> Mazdaspeed Forums Performance Parts Reviews > Review Discussion
Review Discussion Want to comment on a review, do it here.
 Old 12-01-2008, 11:14 PM   #1
Default Cobb Tuning 3" Downpipe
Comments and questions about the review can be posted here.
Boosted333 (05-17-2010)
 Old 12-01-2008, 11:39 PM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Looks good. About time you get your hands dirty, my favorite picture is the one of the threadless stock O2 sensor. I'm assuming the heat shield goes back on top of the dp, shape...such a niece looking piece of hardware.
 Old 12-02-2008, 12:02 AM   #3
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Excellent review as always.
Let us know when you start smoking.......
Suspension:
 Old 12-02-2008, 12:07 AM   #4
5/40 brotha, no smoke in sight!!
 Old 12-02-2008, 08:21 AM   #5
mtlms3's Avatar
Posts: 143   (View Stats)
mtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond reputemtlms3 has a reputation beyond repute
Default Sensor
Maybe I missed it, but do you have the bosch part number for the sensor that was lunched?
mtlms3 is offline   Reply With Quote
 Old 12-02-2008, 10:15 AM   #6
No, but ill post it for you.
 Old 12-02-2008, 08:49 AM   #7
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Is there supposed to be a review here? Why can't I see it??
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 12-02-2008, 10:55 AM   #8
LBV
LBV's Avatar
Found the review ... now THAT'S the way a how-to should be written. Well done!
The Following User Says Thank You to LBV For This Useful Post:
Haltech (12-02-2008)
 Old 12-02-2008, 11:04 AM   #9
F00E262571 - BOSCH
The Following 3 Users Say Thank You to Haltech For This Useful Post:
doubleflusher (03-12-2009), LBV (12-02-2008), mtlms3 (12-02-2008)
 Old 12-02-2008, 12:33 PM   #10
mtlms3's Avatar
F00E262571 - BOSCH
Awesome, thanks!! I'll be sure to order one before I start a DP install.
 Old 12-02-2008, 10:20 PM   #11
PCspeed3's Avatar
Posts: 55   (View Stats)
PCspeed3 will become famous soon enoughPCspeed3 will become famous soon enough
So is a narrow band sensor even neccessary? I saw that you just plugged yours and it worked out. Any CEL's with no sensor? very nice write up by the way, I may be going down to Cobb to get the turbo back for Christmas......=)
Edit: Sound clips! Sound Clips! Sound Clips!
PCspeed3 is offline   Reply With Quote
 Old 12-03-2008, 01:29 AM   #12
It threw a CEL the second time i cranked the car over. The car didnt act odd, nor did it exhibit any power loss. I had done a log prior and after, everything looked fine.
Now, on Fords, the rear 02's are for 1996+ OBDII compliance only. So, since they arent heated, their only job is to report a rear section converter failure. Ive heard people say that the car tunes off the narrow band, opposed to the wideband, but i also find this hard to believe since mazda chose to do a wideband up top, prior to the first converter. They could of saved a lot of money and used a narrow band there too.
CowboyMS3 likes this.
 Old 12-04-2008, 04:29 AM   #13
Speedy3's Avatar
Posts: 298   (View Stats)
Speedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the world
I see you didn't pre-twist the WB O2 sensor before threading it in......
Nice write-up btw. A couple things i'd add is to how to remove the stock DP top heat shield before removing the DP-turbo studs. It can be done, just have to find the right angles. Also, I use cooking Pam spray on the lower rubber mounting grommets to help remove/install the DP hangers.
2007 MAZDASPEED 3, MS CAI, MS CBE.
Speedy3 is offline   Reply With Quote
 Old 12-04-2008, 08:10 AM   #14
Pam is the last thing you want to use... PB blaster or WD40 will work. I was in a hurry the second go around and didnt snap pics of the top heat shield.
What do you mean i didnt pre twist the 02 sensor? You can even get it started without doing so.
 Old 12-04-2008, 08:27 AM   #15
Speedy3's Avatar
Pam works perfect on the rubber hangers. I'm not talking about the DP studs.
