 Old 03-30-2015, 07:51 PM   #1
lescano88's Avatar
Posts: 40   (View Stats)
lescano88 is a jewel in the roughlescano88 is a jewel in the roughlescano88 is a jewel in the rough
Default VD accuracy
I made 4 logs today on rt 19 two southbound and 2 northbound, one was bad as someone tried cutting me off but here are the three. Honestly thought it would be higher given the mods and tune. BTW this is the ms6 sport in my sig
2006 MS6 Sport
BNR S4,Grimmspeed 3port EBCS, Bosch 3 bar map,Autotech HPFP internals-AP V3/FreekTuned-COBB SF Intake,TIP,BPV
Mishimoto FMIC,TMM,PMM,RDM,RMM,Corksport Rear chassis brace,CPE DP w/Highflow Cat,Corksport CBE, safe injector seals-NGK 6510
JBR EGR Block Off Kit,JBR BPV Hose,Redefined Performance PCV Plate,OCC S2,Odyssey PC680MJ Battery,SU Short Shifter,JBR solid shift bushings/weight,Eibach Pro-Kit Springs,Koni Sport Adjustable Shocks,SPC Camber Adjustable Ball Joints
Michelin Pilot Super Sports 225/40ZR18(summer)/Continental Extreme Contact DWS 215/45zr18(winter)
TRS mini projector retrofit w/h1 Morimoto 55w,60mm STRI boost guage
2013 Mitsubishi Outlander Sport SE
Stock
lescano88 is offline   Reply With Quote
 Old 03-30-2015, 07:52 PM   #2
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
seems about right for a k04 on 93
The Following 2 Users Say Thank You to Cevaes_64 For This Useful Post:
ASHMS3 (03-31-2015), Vansquish (03-30-2015)
 Old 03-30-2015, 07:54 PM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Looks about right.
MS6 = slowsville.
Get an E85 tune.
 Old 03-30-2015, 08:06 PM   #4
Police - Grammarhead
Vansquish's Avatar
It's about right, unless you've got cold weather (like I did for the numbers in my sig).
 Old 03-30-2015, 08:20 PM   #5
lescano88's Avatar
when it asks for air temp, is it the ambient air temp or intake air temp?
Forgot to mention it is tuned for 20 psi. Also when it asks for air temp, is it referring to ambient or intake air temp?
Originally Posted by Agent_Orange View Post
Looks about right.
MS6 = slowsville.
Get an E85 tune.
i don't think we have E85 around here
2006 MS6 Sport
Stock
Last edited by lescano88; 03-30-2015 at 08:20 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-30-2015, 08:31 PM   #6
lescano88's Avatar
i was only able to get one log for this one but here it is for the gt in my sig
2006 MS6 Sport
Stock
 Old 03-31-2015, 03:05 AM   #7
Groans: 665
Mighty Joe's Gas Grill & Deli
1231 Route 206
Shamong, NJ 08088
609-268-0303
Power Gas
205 Sanford Street
East Orange, NJ 07018
973-678-2002
Lalli Gas Inc
205 Sanford St
Gulf
100 Lindbergh Rd
Newark, NJ 07114
Newark International Airport.
They aren't exactly in your back yard, but there's definitely plenty of eth around NJ.
A 20 min drive to East Orange is well worth the fun of 300 whp and instant spool.
The Following 3 Users Say Thank You to Agent_Orange For This Useful Post:
CWP_MS3 (03-31-2015), lescano88 (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-31-2015, 05:44 AM   #8
lescano88's Avatar
wow didn't think it was that close, never like the idea of corn tbh. thanks a lot ill do more research and find more pumps in jersey and possibly tune.
2006 MS6 Sport
Stock
 Old 03-31-2015, 05:53 AM   #9
Vansquish's Avatar
Ambient. What else is in the tune? I mean, you haven't just turned up the boost, right?
 Old 03-31-2015, 05:55 AM   #10
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Why would you not like the idea of corn? No knock and about 30whp more... What's there not to like other than the inconvenience of having to do your mixes?
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
Agent_Orange (03-31-2015)
 Old 03-31-2015, 02:34 PM   #11
lescano88's Avatar
Not sure whats in the tune. Previous owner had it freektuned to run 20 psi then taper down to about 18.5 I'll attach the 3 logs i used for the VD.
