Like Tree5Likes
  • 1 Post By Cdnspeed6
  • 1 Post By dale_gribble
  • 1 Post By sheston
  • 1 Post By shamie
 Old 04-22-2016, 01:39 PM   #1
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
Default Stock K04 320/360
Does this seem right? seems kinda high.
Clean run with less than 1.xx knock
I'm running the aem 500cc nozzle which is more like 600 Tbh, I love how low my bats are even after doing several runs lol
From what I understand is vdyno 1.09 is more accurate for a speed6 and a 1.01 is more accurate for a Speed3
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
The Following User Says Thank You to Cdnspeed6 For This Useful Post:
KiwiFlavor (04-23-2016)
 Old 04-22-2016, 02:20 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
What octane of pump gas?
There needs to be a correction factor if you don't use the SAE correction, default DJ is too generous also for MS6s also. What I do is get the temp/baro pressure at time of the run (you can use weather history websites like this: https://www.wunderground.com/history/), and plug those in as an SAE correction (i.e. 70 degrees / 29.00 baro).
IMO, the default DJ CF + SAE correction for your conditions is the most accurate. Also, I name my logs with the SAE correction values so I can compare runs seasons to seasons.
EDIT: THE tune looks pretty good. It's a good nozzle choice. Also, the car is doing a good job of holding power to redline, you're only about 10% off peak power to redline which isn't bad for a k04. That meth helps you get good timing to redline. What mix of meth/water are you running?
Ya, those KR blips don't mean anything.
monkey.bones.007 likes this.
MINI H1 6.0 - CAR LED TAILS
 Old 04-22-2016, 02:43 PM   #3
Cdnspeed6's Avatar
im running -35 Blue washer Fluid, I just noticed im slightly down on boost too, I think i had a small vacuum leak just start up last night, looks like i need to do a boost leak test
I feel like i can still run more timing in the mid-range but tbh I'm very happy with the power it makes Atm lol
I think the 3" cat back is helping keep power uptop I noticed a huge difference when i put it on, Im hoping to grab a XSpower manifold soon just to see how far i can take this turbo lol
Cmfk likes this.
 Old 04-23-2016, 09:00 AM   #4
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
@sheston; runs his k04 ragged.
 Old 04-23-2016, 06:43 PM   #5
sheston's Avatar
Posts: 1,847   (View Stats)
I like it like that. I bent a rod, so I built the motor. I run 27 + psi until the K04 quits building boost. Because of this I run Meth in tank and spray a D07.
Vdyno (with 300 lbs removed but not counted) says I get somewhere around 450 ft lbs and 350+ hp. It's a lot of fun, but I am looking forward to going BT (GTX2867R or its EFR equivalent) to see how much fun making the same power, but easier and better to modulate and control
Cmfk likes this.
speedfreak44 (05-27-2016)
 Old 04-23-2016, 10:56 PM   #6
Cdnspeed6's Avatar
Lol 450ft lbs haha wow that would be nuts, I'd like to up my boost towards redline abit more and carry HP higher if I can but I don't think this turbo will let me lol
 Old 05-26-2016, 02:39 PM   #7
BHM Mike's Avatar
Posts: 3   (View Stats)
BHM Mike can only hope to improve
Groaned at 4 Times in 1 Post
Default Stock MS 6 Engine HP
Howdy. Turbo failed and ruined engine. Going to rebuild. Looking at remanufactured OEM long block with Garrett turbo, upgrade on intercooler and intake, with better downpipe. Someone at Corksport said that you can generate 350 - 380 HP on stock OEM engine without damage. Does anyone know what the max HP is advisable with OEM engine internals?
BHM Mike is offline   Reply With Quote
The Following 4 Users Say NO Thank You to BHM Mike For This Un-useful Post:
MD1032 (05-27-2016), mize13 (05-27-2016), Thepedigree13 (05-26-2016), WetzMS3 (05-27-2016)
 Old 05-26-2016, 02:47 PM   #8
shamie's Avatar
Posts: 952   (View Stats)
Find the right section to post in Mike, don't just dump in someone else's thread.
Cheapspeed likes this.
The Following 2 Users Say Thank You to shamie For This Useful Post:
Cdnspeed6 (06-09-2016), WetzMS3 (05-27-2016)
 Old 05-26-2016, 04:19 PM   #9
BHM Mike's Avatar
Will do.
 Old 05-26-2016, 08:31 PM   #10
sheston's Avatar
@Cdnspeed6; Here's the logs you were looking for
Enjoy :-) I did
 Old 05-26-2016, 11:44 PM   #11
Cdnspeed6's Avatar
Thanks dude!!!
 Old 05-27-2016, 05:09 AM   #12
speedfreak44's Avatar
Posts: 1,391   (View Stats)
The power the k04 can bring on is pretty intense. I would like to take a ride in a built ms6 running a k04 to 27 psi. I ran my bnrs2 at 28psi and it would rip tires loose at 60mph roll ons.
The line up:
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
Page generated in 0.32956 seconds with 27 queries