The picture shows the wires all twisted up. Why are you being so defensive?
 Old 12-04-2008, 10:36 AM   #16
You didnt specify wires, you said i didnt thread the O2 before tightening it down, which is incorrect info.
Im really not to concerned with the wires being straight man. I really dont understand why you are being critical about it.
 Old 12-04-2008, 09:31 AM   #17
LBV
LBV's Avatar
I think the comment about twisting the O2 wires is that you need to pre-twist the O2 in a counter-clockwise rotation BEFORE actually twisting it into the bung. That way when you're fully rotated clockwise (ie. tightened) the wires are atleast reasonably straight.
 Old 12-04-2008, 07:14 PM   #18
xandrake's Avatar
Posts: 575   (View Stats)
xandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the world
He's not being critical, just offering insight to people who might not pay attention and pull wires too tightly.
Thanks for this write up! It's going to help me a ton with my install in the next few weeks.
xandrake is offline   Reply With Quote
 Old 12-09-2008, 11:31 AM   #19
GFish's Avatar
Posts: 286   (View Stats)
GFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond reputeGFish has a reputation beyond repute
how about them audio clips lol... cant wait till you get a chance to make them looking foward to it
__________________________
2008.5 Mazdaspeed 3 GT Crystal White Pearl Mica
mods:30% tint front 2 windows 20% all other windows, clear bra on front and custom peace covering rear bumper, corksport mm inserts, and some other good stuff
GFish is offline   Reply With Quote
 Old 12-09-2008, 07:28 PM   #20
CWPspeed3's Avatar
Posts: 51   (View Stats)
CWPspeed3 is an unknown quantity at this point
Thats one of the best reviews/ how-to's I've ever seen, kind of scared me away from trying to do a downpipe myself though, the price is the other part that scared me away.
CWPspeed3 is offline   Reply With Quote
 Old 12-12-2008, 08:39 PM   #21
PCspeed3's Avatar
Hal, where did you buy your Bosch O2 sensor? thanks
2009 CWP Speed3
~Disco Potato~
 Old 12-12-2008, 08:56 PM   #22
EDO ordered it for me locally from their distributor. Whomever sells Bosch, can get you that sensor.
 Old 12-14-2008, 07:03 PM   #23
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
so the torque for the downpipe bolts is anywere from 38 too 51 ft lbs???
also is it pointless to get the cat back because the downpipe goes down to 2.5" anyway???? is the stock catback restrictive??
 Old 12-14-2008, 07:09 PM   #24
it only necks down there to get a good seal on any catback thats on the market. Lots of people prefer to use the stock cb which is 2.5 inch and this slight neck down, allows a good seal. It hardly makes it anymore restrictive then your stock exhaust. Its not a huge drastic neck down as you can see in the pictures.
 Old 12-14-2008, 07:18 PM   #25
18psiWhiteMS3
Lurkers
Posts: n/a
how much hp can i expect from this turboback exhaust. in combo with the cobb sri
 Old 12-14-2008, 07:20 PM   #26
Depends on the tune honestly.. Anywhere from 30-50 hp.
 Old 12-14-2008, 07:23 PM   #27
18psiWhiteMS3
Lurkers
Posts: n/a
in the summer i plan to add exactly what i have posted in my signature, cobb inlet, cobb sri, cobb turboback, hks bpv. No tuning though. Just bolting on these things. si im looking at more like 30 whp?
 Old 12-14-2008, 07:25 PM   #28
Cant really tell you. each car is difference. By summer time, we will have an onslaught of tuning options, so i would reconsider your tuning option.
