Miata MX-5
> Miata - Wheels, Tires & Appearance
 Old 01-09-2012, 01:50 PM   #1
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Default Miata Coilover Discussion.
Im looking to get some coils for the miata I just picked up, not for a month or two though. Seeing if anyone has anything to say about what TO or TO NOT buy, there are always cheap alternative (I'm not looking for hardcore coils, dampening is not that big of a necessity) but im basically looking for something I can use for a monthly autocross addiction, its not a competition its just a friendly event a local church puts on once a month in the warmer months.
Im looking to pick up some coils and then some 15x8's, I dont want to go crazy since I wont be tracking this thing, I just want to be able to be semi functional when i want to autocross or do a crest run.
Wheels ill most likely stick with XXR's or Rota's since they are cheap and Im not needing the hardcore weight reduction with 6ULRS or Enkei's etc.
The car is a 99' NB.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-09-2012, 02:00 PM   #2
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
*damping
I recommend Bilstein HD/Rpackage/Koni with either springs or ground controls. The adjustable collars will get you to a height that will be perfect for a decent alignment. However I run R package with Eibach pro kit... the stock r package can run 8/6k. 4/2k would be sufficient for DD which is what I am currently running.
You want to look into sway bars as well. Nothing too stiff, maybe just a FSB for your parking lot shenanigans. Without an LSD you will not have corner exit power.
Do NOT buy rota/xxr. Look @ Konigs... heavy wheels will murder the feel and power of the car. With stock power I would not exceed 13lbs per corner.
For tires I recommend Yokohama S Drives in 205/45 or 50 over anything available.
Tires are the most important part of handling and braking in the Miata. Next is going to be alignment and then suspension components. In stock trim the car will be able to out perform anything you will doing with it. Which is why I have kept mine stock w/ 11lbs Konigs for over 6 months.
I will be competing later this year in the Miata Challenge series on just springs and RS3's.
Past Mazdas & Speeds
PapaSmurf (01-09-2012)
 Old 01-09-2012, 02:10 PM   #3
PapaSmurf's Avatar
Originally Posted by Touge Sensei View Post
*damping
on a side note how much does say a stock used LSD go for? or just a LSD in general? Im guessing around $1k?
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-09-2012, 02:11 PM   #4
Neverlift's Avatar
Groans: 1,143
OEM Torsen's can be found for $400 for just the diff/housing. With axles I wouldnt pay more than $600
Easter Bunny (01-09-2012), PapaSmurf (01-09-2012)
 Old 01-09-2012, 02:16 PM   #5
minger's Avatar
Posts: 1,064   (View Stats)
minger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the world
I'll be honest: I have Racelands on my NB, along with a RB FSB (02 Base) and I like it. Not very damp, but a lot stiffer than stock and worked out pretty well for me the few times I autocrossed it.
minger is offline   Reply With Quote
The Following 2 Users Say Thank You to minger For This Useful Post:
mr_mazda329 (03-20-2019), PapaSmurf (01-09-2012)
The Following User Says NO Thank You to minger For This Un-useful Post:
Neverlift (01-09-2012)
 Old 01-09-2012, 02:22 PM   #6
Neverlift's Avatar
Groans: 1,143
Don't come in here recommending Ricelands. Worst thing you can do to your Miata.
If you must have a cheap/decent set of coilovers go with Megan EZ streets. They are monotube and work very well for the price. I don't think you need them though. Wait a couple months... unless your suspension is already blown. I would look into replacing the suspension bushings as well as the diff bushings.
@cpolly69
bigx5murf (02-19-2012), PapaSmurf (01-09-2012)
 Old 01-09-2012, 02:26 PM   #7
PapaSmurf's Avatar
@cpolly69
The suspension seems fine, I am more into just lowering it to get rid of the horrible wheel gap and get a little better handling to boot.
What are some good websites to troll classified sections?
