  • 1 Post By xtasy
 Old 06-03-2017, 08:17 PM   #1
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groaned at 6 Times in 4 Posts
Default Mazdaspeed6 525awhp & 497 AWTQ (freektuned)
Video and dynograph below.
Mod List:
Built bottom end, stock head.
HTP 3.5in intake
Grimspeed ported Intake manifold
CXRacing front mount intercooler piping w/ Treadstone TR8 intercooler
Custom Exhaust manifold
PTE 5858 w/ .82 AR (Running EWG, Tial 38mm) @35-36psi
3 inch Downpipe and turbobacck
6th port injection
Freektuned.
This is my 3rd dynotune with Justin @freektune.
First one was 200 miles after the motor was installed, bolt everything on with a stock top mount intercooler. The car Made 332awhp and 3XX torque. It should say in my sig.
Second time, the car made 479Awhp and 443 awtq. I made a mistake of not checking which map sensor I had. The whole time, I thought I had a 3.5 bar map sensor installed, but it was a 3bar. This tune was restricted by the map sensor.
Fast foward 13 months, only difference in mods was that there's a 3.5 bar map sensor now. I also put on about 3,500 miles since the last tune.
For this tune, I was hoping for 550 AWHP and maybe 475 AWTQ if lucky.
Justin did his magic and the result was 525 AWHP & 497 AWTQ. Even though the car didn't reach 550 AWHP, I extremely happy with the result. I favor torque over horsepower anyday. The extra 54 torque from this tune is really noticeable. 4th gear now pulls like 3rd gear in the previous tune.
This might be the end of the journey in terms of power mods. In order to make more power, the car will need new intake manifold, port injection and a bigger turbo. This PTE5858 surprised me with how much power it can push. This turbo is rated at 620hp on precision's website. Which sounds about right, since this engine should be pushing about 620-630 to the crank now.
https://www.youtube.com/watch?v=sQzsapO9sFk
Cheapspeed likes this.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
The Following 5 Users Say Thank You to xtasy For This Useful Post:
Cheapspeed (06-15-2017), Code Monkey (06-04-2017), IlleztImportz (06-17-2017), sho (06-14-2017), Tifosi42 (06-03-2017)
 Old 06-14-2017, 10:53 PM   #2
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Such a fun turbo. I went from a 5858 to a 5862, and at 35psi,it rips
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following User Says Thank You to sho For This Useful Post:
xtasy (06-15-2017)
 Old 06-15-2017, 12:05 AM   #3
xtasy's Avatar
What did you end up making on a speed3? I'm actually surprised that it landed directly at 525whp, PTE rated the5858 at 620 crank. Pretty close to that number if calculated to crank hp.
 Old 06-15-2017, 06:23 AM   #4
GroceryGtr's Avatar
Posts: 472   (View Stats)
What were you doing for fuel your sig says e85/93.
 Old 06-15-2017, 06:36 AM   #5
Djohns's Avatar
Posts: 3,944   (View Stats)
Ah another IL guy! Are you a FF or just have the plates?
2010 black mica speed3
Soon:built motor
 Old 06-16-2017, 10:52 PM   #6
xtasy's Avatar
I'm on e42 blend. So half e85 and half 93.
Nope just have the plates. It was between police memorial plates and FF plates. Was planning to do Police memorial plates on my daily, but never got around to it.
 Old 06-17-2017, 12:31 AM   #7
IlleztImportz's Avatar
Posts: 169   (View Stats)
IlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond repute
Question about your motor build. Did you have your crank keyed and what headstuds are you using?
IlleztImportz is offline   Reply With Quote
 Old 06-17-2017, 12:49 PM   #8
xtasy's Avatar
Crank is not keyed. L19 headstuds were used. Motor only has around 5000 miles within the last 3 years.
The Following User Says Thank You to xtasy For This Useful Post:
IlleztImportz (06-19-2017)
 Old 06-19-2017, 04:55 PM   #9
Djohns's Avatar
FF is better
Soon:built motor
xtasy (08-26-2017)
Been freektuned by rob JDMCRX FREEKTUNE 8 09-02-2014 06:24 AM
Getting Freektuned! vesestilldrumming FREEKTUNE 4 06-14-2014 07:28 PM
Freektuned E85 K04 Wildcard FREEKTUNE 26 04-17-2014 10:54 AM
Freektuned E85 PPD369Speed3 2010 MS3 - Dyno Sheets/Discussions 10 09-12-2013 05:34 PM
Got freektuned Code Monkey MazdaSpeed 3/6 - Dyno Sheets/Discussions 8 08-18-2012 08:27 PM
Page generated in 0.30975 seconds with 25 queries
