  • 1 Post By Boost_creep
 Old 12-05-2015, 07:40 PM   #1
Joost27's Avatar
Posts: 39   (View Stats)
Joost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond reputeJoost27 has a reputation beyond repute
Default My VD and Log
So, things have gotten tight this last month or so. I had to make some choices and I chose to make some quick cash selling my CS TMIC, SURE SRI, and a tons of old protege parts. Everything else on the MS6 has stayed. Leaving the HTP 2.5" TIP, M2 catted DP, Turbo Manifold, 07+ Cold pipe we opened up the pinch point on, CS HPFP, Methanol and AP.
I initially went back to a OTS map from what I had been running. And soon was disappointed and questioned why I bothered, as all I had was a few intake side restrictions from before. So I loaded up the old map and pulled a little timing and boost and did some pulls and then started adding it back. Right now, this is where I am at.
This is my VD plot
And log is attached. Feeling pretty good about it so far. Any input or tips other than buying some parts...
06 Mazdaspeed6 GT VRM
Sure Aeros | Corksport TMIC | XS Power v2 Manifold | HTP TIP | Corksport HPFP | COBB AP v3 | M2 DP w/ Cat | SURE RMM | Denso ITV22 | TurboSmart/SU Dual Port | H&R Springs | DO Stage2 MAF WMI DO7 Nozzle | EVO 8/9 Brembos
00 Protege ES
KLZE Straight Neck | Pacesetter Headers | CAI | AFPR | MFactory LSD | MSP Axles | 03.5 MSP Axle-Back | Catless Mid | Eibach Springs | Tokico HPs | MSP RSB | KMR Bracing | Corksport FSB | 5-lug Swapped | 07 MZ6 Front Brakes | 98 626 Rear Brakes | 03 ES Black Interior | Nardi Miata Steering Wheel | etc....
Joost27 is offline   Reply With Quote
 Old 12-06-2015, 06:12 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Looks pretty good. My only suggestion might be to make the timing advance more linear, ie. fill it out in the mid rpm range.
I big on pushing it, so I would add some WGD and get a little more boost mid band as well :-)
 Old 12-07-2015, 04:36 PM   #3
MSMS3's Avatar
Posts: 2,826   (View Stats)
I notice that the VD was done with Dynojet correction. Has Barnhill (developer of VD) finally gotten the correction factor right?
I know we have all been using 1.01 CF for a long time to make our VD charts more closely reflect chassis dyno numbers. Just wondering. I'm still using 1.01.
 Old 12-07-2015, 05:01 PM   #4
Joost27's Avatar
oh, Idk. been using dynojet CF all along. They still have it at 1.09. I guess comparing to others here it would matter, but for seeing progress as i make adjustments it should be fine as it is still comparing apples to apples.
Here is the same log with CF 1.01
00 Protege ES
 Old 12-08-2015, 10:36 AM   #5
Boost_creep's Avatar
Posts: 829   (View Stats)
I've found that MS6's actually turn out to be closer to Dynojet, while MS3's are closer to 1.01 CF.
The Following 2 Users Say Thank You to Boost_creep For This Useful Post:
MSMS3 (12-08-2015), rfinkle2 (12-08-2015)
 Old 12-08-2015, 07:52 PM   #6
MSMS3's Avatar
My bad. Failed to notice it was MS6. Also good to know 1.01 is still the standard CF for MS3.
 Old 12-09-2015, 08:31 AM   #7
Joost27's Avatar
More Timing and More Boost. Although I think I need to play with WGDC a bit more in the mid-high area, as it dips a bit. But, I dont have much more room to go, so I may be SOL.
Both Runs were done on the same section of road in similar temps (33*F vs 34*F last night) maybe a couple gallons less fuel though.
00 Protege ES
Page generated in 0.27241 seconds with 23 queries
