| MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information. |
![]() Join Date: Jun 2018
Rep Power: 0 ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score Hey all, going to apologize upfront for being ignorant on the subject (currently learning what I can). Long story short my 2008 speed3 had engine work done at a local performance shop and just had them install intake/tip, hpfp internals, and Dyno tune it w/ an AP I bought with them while I was out of the country for a few weeks. Only other performance parts are a catback exhaust. Anyways here's the results. Not completely sure how this should compare, again sorry for being a noob with this, can respond to any questions! |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| 400+ lbft at just over 3000rpm is a recipe for bent rods.
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score i'd say the dyno is extremely optimistic because average stock dynos are 220-240whp, and there's no way you picked up 80-100whp with intake and tune. that's full bolt-on e85 territory. look up how to take a WOT data log and you'll be able to see what the tune really looks like.
__________________ 94 M MS6 IS350 |
| Not Ranked : 0 score I was thinking Mustang Dynos read low, but yeah, those numbers seem high for what's in it. Unless there's something OP isn't telling us.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Vansquish (08-28-2019) |
![]() Join Date: Jun 2009
But if that is whp on a Mustang he must have more mods and he must retune to soften the low rpm torque or he will be throwing a rod through the side of his block. I could not get to just barely 300 whp (per Virtual Dyno 1.01 correction) until I added a 3” catless dp/rp. I’d like to see a data log 3,000 rpm to redline from him and run it through Virtual Dyno.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Vansquish (08-28-2019) |
| MY RESULTS WITH DIZZY TUNNING-BY BUCKER- B4 AND AFTER "REAL" DYNO RESULTS | stc terminus | 2010 MS3 - ECU Computer Tuning | 2 | 07-30-2012 10:43 PM |
| Results from dyno day | BLURSPORTS | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 9 | 12-09-2010 01:18 PM |
| Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? | desperado callado | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 10 | 05-18-2009 11:27 AM |