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-09-2012, 02:27 PM   #8
Neverlift's Avatar
Groans: 1,143
ClubRoadster.net Main
Mazda Roadster Forums - Home (new, section sucks for now)
www.miataturbo.net
 Old 01-09-2012, 02:32 PM   #9
/out before papasmurf falls in love with miata and stops building ms3.
 Old 01-09-2012, 03:05 PM   #10
PapaSmurf's Avatar
if any of you guys can keep a look out on some NB suspension shit, let me know if you find a good deal.
thanks
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-09-2012, 03:39 PM   #11
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
here https://docs.google.com/spreadsheet/...COuP2bQC#gid=0
bigx5murf is offline   Reply With Quote
 Old 01-09-2012, 03:44 PM   #12
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
If moneys not problem go with the afcos, hands down the best coilovers for the miata. In fact they were designed specifically for them in every aspect. Had them for the msm.
http://www.flyinmiata.com/index.php?...00%20%20CUSTOM
Sent from my Galaxy Nexus using Tapatalk
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 01-09-2012, 03:49 PM   #13
PapaSmurf's Avatar
Originally Posted by bigx5murf View Post
link no worky
Flyin' Miata : Chassis : Suspension components : Flyin` Miata AFCO suspension
I wish money wasent a problem or i would be driving a GTR. lol
Im thinking about going with Megan EZ-Street coils, seem to be affordable and pretty decent from what I've read.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-09-2012, 03:51 PM   #14
InFeXIoN's Avatar
Lol it works now on your post
Build Complete!!!!
 Old 01-09-2012, 03:52 PM   #15
PapaSmurf's Avatar
must be the stupid government computer im on.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-09-2012, 04:16 PM   #16
InFeXIoN's Avatar
Yea guess coilovers are against policy.
Build Complete!!!!
The Following User Says Thank You to InFeXIoN For This Useful Post:
 Old 01-09-2012, 04:54 PM   #17
Neverlift's Avatar
Groans: 1,143
I would contradict the AFCO coilover recommendation. They are twin tube. That is 30+ year old technology. The air behind the piston causes cavitation. Which is going to cause a much slower reaction over rough surfaces. They are cheap to make and fade much more quickly than a monotube will. I think they should only be used in large commuter cars with soft spring rates.
Monotube are usually aluminum bodied and better in every way despite FM's claim.
I have been in a car with the FM AFCO and they did not perform nearly as well as my Ohlins did. The dual flow valving on the Ohlins was leagues ahead of the AFCO. Length of stroke on the Ohlins is always a topic of discussion but I never bottomed them out, in any condition, ever. Off road included.
I would recommend Fatcat Motorsports custom coilovers long before I would recommend any twin tube to anyone. It should be mentioned even stock Bilsteins are monotube and are known to last beyond 100k.
I would say Xida CS would be the best you can get for under 2500 atm but that is not within the scope of the OP's post.
rfinkle2 (01-09-2012)
 Old 01-09-2012, 06:19 PM   #18
InFeXIoN's Avatar
I never had a problem with them... But fatcat motorsports was going to be my next recc.
Build Complete!!!!
 Old 01-09-2012, 11:12 PM   #19
minger's Avatar
@cpolly69
I have to ask: Have you tried a car with them installed? All I'm saying is that I like mine, and while they may lack a little dampening I am very happy with them.
Beats out the stock suspension on my MS3, but that doesn't say too much.
 Old 01-10-2012, 06:49 AM   #20
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
I've intended to buy the Megan EZs almost since the moment I got my car....
I was ready to get them over the holidays but I got distracted by megasquirt first....
I'm still confident that I'll have them installed and on a decent n/a tune by this summer..
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 01-10-2012, 08:09 AM   #21
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
rob let me know if your interested in these:
Sonic Tuning Coilovers
they make them for the miata too
P.S. your going to have to beat the super sweet yellow SRT4 and that bad ass honda fit if u wanna win at church cross!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 01-10-2012, 09:56 AM   #22
PapaSmurf's Avatar
I'm taking that srt4 down! Haha
Like i said it will be a couple months before coils so I can get the genpu straightened out but those look promising.
