![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
(Thread Starter) | Not Ranked : 0 score After doing so I noticed the rear was much more tail happy and had a strong snap over when bringing it back. I was throwing the car pretty hard to setup into each corner in an effort to test the progression of grip threw the corner. In most cases traction would begin to be lost but at a very progressive rate and a slight squeal. This is much quieter then the 195/50 Ecsta AST I was running before but short of the howl the 195/50 Falker 502's have. Corners purposely drifted were done so with much more ease then any tire I have ever used. I was very confident with it, and never surprised so I never had to lift or let off. I noticed my R-package Bilsteins contributing to some of the handling issues probably from being under damped for this tire. However, after I have some actual time on them I will be able to better assess that hypothesis as I usually have trouble with new tires considering they carry their own characteristics. These runs reached speeds of 85+ mph while cornering. This could have also been a bit over ambitious for a new tire and the shocks damping. They are wide for a 195/50. I would say they may even exceed contact patch for some companies 205/50s tl;dr Tires have controllable progression beyond the edge. They regain grip unexpectedly at their current psi at high speed (possible damping issue). Further testing including wet traction and extensive dry traction will be conducted over the holiday weekend.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,777
Groaned at 21 Times in 9 Posts
| Not Ranked : 0 score I am also running these tires. They are lasting longer than the stock dunlop that came with it.
__________________ 2010 Black Mica Mazdaspeed3 MODS in chronological order of installtion AEM CAI, JBR SSP Stage 2, JBR Heavy Shift Knob, JBR 80 Duro Billet Rear Motor Mount, CP-E NVISCID Turbo Inlet Pipe. & COBB AP Debating on Rear Sway Bars, Springs, or internals next... |
![]() Join Date: Jun 2010 Location: Behind the Orange Curtain
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score I have been running these on my z for about a year. One of the best street tires Ive run on that car. Although I am limited on selection by the 205/55/15 requirement so I am not sure how they would hold up against some of the more aggressive tires. I'm looking forward to your report on wet traction(the z doesnt go out in the rain)... |
![]() Join Date: Jun 2011 Location: Conroe, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,698
Groaned at 42 Times in 15 Posts
| Not Ranked : 0 score I ran these on my msm also at the 3 sisters... I was impressed Sent from my HTC Vision using Tapatalk
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! |
![]() Join Date: Mar 2008
Rep Power: 147 ![]() ![]() Thanks: 85
| Not Ranked : 0 score I'm running these tires too a little to much road noise for my taste. |
Groans: 1,143
(Thread Starter) | Not Ranked : 0 score So I took the car out last night since it was raining pretty good. Didn't get to hit up the canyons like I wanted but I got extensive business park, highway on ramp and round-about testing in. I had no problem cruising 80+ comfortably and never hydroplaned or felt unsure of how they were going to react. If I did induce a loss of traction on purpose it could be regained immediately and without much trouble. They are still new so I would be interested to see how they react in the last 30-40% of their lifespan in the wet. I am really loving these in the dry though.
| The Following User Says Thank You to Neverlift For This Useful Post: | InFeXIoN (11-14-2011) |
Groans: 1,143
(Thread Starter) | Not Ranked : 0 score Alright, I put some serious testing on them and I can say they are an incredible tire. I didn't want to stop. I put about 250 canyon miles on them for about 7 hours. Initial bite is quick and crisp and the progression when heading toward a loss in traction is very communitive and not at all surprising. I see no reason to ever switch. I would have no trouble running these on a track day. However, they are tire pressure sensitive. I played with a few different ones and found 34-35 hot is best. They do get greasy but once again you know it and they cool quickly. Only had to let off for a minute or so and it was good to go. This is a quick run to show you how they act on the road.
| The Following User Says Thank You to Neverlift For This Useful Post: | WAHBAM (11-13-2011) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
Groaned at 20 Times in 10 Posts
| Not Ranked : 0 score My friend is running these on his wrx, it's quite easy to 4 wheel spin in the rain with them. I'd consider them more a warm dry weather tire. |
| Not Ranked : 0 score How do these compare to the RS3s you tried on your MSM?
