 Old 08-01-2016, 07:20 PM   #1
GroceryGtr's Avatar
Posts: 472   (View Stats)
Default Raw Freektune
VD from the WOT logs that went to freektune last week. Just thought I'd track my progression. Feel free to point out anything I did wrong on the options for the graph. occupant weight is 185 plus 40lbs in parts in the trunk. SAE taken from weather history, using stock DJ cf of 1.09. tires are new so dead-on height. Seems low, but then again its the base map so i'll be chompin to see how the revision performs.
Mods:
*Built engine(stock bore/comp)
*New K04(came with car and will do till I make up my mind between bnr and efr)
*TIP w/ ms cai
*Autotechs
*VCTS delete
*M1 long DP(no cats period)
FSR Freektune day wolfpack92054 FREEKTUNE 0 01-28-2016 05:46 PM
Mr. Freektune Clutch8218 FREEKTUNE 15 08-25-2015 08:03 AM
Freektune jseams 2010 MS3 - ECU Computer Tuning 14 12-02-2013 11:48 PM
Freektune and BT = Better MPG? NCspecV81 2010 MS3 - Big Turbo Builds 34 09-11-2013 11:27 AM
Page generated in 0.22159 seconds with 21 queries