Whats the price of the miata coils? $899?
Tapafucku!
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-10-2012, 10:57 AM   #23
Neverlift's Avatar
Groans: 1,143
*damping
Yes I have driven a Miata w/ ricelands & rokkors, they are a fucking joke. Picking the right shock for a Miata, or any car for that matter is very important. You can skimp on anything else but the shock.
You may be happy, but someone the intention of using their Miata for what it excels in, and not a parking lot needs a half way decent set up.
I don't know why I am explaining this. You clearly don't know any better.
Also, before looking at Sonic Motors coilovers, find out where they are built, what kind of warranty they come with, where the warranty claim & rebuild will take place, what spring rates they offer, and the cost of revalving. I would also like to know what spring manufacture they use.
I am not impressed with the lack of information on the valving & piston size. With the plethora of Miata coilover offerings, I would look elsewhere.
 Old 01-10-2012, 01:28 PM   #24
PapaSmurf's Avatar
damping/dampening same shit, stop auto correcting people, shits annoying lol, we airnt in English class, we all know what it means... sorry its a pet peeve of mine.
Im still a couple months from a purchase and will do research before buying anything, but as of right now im leaning towards the megans.
860whp/677wtq
2.7 V6 Ecoboost
Neverlift (01-10-2012)
 Old 01-10-2012, 01:30 PM   #25
Did you watch Bob's video?... it makes me want a miata too.
 Old 01-10-2012, 01:35 PM   #26
PapaSmurf's Avatar
nah...
link please?
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-10-2012, 01:36 PM   #27
http://www.mazdaspeedforum.org/forum/foru...lation-100836/
 Old 01-10-2012, 01:40 PM   #28
PapaSmurf's Avatar
Ill have to check it out when im not at work, since work computer = deathly slow.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-10-2012, 01:42 PM   #29
I have never seen a go pro video in a car that stays that flat.
Try to watch it, and you will be even more stoked about your miata.
PapaSmurf (01-10-2012)
 Old 01-10-2012, 02:34 PM   #30
Neverlift's Avatar
Groans: 1,143
damping/dampening
Since it is a suspension topic it is a pet peeve of mine people not knowing they are not using the right terminology. Dampening is pissing in a diaper. A damper is shock absorber, not a diaper in this context
Like when someone says "I could careless." How much could you careless?
Borderline retarded behavior.
Thanks for the props Fink... please watch it with your own soundtrack. Youtube would only let me use one of their preapproved tracks since I edited it on their site.
Sorry to put a damper on your thread
@aaronc7
PapaSmurf (01-10-2012), rfinkle2 (01-17-2012)
 Old 01-10-2012, 02:57 PM   #31
PapaSmurf's Avatar
just bought my first mod... haha
JBR 5peed shift knob... For some reason the old fucker I bought the car off of had a cheap ass autozone fake carbon fiber shift knob that rattles like a mutha fucker and annoys the shit out of me.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-10-2012, 03:32 PM   #32
minger's Avatar
*damping
Was just asking. At least you have good reason to hate them then; there was a lot of hate for them when they first came out based on pricepoint alone.
 Old 01-11-2012, 08:13 PM   #33
bigx5murf's Avatar
I don't understand people willing to drop a few k to increase whp 20-50%. Yet think <$400 coilovers are gonna put that power down
Anyone miata with sports package has better shocks than the ricelands. They are basically some vato zone monroe shocks w/ adjustable perches, and ebay springs.
As for AFCO vs xidas... I was considering both of these. In the end I decided on xidas for a few reasons. Keith admitted the AFCOs that you can buy are not the same thing the "top drivers" they claim use them. He admitted those guys were using AFCOs with redesigned geometry, something most of us will not be able to copy. If was even brought up, and few of these guys were running the AFCOs inverted.
