For This Useful Post:
 Old 10-05-2016, 10:24 PM   #20
Atticaz's Avatar
Posts: 621   (View Stats)
Neutral  +1 score
I'd like to see some more logs and vdyno's now that it's cooler out, if you've done any.
2007 MAZDASPEED3 - SOLD
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
Corksport Turbo Install pastry00 MazdaSpeed 3/6 - Big Turbo Builds 106 10-24-2016 01:54 PM
Corksport Turbo EWG Jester2552 CorkSport 60 12-03-2015 06:53 PM
Corksport Turbo Xxblinddzxx Mazdaspeed3/6 General Discussion 9 08-25-2015 08:06 PM
Corksport Turbo Set Up 406Speed6 CorkSport 7 07-15-2015 11:29 AM
Page generated in 0.40886 seconds with 31 queries
