![]() Join Date: Feb 2016
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I'm pretty pleased with the result: |
| The Following User Says Thank You to tweak89 For This Useful Post: | dale_gribble (02-24-2016) |
| The Following User Says NO Thank You to tweak89 For This Un-useful Post: | Neverlift (02-24-2016) |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Neutral : -1 score Boat anchors on a MSM.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
(Thread Starter) | Not Ranked : 0 score Well my hopes of impressing you are dashed. Hopefully when I grow up I'll as cool as you! |
Groans: 1,143
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() | |
(Thread Starter) | Not Ranked : 0 score No, I really was hoping to impress you! Seriously! |
![]() Join Date: Feb 2015 Location: O-Hi-O
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score As long as you're happy with them... That's all that matters. Now, with that being said. They look fugly as heck.
__________________ 2013 LSM Mazdaspeed 3 Stock ![]() |
(Thread Starter) | Not Ranked : 0 score Now I see why this forum is so highly spoken of! Last edited by tweak89; 02-25-2016 at 07:53 PM. |
Groans: 1,143
| Not Ranked : 0 score Dont like it, then get lost. If you do like it, stick around, but answer the phone next time 2003 calls and wants their time attack striped, 20lb wheels back.
(Thread Starter) | Not Ranked : 0 score Only if you teach me what cool stuff to list in my signature so I can be adored by teh internets! Don't dish it if you can't take it! Sheesh! |
Groans: 1,143
Quality parts for a high performance car that is already loaded with them. Don't replace anything with lower quality than OE. Quality is determined solely by manufacturing processes, materials, and components. If you came to this performance only oriented community expecting unanimous applause for poor decisions, you might have noticed people like me exist. I will tell you the honest truth, because you deserve to know better, you own a Mazdaspeed after all. The rest you asked about comes with tenure and experience, so in due time.
(Thread Starter) | Not Ranked : 0 score Well, just so you know, I have no intention of modding this car into oblivion. Not because I'm not interested in things of that nature, but because I bought this car knowing that I don't need to do much to it, especially since it's purpose is the weekend ride (which I clearly stated in my introductory post). That you don't like my wheels or think that they are too heavy is of no consequence to me as far as how I think about MY car. I wasn't looking for applause, I was simply making a post in the appropriate forum section. I always join a car/motorcycle form relevant to whatever I have at the time to learn things about that particular vehicle. I also know the general nature of internet forums and the folks that populate them,some are helpful, some critical and some fall in between. But, if all your going to do is trash talk, expect some back...in the end it's not really going to affect my life or yours. |
| The Following User Says NO Thank You to tweak89 For This Un-useful Post: | Neverlift (02-26-2016) |
| New Motegi Wheels | Will915 | Wheels & Tires - METRO GREY | 1 | 11-11-2013 04:24 PM |
| Motegi MR116's 18x9 et35 | Jerzees_illest | Wheels & Tires - RED | 13 | 11-05-2013 12:53 AM |
| Motegi SP-10 | JLee1469 | Wheels & Tires - COSMIC BLUE | 15 | 09-10-2012 12:38 PM |
| Motegi MR116 | XxDrakkelxX | 2010 MS3 - Wheels & Tires | 15 | 03-28-2011 06:49 AM |
