| MazdaSpeed 3/6 - Dyno Sheets/Discussions Post up your dynosheets. Discuss the graphs and any related information. |
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| What's your E85 mixture ratio? I can say that with an almost fully-bolted (no exhaust mani) MS6, I was able to get to around 290/335 on pump gas at relatively low temperatures. 270/330 isn't bad for the MS6, but I suspect you'll end up above that once you're fully tuned. A first revision from freektune is going to be a relatively safe place to start, and it won't be indicative of the full power you're likely to be able to achieve.
(Thread Starter) | Not Ranked : 0 score im running Full E85, no mix.
| Not Ranked : 0 score What's the approximate max whp/wtq on 100% e85 on a speed6 on stock injectors?
| Not Ranked : 0 score I wouldn't have even bothered putting a first draft into Vdyno. It will be in no way indicative of the final result.
| The Following 4 Users Say Thank You to Easter Bunny For This Useful Post: | InkedInspector (01-28-2016), MS3Shadow (01-28-2016), TiGraySpeed6 (01-29-2016), Vansquish (01-28-2016) |
| The Following 4 Users Say Thank You to Vansquish For This Useful Post: | Easter Bunny (01-28-2016), InkedInspector (01-28-2016), MS3Shadow (01-28-2016), robbspeed (01-28-2016) |
(Thread Starter) | Not Ranked : 0 score I read up on the redline si-1 treatment. taking of the HPFP and cleaning it with si-1 every now and then doesnt take much time at all.
| The Following User Says Thank You to wes3id For This Useful Post: | Vansquish (01-28-2016) |
| Watch those o-rings, and you might want to consider going for some nitrided HPFP internals (Integrated Engineering sells some).
No Idea, i'm late to the corn game. was under the impression (from research on here) that we don't yet have any upgraded injectors available yet.
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ Last edited by wes3id; 01-28-2016 at 06:13 PM. Reason: MSF Database - Automerged Doublepost | ||
| Not sure where you got that info. @littleloogy;? IE HPFP Internals For E85
Upgraded injectors (because aux fuel is for losers)
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | wes3id (01-28-2016) |
(Thread Starter) | Not Ranked : 0 score tried doing another 4th gear pull after changing a plug..still on first draft of freektune full E85 tune....not too bad, i can accept this...can't wait to see what i the final revision will look like.
| My first Maf Cal log, need advice | JDMJOSH | 2010 MS3 - ECU Computer Tuning | 0 | 11-02-2012 12:21 PM |
| advice please | mps6dave | Mazdaspeed3/6 General Discussion | 11 | 06-29-2012 03:40 PM |
