MAZDASPEED Protegé
> MSP - How-To's
 Old 06-24-2010, 09:43 PM   #1
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Default How To: Polish Aluminium
Here is a how to that I am epic copy/paste-ing from another forum..
This takes a LOT of time.
I have managed to figure out how to make it take less.
Take one of these
Apply only medium pressure and low speed. It will get all the shit and most of the bumps off the surface.
WEAR A FUCKING MASK --- WEAR A FUCKING FACE MASK --- PROTECT YOUR LUNGS!!
Then Next step is a Palm sander.
Use 220 Grit, 400 Grit, 800 Grit, 1500 Grit, then 2000 If you can get it.
800 - 2000 should be done in a sink with water running over the surface (WET SANDING) this will remove all the bits that are coming off that are trapped under the paper, because they are bigger than the grit, they will mar the surface and clog the paper. Your paper will last 10 times longer and the result will be awesome.
Do not be afraid to do some parts by hand, do not let the sander hit the surface, it will Pitt and make more work for you. Work slowly, it will make this faster in the long run..
This and...
You can mount the wheel on a Bench grinder or a 15,000 RPM angle grinder.
I have done both, the angle grinder is more effective AND MORE DANGEROUS, THUS EXCITING.
MAKE SURE THE PART IS SECURE ON A TABLE (Not Silly Clamps)
The Polish is what makes it shine, not the wheel. With rubber gloves, apply the polish to the surface, do not bother to clean it off the hand, start buffing, when the polish is gone then apply more and buff, apply, buff.
You will see it go from smooth to smooth and polished.
After all that, grab some good quality paper towel and do a hand buff with the polish.
DONE
The Following User Says Thank You to Brian MP5T For This Useful Post:
EnzoR (08-04-2010)
 Old 07-30-2010, 11:07 PM   #2
1bad2k's Avatar
Posts: 22   (View Stats)
1bad2k will become famous soon enough1bad2k will become famous soon enough
Nice write up... or copy/paste anyways lol
1bad2k is offline   Reply With Quote
 Old 08-04-2010, 07:59 PM   #3
Brian MP5T's Avatar
It's my Copy paste so I think it's fine to copy paste the shit from a different forum.
 Old 08-04-2010, 08:02 PM   #4
5.000000yeah
ridenfish39's Avatar
Posts: 1,269   (View Stats)
ridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the world
Groans: 44
Groaned at 30 Times in 18 Posts
Unless you want to repolish frequently make sure to clear coat after wards.
2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL
ridenfish39 is offline   Reply With Quote
 Old 11-04-2010, 09:57 AM   #5
Corvette Tuner's Avatar
Posts: 404   (View Stats)
Corvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the world
Cool, thanks for the info.
Corvette Tuner is offline   Reply With Quote
Volk TE37 full polish tomsnatchez Wheels & Tires - BLACK 37 08-13-2011 04:04 AM
Claybar, Polish and wax! Andrew85 Appearance - BLACK 24 12-02-2010 10:47 PM
Fiat Powertrain Technologies to buy General Motors stake in Polish engine plant Haltech Automotive News 0 02-03-2010 07:30 AM
Dealer ads polish Ford image Haltech Automotive News 0 01-31-2010 10:10 PM
How To Replace HID Bulbs, Mercedes E350W Won't Shift Properly, Chevy Nova Fuel Gauge Problem, How To Polish Headlight Le Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.25517 seconds with 23 queries
