  • 1 Post By Mastertrixter
 Old 05-20-2015, 05:35 PM   #1
keychain12's Avatar
Posts: 239   (View Stats)
keychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the world
Default Gtx2867r Dynos
I myself have a Gtx2867r and was hoping to see others dyno's and mods list (I'm currently running into issues with my CP-e catted downpipe flowing passed 360+ hp)
My most recent dyno with comparisons from last time:
My mods list:
- ATP GTX2867r
- CP-e 3" catted TBE
- HTP 3.0" inlet & intake
- CX Racing piping w/ Treadstone TR8 FMI
- HPFP
- EGR Delete
- Grimmspeed EBC
- Forge V2 BPV
- Thermal Intake Gasket
- NGK Plugs
- 3.0 bar Map
- Devils Own WMI w/ d07 Nozzle
ATP GTX2867r | CP-e 3" catted TBE | HTP 3.0" Full inlet & intake | CX Racing piping w/ Treadstone TR8 FMI | HPFP | EGR Delete | Grimmspeed EBC | Forge V2 BPV | Thermal Intake Gasket | NGK Plugs | 3.0 bar Map | Devils Own WMI w/ d07 Nozzle | Cobb AP
Dynojet Dyno:
92 pump gas tune: 326whp & 320tq
24psi tune w/ WMI: 349whp & 351tq
26psi tune w/ WMI: 360whp & 364tq
XXR 531 18x8.5 [+35mm] | Dunlop Sport 225/40 | Cobb Springs | JBR Rear camber arms | JBR 80 RMM | Hotchkis front & rear SB| SS brake lines | Corksport CC | MSD Dashhawk |Custom Stealth Sub Box by user: JTMS3
keychain12 is offline   Reply With Quote
 Old 05-20-2015, 06:06 PM   #2
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Don't think it has anything to do with the stock intake and exhaust manifolds?
 Old 05-20-2015, 06:12 PM   #3
keychain12's Avatar
You know, it could. A local guy had the same mods with a VCTS delete manifold and a tubular exhaust manifold and he made 420hp lol. So something is choking me up
Dynojet Dyno:
 Old 05-20-2015, 06:16 PM   #4
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
Your sig says you have a 3" HTP intake? So do you have a stocker or HTP?
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
 Old 05-20-2015, 06:18 PM   #5
keychain12's Avatar
The guy above was referring to intake manifold and exhaust manifold I believe.
I have a HTP 3" full inlet and intake, but stock intake manifold w/ VCTS.
Dynojet Dyno:
 Old 05-20-2015, 06:24 PM   #6
Kor3y101's Avatar
Ahh of course. My derp has preceded me.
'12 Black Speed 3
 Old 05-20-2015, 06:28 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
Neutral  +1 score
It would be better if you could post a WOT log. That should tell us more about what is limiting your hp
Looking at things like your boost, AFRs, etc can tell a lot about your tune
keychain12 (05-20-2015)
 Old 05-20-2015, 06:29 PM   #8
keychain12's Avatar
Tell ya what. I'll get some logs and throw them up.
But for now, I'm just looking at others to see how they are doing on this same turbo
Dynojet Dyno:
 Old 05-20-2015, 06:42 PM   #9
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Just made 358whp on a mustang dyno with my 2871.
3" HTP
ETS TMIC
CS RP & CBE
3 gal e85
 Old 05-20-2015, 06:57 PM   #10
keychain12's Avatar
3" HTP
ETS TMIC
CS RP & CBE
3 gal e85
I should note I'm up in WA and we have very limited sources of e85. So WMI is really the only alternative fueling options for most.
Dynojet Dyno:
 Old 05-20-2015, 06:57 PM   #11
NCspecV81's Avatar
Posts: 2,867   (View Stats)
21-22psi on dyno
HTP 3in
stock EM
Stock Midpipe
3inch axle back w/o muffler
Meth 30/70 mix 500cc
2013 CWP and Stock
 Old 05-20-2015, 06:59 PM   #12
keychain12's Avatar
21-22psi on dyno
Who tuned you?
 Old 05-20-2015, 07:01 PM   #13
Groans: 51
Yes, but you are on Meth. I could make the same if not more power than I am now on 93 and meth.
Matthew
 Old 05-20-2015, 07:04 PM   #14
NCspecV81's Avatar
Who tuned you?
That was my concoction. Actually that was a GTX3067. nevermind. Same compressor side as the GTX2867 just uses the GTX30 turbine. They are very similar turbos tho.
