| Review Discussion Want to comment on a review, do it here. |
![]() Join Date: Apr 2017
Rep Power: 0 ![]() Thanks: 19
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score do a boost leak test, a visual inspection doesn't do much.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
| The Following User Says Thank You to GroceryGtr For This Useful Post: | arnold600 (07-06-2018) |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| You need a real tune. Cobb's OTS maps are pretty shitty.
| The Following User Says Thank You to Vansquish For This Useful Post: | arnold600 (07-06-2018) |
![]() Join Date: Jun 2009
| Not Ranked : 0 score You're right, but he should be seeing 15 psi or a bit more, even with that shitty map. He does need to do a true boost leak test. He may also want to check vacuum lines on his elrctronic boost control. They get hard and get little splits almost invisible over time.
| The Following User Says Thank You to MSMS3 For This Useful Post: | arnold600 (07-06-2018) |
| Not Ranked : 0 score IMo, you don't play with the tune before being sure the mechanic is in shape. -Boost leak test -Engine compression/ leak test Then if everything is fine, you can start to play with it. It could be a cheap intake/bad maf (or bad maf cal. in the tune) that read too much g/s and drop the boost because the target load number is reached...But if you fix it by a tune and then find and fix a leak, you will need another tune to avoid overboost.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 07-06-2018 at 09:02 AM. |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | arnold600 (07-06-2018) |
(Drilling tiny holes in the vac lines was a cheap and easy trick in the old days to increase boost with cars without boost control...)
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
(Thread Starter) | Not Ranked : 0 score FOUND THE ISSUE. So I unplugged my boost control solenoid to diagnose where the issue was. I.E., if unplugging the solenoid still yealded low boost, I would have a turbo piping leak, but if I made boost, I would have a bad boost control solenoid. So, sure enough, a small pull generated 20lbs of boost. DEFINITELY engine destroying territory. So im going to measure the resistance of the BCS, and if its in spec im going to do some wire hunting.. Thanks for everyones suggestions and help. |
| Not Ranked : 0 score Unplugging (electrically) the BCS should result in spring pressure boost (about 10-12psi). Unplugging either hose to the wastegate is an easy way to go really fast for a very short period...read ZZB.
(Thread Starter) | Not Ranked : 0 score Definitely, It was just a quick test. I unplugged the BCS wire and only got 8psi, I also did a data log with it plugged in and i see a signal being sent and received. So i believe the wiring is good. I ordered a new BCS, so hopefully the issue gets resolved. |
| Not Ranked : 0 score what do you mean by login a signal being sent and received ? How did you confirmed the feedback ?
| Not Ranked : 0 score I would agree that 8psi (with unplugged wires) comfirms the electrical is good, but 8psi is too low for spring pressure. Unless that falls within manufacturing tolerances of wastegates and Mazda said "IDGAF, the ECU can figure it out."
| Not Ranked : 0 score Spring pressure should be maxing at 10-11 psi. I still think he has a boost leak somewhere. OP should post that data log he did. Might prove helpful, depending on which parameters he was monitoring and how he did the log.
Groans: 111
| Not Ranked : 0 score We can only tell if you post a log. It may be a boost leak, or it may be the turbo (it was the case for a local which I was tuning, he bought the car with the wrong chinese turbo replacement).
| Low boost issue | nicknguyenle | 2010 MS3 - Troubleshoot/Diagnostics | 4 | 02-05-2018 08:30 AM |
| Over Boost Issue, Boost leak? | vincentspeed3gogh | MazdaSpeed 3/6 - ECU Computer Tuning | 23 | 12-27-2014 02:31 AM |
| Need Help with a possible Boost Cut issue??? | EddyV1987 | MazdaSpeed 3/6 - Big Turbo Builds | 7 | 04-24-2013 04:24 PM |
| Boost issue | sriser66 | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-19-2013 10:40 PM |