2006 MS6 Sport
Stock
 Old 03-31-2015, 02:40 PM   #12
lescano88's Avatar
As I keep reading, I'm liking it more and more but I don't see myself running corn daily. I'm leaving to TX tomorrow for a few weeks. (military crap) I'll hit up Nishan for a corn tune
2006 MS6 Sport
Stock
 Old 03-31-2015, 02:48 PM   #13
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
the need to mix is all but unnecessary now with regard to the sticky death. Fueling headroom is another story on BT cars.
somewhere around this post.
E-85 Cure With Fuel Additives
clifs: Royal Purple Dexxos spec oil (no others) + Redline SL-1 lube in the CDFP periodically.
it has been found that setting the CF to 1.01 provides the most accurate numbers when compared to a loaded Dynojet.
at least that's the last I heard about a year ago. the default 1.09 is generous.
Last edited by Dano; 03-31-2015 at 02:48 PM. Reason: MSF Database - Automerged Doublepost
CWP_MS3 (04-01-2015), WetzMS3 (03-31-2015)
 Old 03-31-2015, 03:24 PM   #14
lescano88's Avatar
wow, a lot of good info on that thread, thanks. so dexxos royal purple is the go to oil for full e85. I guess I'll start prepping when i return for full maiz
2006 MS6 Sport
Stock
 Old 04-01-2015, 08:22 AM   #15
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Interesting.....
I'm a bit curious as to what is causing that red dust on the parts. Has anyone tried this without using that fuel cleaner? Perhaps that is the cause for the sticky film on them when he pulled them. Then again, maybe not because it did dry out.
I'd be interested to see what they look like after 10-15k without being pulled and cleaned. I wonder if it could be a zero maintenance long-term fix.
@MSP6;
Rich Tuned
330WHP and 363TQ
 Old 04-01-2015, 09:05 AM   #16
Trail of Fail
Dano's Avatar
yeah they are very close to maint free so time will tell.
 Old 04-01-2015, 09:07 AM   #17
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Well that depends on what the goop was on his internals before it dried out. That's why I'm curious if that SR1 or whatever is the cause of that, and its just a lube film that stuck around. IDK, cuz it dried out, so if it was actively still lubed with that shit, then it shouldn't have dried out.
You guys are making me want to get RP and give this a shot. I've never pulled my FP in almost 30k miles. My car has always been fine, so I never bothered. However, 100% E is very appealing to someone with a busted ass level sender. lol. Hell, doing mixes is a mild inconvenience, but a bit obnoxious if you don't have to.
Rich Tuned
330WHP and 363TQ
 Old 04-01-2015, 09:31 AM   #18
Trail of Fail
Dano's Avatar
I guess I look at the red dust like this....if you didn't pull the pump it would probably have just remained suspended in the fuel...IDK...there again time will tell but the RP Dexxos + SL-1 is the most promising development thus far.
I do run a mix ( E40) and it is a mild PITA to pull up to 2 pumps each time. I have a genwan so no fuel sensor issues occur that I am aware of. very weird that the PUs have it..damn fangled digital displays. If I went full E I would have to man up and get a 5th port though. Not too sure I want ~ 30% of my fueling coming from a $5 meth nozzle..lol
 Old 04-10-2015, 01:06 PM   #19
MSMS3's Avatar
Posts: 2,827   (View Stats)
Question: I know Brian Barnhill keeps tweaking his Virtual Dyno program with each new version. Is CF 1.01 still considered now to be the closest to typical Dynojet readings, or has be gotten his DJ calibration right for us? I'm reading different opinions here on this, but the posts seem to relate to different versions of the software.
Digital/Analog accuracy Peterzoom Mazdaspeed3/6 General Discussion 3 06-08-2014 08:40 AM
Torque app accuracy G-Man MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 03-14-2014 10:21 PM
Cobb App dyno accuracy? mroclimbr MazdaSpeed 3/6 - ECU Computer Tuning 4 03-29-2012 08:17 AM
accuracy of Dashhawk 1/4 times/horsepower? btstarcher Mazdaspeed3/6 General Discussion 8 04-27-2011 04:38 AM
Boost guage accuracy.. SpeedKAF MazdaSpeed 3/6 - Turbo Induction 15 04-20-2011 06:51 AM
Page generated in 0.40700 seconds with 27 queries