AST claims what they sell you is exactly what they sell the WC teams, and that the only difference is spring rates and valving.
Regarding the twin vs mono tube argument, FM claims "the implementation is more important than the underlying technology". But, if you do the research, just about every modern motorsport league seems to only use monotubes. This includes F1, wrc, wc, and even NASCAR.
I won't lie, I've thought sometimes I should've went AFCO, since they can ride higher, and were developed on the targa newfoundland, so they MIGHT handle shitty nyc roads better. But keep in mind, the targa car had skid bars and skid plates all over the underbody. So it might not be all the AFCOs.
Most important thing with coilovers imo, is don't try to "set it and forget it". Mess with the heights, mess with the damping, the alignment, get adjustable endlinks and mess with those too. Fiddle with it until it's to your liking. Gotta be really observant with what happenes when you change one thing at a time.
 Old 01-11-2012, 08:58 PM   #34
Neverlift's Avatar
Groans: 1,143
What springs rates? Did you get the dual spring system?
 Old 01-15-2012, 10:37 AM   #35
bigx5murf's Avatar
550f and 350r, yea I got the helper springs, and I'm on stock top hats.
On one of the main highways here, there are these mini speed bumps on it, and going over them at 80, you'll catch a little air, it's not as bad with a passenger. But after these coils, I can feel the wheels hug the bumps all the way through.
I have some pics on another thread here
I think you really need the 949 endlinks to get the most out of them. Without them, the suspension will have a slight solid axle effect if that makes sense.
 Old 02-19-2012, 08:50 PM   #36
littlered's Avatar
Posts: 131   (View Stats)
littlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond reputelittlered has a reputation beyond repute
i have stance coilovers on my miata and love them. they have been on my car for about 2.5 years and still feel great...
littlered is offline   Reply With Quote
 Old 03-26-2012, 09:27 AM   #37
inglouriousbasterd's Avatar
Posts: 111   (View Stats)
inglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud ofinglouriousbasterd has much to be proud of
Groaned at 6 Times in 3 Posts
Originally Posted by Tony says: View Post
*damping
I hate my koni and ground control combo on my '99 nb , every time i take a long trip i wanna pull out my glock and eat a .40 cal. However i drove my friends '99 and I was loving his tein basics , much nicer ride. Any body try the fm v- maxx ?
When you decide to be something, you can be it. That's what they don't tell you in the church. When I was your age they would say we can become cops, or criminals. Today, what I'm saying to you is this: when you're facing a loaded gun, what's the difference?
inglouriousbasterd is offline   Reply With Quote
 Old 03-26-2012, 11:21 AM   #38
Neverlift's Avatar
Groans: 1,143
Vmaxx are pretty shitty too...
The reason you like the basics is because they are ridiculously soft. I doubt OP cares about DD ability.
Monotube or bust. Why anyone would put twin tube shocks on I have no idea.
 Old 07-08-2014, 03:08 AM   #39
pandita's Avatar
Posts: 989   (View Stats)
pandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the world
Megan EZ streets.
Get them.
Love them.
Absolutely no complaints.
pandita is offline   Reply With Quote
The Following User Says NO Thank You to pandita For This Un-useful Post:
Neverlift (07-10-2014)
 Old 07-08-2014, 04:22 AM   #40
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
2 year old thread...
The Following 2 Users Say Thank You to Vader For This Useful Post:
Neverlift (07-10-2014), Playaj (07-10-2014)
Ultimate MPG Discussion... 6SpeedTA95 2010 MS3 - Engine, Transmission & Driveline 27 12-02-2010 08:15 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
1.04 Maps with LC etc Discussion thanox2
Cobb ATR Support
272 08-02-2009 11:56 PM
Haven't found this CBE discussion yet so here goes... jbarbaresi MazdaSpeed 3 - Engine, Transmission & Driveline 23 03-16-2009 04:45 PM
Page generated in 0.60216 seconds with 31 queries
