  • 1 Post By PurplFox
 Old 01-05-2016, 10:54 AM   #1
PurplFox's Avatar
Posts: 352   (View Stats)
Default Quite Happy
Enjoying my results from Justin@freektune
Comparison from 93 vs E33 sae and none sae corrected
Justin@Freektune likes this.
Cobb AP
JBR Tru-3.0
CNT Catted DP "Gutted"
CNT Catback
JBR 88 RMM DM PMM and TMM
3 port, Turbosmart dual port
FReaktune E33
The Following 6 Users Say Thank You to PurplFox For This Useful Post:
Code Monkey (01-05-2016), dale_gribble (01-05-2016), Justin@Freektune (01-05-2016), MS3Shadow (01-05-2016), robbspeed (01-06-2016), Tifosi42 (01-05-2016)
 Old 01-05-2016, 05:50 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
There's no reason to run SAE correction on top of a Dynojet CF of 1.01. That's 2 correction factors. Run the Dynojet default CF AND the SAE correction or the Dynojet CF 1.01 and no SAE correction. I prefer the former. It's either/or.
Good numbers for a k04 with a couple mods not pushing much past 20psi.
MINI H1 6.0 - CAR LED TAILS
robbspeed (01-05-2016)
 Old 01-06-2016, 05:23 AM   #3
PurplFox's Avatar
That makes since. I figured that the sae would help with the temperature changes from logs on different days.
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
 Old 01-06-2016, 06:23 AM   #4
Sure. I do that too and it does helps normalize runs. What is the vd power on those logs if you run default vd cf and just run sae correction?
 Old 01-06-2016, 07:55 AM   #5
PurplFox's Avatar
If i set it up right 318/378 and 309/638 SAE corrected
DJ 337/401 sae 346/412 no sae
Mustang 302/359 and 294/349
all at Smoothing 3
here is the log from that run
Cobb AP
JBR Tru-3.0
CNT Catback
FReaktune E33
Happy B-Day DJ jracer Mazdaspeed3/6 General Discussion 14 12-15-2010 03:46 PM
Page generated in 0.25950 seconds with 22 queries
