![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
Groaned at 20 Times in 10 Posts
(Thread Starter) | Not Ranked : 0 score Problem is tire availability in 225/45/15. The Hankook RS3 seems to be the hot ticket this year, but they're sold out just about everywhere, and the rack is claiming they get 8 tires at a time, and will take at least a month to get you a set. The next step up Nitto nt01, carries a significant premium over the RS3. 225/50/15 options are more plentiful, but introduce more fitment issues, and the tires available are less reviewed. Lets use this thread to provide tire supplier information, reviews, fitment experience, and anything in between. |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Americas tire. Rs3
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
Groans: 370
| Not Ranked : 0 score tire rack has RS3s back in stock whoot. Saw they were a lil cheaper at discounttiredirect.com..but said special order or something |
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
| 15x9 Wheel Options | Neverlift | Miata - Wheels, Tires & Appearance | 24 | 03-27-2014 06:33 PM |
| Pairing new tire and old tire bad for front diff? | smakdown61 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 01-24-2011 08:55 PM |
| Titan Tire ships world's first 63-inch tire | Haltech | Automotive News | 3 | 07-31-2008 02:45 PM |
| GMC Sonoma Stalls, Sugar in the Gas Tank, Correct Tire Pressure, Ford Escape Tire Shimmy: Mike Allen's Weekly Online Aut | Haltech | Automotive News | 0 | 07-25-2008 02:30 PM |