 Old 12-14-2008, 07:32 PM   #29
18psiWhiteMS3
Lurkers
Posts: n/a
then in the summer i will be doing alot of research. lol i only have 150 miles on my car and i already have a wish list
 Old 12-14-2008, 07:32 PM   #30
You and 90% of the rest of us. lol
 Old 12-14-2008, 07:46 PM   #31
xandrake's Avatar
I had my SRI on within the first 50 miles. :X
 Old 12-14-2008, 08:22 PM   #32
18psiWhiteMS3
Lurkers
Posts: n/a
i wanna put at least 3000 miles on my car to make sure i dont have a lemon before i start modding
 Old 12-15-2008, 06:00 PM   #33
ms3jake's Avatar
Posts: 695   (View Stats)
ms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the world
To anyone's knowledge has anyone blown their Ms3 motor from having an intake and downpipe/midpipe as their only mods, no tune(not due to factory motor defect) I mean solely from the downpipe?
ms3jake is offline   Reply With Quote
 Old 12-15-2008, 07:40 PM   #34
18psiWhiteMS3
Lurkers
Posts: n/a
with cobb i dont think u have to worry cause the back pressure from there downpipe will prevent booost spikes i think.
 Old 12-18-2008, 02:04 PM   #35
PCspeed3's Avatar
So I have been hunting around for that damn 02 sensor for a week now and I cant seem to find it. So I called Bosch directly today and they gave me the part #13770. Hal, is there anyway you could maybe check the box that your sensor came in and look for this part number? im 90% sure that part number that Bosch gave me is the one I need. Thanks.
2009 CWP Speed3
~Disco Potato~
 Old 12-18-2008, 03:12 PM   #36
The number i listed is what the box said.
 Old 01-03-2009, 07:58 PM   #37
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
i just want to state, Haltech, that the bosch number you listed is a production number the actual part number is 99.9% of the time a 5 digit number i have it written down on my tool box but 13770 sounds correct actually, the 5 digit number is how to order it, most of the time a production code won't cross over in their system at said auto parts store.
fbpem1 is offline   Reply With Quote
 Old 03-21-2009, 12:11 AM   #38
dubi0us's Avatar
Posts: 30   (View Stats)
dubi0us is a jewel in the roughdubi0us is a jewel in the roughdubi0us is a jewel in the rough
Default Car demands blood.
At recommendation of machine shop next door I used a product called 'Aerokroil' sprayed it on all of the nuts/bolts that needed to be removed and waited an hour. By the time I came back, all of the nuts (that I could reach) came off with no force at all, including both O2 sensors. If you live next to a machine shop and are doing this install I'd highly recommend seeing if they have any you could borrow or spray into a cup to brush on. All went smoothly except for the front bottom nut on the DP flange, that fucker cost me an hour just trying to come up with the right socket/extension combination. Once I cracked it a little loose it spun right off, but shit I tried the wobble extension, the universal socket, 1/4" drive, 3/8" drive, short sockets and long sockets. I finally gave up on the wobble/extension combo and took off the heat shielding from the exhaust manifold and put the ratchet between the exhaust ducts. Sadly I ran out of light, will have to finish tomorrow, but it seems downhill from here(please Murphy don't smite me!)
Things to do:
1) Your mom
2) Your sister
Cobb AP, SRI, TBE, TI, FMIC, Forge BPV, SU MM
Stage 2+ 91 FMIC v103 FTW (Damn Hawaii and there lack of good pump gas!)
dubi0us is offline   Reply With Quote
 Old 04-26-2009, 08:28 PM   #39
18psiWhiteMS3
Lurkers
Posts: n/a
how do you tq the bottom flange bolts cause all u can use is a open end wrench. i mean i tightended them good but i know they arent as tight as the top 3 i got the tq wrench on.
also mine were not locking type nuts. as soon as i loosened them they all came off by hand.
 Old 04-26-2009, 08:42 PM   #40
If you go from underneath the car, you can get to them with a socket.
"Standback Tuning For Dummies Guide" The Official Q&A... AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 929 06-19-2012 10:07 AM
Cobb Tuning Mazdaspeed 3 Downpipe: Haltech MazdaSpeed 3/6 - ECU Computer Tuning 40 03-06-2009 06:16 AM
Cobb Tuning 3" 07-08 MazdaSpeed3 Street Downpipe Review Haltech Mazdaspeed Forums Performance Parts Reviews 0 12-01-2008 03:08 AM
COBB 3" Stainless Steel Downpipe for MazdaSpeed3 Now Available Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 8 11-18-2008 07:41 AM
Page generated in 0.55541 seconds with 32 queries