2013 CWP and Stock
 Old 05-20-2015, 07:08 PM   #15
keychain12's Avatar
Matthew
I'm on 92 in WA.
Dynojet Dyno:
 Old 05-20-2015, 08:15 PM   #16
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I would also be interested in seeing a log.
2007 Mazdaspeed3 GT
 Old 06-27-2015, 05:32 PM   #17
Mastertrixter's Avatar
Posts: 386   (View Stats)
Mastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the world
Just looking at the dyno graph I can see one issue...... your not making any more power above what I'm guessing is like 5k..... what's your boost curve look like?
2011 speed 3
BNR s3 v2
snow performance wmi
dammon occ, egr deletes
htp 3"
cx piping with tr6 core
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
jbp ssp, weight, bushings, rmm, and rsb
koni oranges with road magnet springs
motegi mr116 18x8 +45
Powered by PURPLE DRANK
350/360 vdyno cf 1.01 on 91 pump only
Mastertrixter is offline   Reply With Quote
 Old 06-28-2015, 12:01 PM   #18
keychain12's Avatar
Well one thing that is for sure I have a boost leak. Just tested last night and I found that I have a leak where my Damond Motorsports throttle body WMI spacer is. Gonna order a couple stock throttle body gaskets and retest.
Dynojet Dyno:
 Old 06-28-2015, 12:10 PM   #19
Yeah get that shit ironed out. Your missing out on the best benefit of a bt. Power all the way to redline.
2011 speed 3
BNR s3 v2
htp 3"
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
The Following User Says Thank You to Mastertrixter For This Useful Post:
keychain12 (06-28-2015)
 Old 07-12-2015, 06:52 AM   #20
murda's Avatar
Posts: 42   (View Stats)
murda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond reputemurda has a reputation beyond repute
Here's my dyno graph comparison from Cobb stg. 2 to bolted & tuned to GTX2867 & tuned. All on the same dyno.
Stage 2 = 254/285
K04 w/ tune = 282/340
gtx2867 w/tune = 380/390
2010 GTX2867r MS3 380whp/390wtq 94 pump gas
murda is offline   Reply With Quote
 Old 07-12-2015, 07:07 AM   #21
everton99's Avatar
Posts: 1,044   (View Stats)
Groaned at 8 Times in 7 Posts
Stage 2 = 254/285
93 or E mix on the 28?
 Old 07-12-2015, 07:13 AM   #22
murda's Avatar
Ultra94, no E.
 Old 07-12-2015, 10:31 AM   #23
everton99's Avatar
Ultra94, no E.
Holy crap man that makes me feel like my GTX2871 should be able to get close to that then. Makes me even more excited to install it!
 Old 07-12-2015, 10:58 AM   #24
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Who is tuning it?
 Old 07-12-2015, 11:01 AM   #25
everton99's Avatar
Who is tuning it?
Justin.
 Old 07-12-2015, 11:03 AM   #26
Gr8Speed's Avatar
Was referring to the OP.
 Old 07-12-2015, 11:08 AM   #27
murda's Avatar
Who is tuning it?
@Fobio
 Old 07-12-2015, 01:15 PM   #28
Would be interested in seeing some logs. Curious as to what your idc looks like? Also timing?
everton99 likes this.
2011 speed 3
BNR s3 v2
htp 3"
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
 Old 07-12-2015, 03:23 PM   #29
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Stage 2 = 254/285
I've always hated how laggy dynapack's makes big turbos look...
My old 3071 could spool to 20psi by 3300 on the street, but on the dyno, never spooled better than 4000...
 Old 07-12-2015, 08:24 PM   #30
murda's Avatar
Here's the 3 logs from the dyno pulls.
 Old 07-13-2015, 01:30 AM   #31
Jebus that's impressive. I need better than 91 oct.
97% idc and 13.5* up top on 26psi is near my meth setup lol
2011 speed 3
BNR s3 v2
htp 3"
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
 Old 08-06-2015, 03:08 PM   #32
keychain12's Avatar
Guys who have made 360+ with a gtx2867 do you wall have cat less down pipes?
Dynojet Dyno:
GTX2867r meicalnissyen MazdaSpeed 3/6 - Turbo Induction 59 04-18-2015 05:06 PM
All my dynos phailerider MazdaSpeed 3 - Engine, Transmission & Driveline 89 11-02-2013 08:14 PM
Page generated in 0.48234 seconds with 32 queries