Groans: 1,143
(Thread Starter) | Not Ranked : 0 score Nothing compares to RS3s. These are a 300 treadwear tire. It would be foolish for me to draw a comparison.
| The Runner ![]() Join Date: Feb 2010 Location: Santa Ana, CA
Rep Power: 140 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 353
| Not Ranked : 0 score Hey Bob where was that video taken? Cause i live right next to irvine (tustin) and id love to take my ms3 out there.
__________________ '09 Black Mica [MURDERED] MS3- HyperTech Tuned, CPE rear and side motor mounts, COBB TIP, JBarone Short Shifter Plate and Heavy Shift knob, SU Shifter Bushings, CPE Nano SRI, AWR End Links. WANTED- Radar Detector, Down Pipe, DashHawk, Forge BPV. |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score I contemplated getting these when I was in the market, but after several credible reviews, I decided on the Hankooks. This is still interesting to me for future reference. I'll be trying something else when the V12's kick the bucket. Bob, how's the sidewall? Is it rigid enough to offer sharp steering response and turn in? I lost a small amount of response and slightly less precision on turn in with the V12's. They definitely have more grip than the Potenzas, but are a little mushy on the sidewall. |
Groans: 1,143
(Thread Starter) | Not Ranked : 0 score Nathan, hit me up when you want to go. Either early morning, random weekday afternoons and late at night is when you can actually drive the road. Otherwise you have other motorists, jogger, long boarders, motorcyclists and deer to deal with. Tony, the sidewall is softer then the shitty tires I have been running. I would describe the turn in quick like an RS3 (has a soft sidewall) but doesn't hold the road like them. I need to get a video of me driving so you see how I use the steering wheel in the corners.
| The Following User Says Thank You to Neverlift For This Useful Post: | Dash08 (11-14-2011) |
Groans: 293
| Not Ranked : 0 score In for this. I'd like to see how the car responds to your inputs. Could give a good idea of how they perform. |
Groans: 1,143
(Thread Starter) | Not Ranked : 0 score Cool. I have one now from the same day but you can only see one hand but you may get the idea of the response. Ill host it now
Groans: 1,143
| The Following User Says Thank You to Neverlift For This Useful Post: | Dash08 (11-15-2011) |
| Not Ranked : 0 score Yes these in no shape can compare to some RS-3's.. but for the dry performance and decent in wet, especially for the price.. they are really hard to beat. As bob said the RS-3's treadwear compared to these are no match but the RS-3's stick like glue! I was overall impressed with them myself when i took them out to the 3 sisters for a 7 hour run, and ran them pretty hard.
| Not Ranked : 0 score Yeah I go to UCLA so I'm not in tustin currently but maybe over the break.
![]() | | #19 | ![]() |
| Not Ranked : 0 score I finally used up my s drives. They are so bald that they are leaking out air from a crack on near 1/3 of the thread. I'm trying out the Hankooks V12s now. So far I loved that tire, but the fact that they discontinued them I have to jump ship. On the stock dunlops I had I ruined the inner sidewalls, but with the s drives they showed no wear on the inner sidewalls.
![]() | | #20 | ![]() |
![]() Join Date: Jul 2010 Location: Rochester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,462
Groans: 64
| Not Ranked : 0 score I had s-drives on my civic si back in the day, great tire for spirited driving. They also look great mounted.
__________________ Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Sorry, I just couldn't resist. ![]()
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club Last edited by Nliiitend1; 12-01-2011 at 03:12 AM. Reason: missed the second one the first time... lol. | |
![]() | | #22 | ![]() |
Groans: 293
| The Following User Says Thank You to Dash08 For This Useful Post: | M4Nathan (12-06-2011) |
| Review: Test Drive Unlimited 2 | Haltech | Automotive News | 0 | 02-11-2011 01:30 PM |
| Yokohama AVID ENVigors | sideslide4life | Wheels & Tires - BLACK | 8 | 12-12-2010 05:39 PM |
| Yokohama Avid Envigor Tires | Jujiro_Prodigy_31 | MazdaSpeed 3/6 - Wheels & Tires | 2 | 03-15-2010 03:35 PM |
| Yokohama peels out with orange tire | Haltech | Automotive News | 0 | 12-08-2009 10:20 AM |
| Review: 2009 Mazda MX-5 Miata is still the drive of our childhood dreams | Haltech | Automotive News | 0 | 10-02-2009 10:10 AM |
