![]() Join Date: Dec 2016
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I have a 2007 cx7 2.3 turbo with 110,000 on the way home from doctor yesterday the car just quit running with no forewarning. I am pretty mechanically inclined so I have pulled the cam cover and all spark plugs. The timing chain is fine not loose and not broke. The motor turns over but has no compression and makes a loud knock when it turns over also the motor is about 2,000 out from needing an oil change and noticed that the motor still has oil but is not touching the dip stick but the timing chain is still picking up oil. Any help will be greatly appreciated I don't know anything about these motors |
| The Following User Says NO Thank You to Ethan23 For This Un-useful Post: | Neverlift (12-29-2016) |
