 Old 08-11-2016, 03:14 PM   #1
GroceryGtr's Avatar
Posts: 472   (View Stats)
Default WTF runs were 15 minutes apart???
See 2 runs attached, 50 hp loss only difference I see is wastegate % is much lower on run10. run8 is 278hp vdyno, run10 is 223hp vdyno. What am I missing? Runs were on same road 15 minutes apart. air temps arent that far off, certainly not to explain a 50hp loss. 3rd gear pulls.
 Old 08-12-2016, 07:25 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
My guess would be that you start out with 20 deg higher BATs. Looks like something pulled a little throttle, some limit you hit or you soft pedaled it. At the end something pulled WGDC, I was expecting to see KR, but didn't. It may just be how your WGDC error correction handles your boost as you peak towards your targets vs. how they work as you drop as rpms rise
I think you really just need to spray some Meth and take the BATs out of the equation :-)
 Old 08-12-2016, 10:15 PM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Did it feel like it was 50hp less? Vdyno isn't always the most accurate.
Do a couple 4th gear pulls and see if you get the same.
jtday (08-13-2016)
ninety minutes my ass galens47 MazdaSpeed 3/6 - Build Diaries 18 02-21-2012 10:04 AM
This is How I Spent 90 Minutes Tonight Stealth01 MazdaSpeed 6 - Engine, Transmission & Driveline 30 07-26-2011 03:13 PM
Frankfurt 2009: BMW 7 Series Active Hybrid runs (almost) silent, runs deep Haltech Automotive News 0 09-16-2009 01:20 AM
VIDEO: Three minutes of NSX goodness Haltech Automotive News 0 06-30-2008 09:20 AM
Page generated in 0.23935 seconds with 23 queries
