 Old 12-05-2014, 07:19 PM   #1
rudydecc's Avatar
Posts: 113   (View Stats)
rudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud of
Default rudydecc's dyno - please post opinions
Well, finally got around to putting the car on a dyno again. The last time I did it I hadn't replaced the fp internals and I still had my bad turbo.
Overall, I really would think that my hp numbers would be higher (or maybe I should say "should be"). Any way, I am putting on a fmic, replacing the bpv, new side motor mounts, and flashing the stage 3 tune. We shall see if the numbers get any higher.
But until next week, any thoughts on the numbers? I am fully bolted with the exception of the fmic.
The last time I dyno'd it had 230hp/216lb
2008 Mazdaspeed3 GT ::COBB STS/Turbo Inlet/AP/SW/BPV, Fujita F5 CAI, CP-E RMM/DP/CBE/FMIC, TWM Shifter Bushings/JBR Side Mounts::
2019 Audi Q7
rudydecc is offline   Reply With Quote
 Old 12-05-2014, 07:36 PM   #2
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
Sounds like you can use an e-tune.
boostdmazda3 is offline   Reply With Quote
 Old 12-05-2014, 07:49 PM   #3
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
whats a stage 3 tune? Also why are you replacing the HKS?
With your mods you should be close to 290-300 whp. You need a proper tune
nilashish is offline   Reply With Quote
The Following User Says Thank You to nilashish For This Useful Post:
CWP_MS3 (12-06-2014)
 Old 12-05-2014, 08:40 PM   #4
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
As they said, get a real tune, OTS isn't too great and an E-tune will make the world of a difference just in feel alone.
 Old 12-05-2014, 10:06 PM   #5
rudydecc's Avatar
Oh I know I need a proper tune. Oh do I know.
And the maps reference stage 3 maps.
http://www.cobbtuning.com/Accessport...s-07-SF-Intake
2019 Audi Q7
 Old 12-09-2014, 03:59 PM   #6
rudydecc's Avatar
Well, I have to take the car into the shop to have two new tires on the front, and chase down a possible suspension/alignment issue. So no dyne before I go to SC. Once I get there, I may have it done. Maybe get an e-tune prior to doing so... who knows.
2019 Audi Q7
First Dyno, advice/opinions? TrePaul86 MazdaSpeed 3/6 - Dyno Sheets/Discussions 24 10-15-2012 05:13 PM
First Dyno, advice/opinions? TrePaul86 2010 MS3 - Dyno Sheets/Discussions 3 10-15-2012 10:40 AM
COBB AP Dyno *post it* zx2man MazdaSpeed 3/6 - Dyno Sheets/Discussions 17 02-08-2011 08:13 PM
Dyno Sheet Post Need Help JRed MazdaSpeed 3/6 - Dyno Sheets/Discussions 1 09-17-2008 06:16 PM
Page generated in 0.25915 seconds with 24 queries
