  • 1 Post By Playaj
  • 1 Post By coopsspeed
 Old 12-01-2012, 02:11 PM   #1
sxshep's Avatar
Posts: 155   (View Stats)
sxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the world
Default Before and after, side molding
Pretty common mod, but just figured I'd show before and after for those using the "thumboverthecomputerscreen" method.
Also after a bath but you get the point... Just used a heat gun and dental floss, and fingernails to scrap off the gunk. Took maybe 10 minutes
COBB ACCESSPORT JBR RRM CORKSPORT SRI/TIP JBR SSP/BUSHINGS
sxshep is offline   Reply With Quote
 Old 12-01-2012, 02:13 PM   #2
HavasuSpeed3's Avatar
Posts: 243   (View Stats)
HavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the worldHavasuSpeed3 is the leader of the world
Also after a bath but you get the point... Just used a heart gun and dental floss, and fingernails to scrap off the gunk. Took maybe 10 minutes
Those damn heart guns, sometimes overkill though.
2011 MS3, HTP 3.5 intake/TIP, 51R battery box, Treadstone TR8L w/ Protégé Garage Piping, Autotech Internals, UR catless DP and test pipe, AP V2 (RichTuned 3:9 E85) ITV22 plugs. Vanilla scented air freshener.
HavasuSpeed3 is offline   Reply With Quote
 Old 12-01-2012, 03:08 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
I think I'm alone in this, but I like the genwin side molding.
 Old 12-01-2012, 04:10 PM   #4
Boostman07's Avatar
Posts: 229   (View Stats)
Boostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond repute
I'm with you on that one. Less door dings ftw.
tappy tap
09 MS3 GT
Fully Bolted
50/50 e85 Richtune
Boostman07 is offline   Reply With Quote
 Old 12-01-2012, 04:12 PM   #5
leon78's Avatar
Posts: 2,595   (View Stats)
Deff looks way better....every speed needs this.
2013 Scion FR-S (Whiteout)
Less parking more racing
 Old 12-01-2012, 06:35 PM   #6
sxshep's Avatar
tappy tap
I wasn't going to remove them, but the moldings only protect if someone in my vehicle were to open their door and hit a vertical post, like found at gas stations. They don't do anything for other vehicles hitting my doors. Neither matter to me, I park at the end of lots and make sure my passengers aren't jackasses lol
 Old 12-01-2012, 06:53 PM   #7
sxshep's Avatar
It was a PITA washing, drying and waxing around them too... After I took them off I was shocked how much dirt had accumulated
 Old 03-11-2013, 11:07 PM   #8
keychain12's Avatar
Posts: 239   (View Stats)
keychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the worldkeychain12 is the leader of the world
Looks nice!
ATP GTX2867r | CP-e 3" catted TBE | HTP 3.0" Full inlet & intake | CX Racing piping w/ Treadstone TR8 FMI | HPFP | EGR Delete | Grimmspeed EBC | Forge V2 BPV | Thermal Intake Gasket | NGK Plugs | 3.0 bar Map | Devils Own WMI w/ d07 Nozzle | Cobb AP
Dynojet Dyno:
92 pump gas tune: 326whp & 320tq
24psi tune w/ WMI: 349whp & 351tq
26psi tune w/ WMI: 360whp & 364tq
XXR 531 18x8.5 [+35mm] | Dunlop Sport 225/40 | Cobb Springs | JBR Rear camber arms | JBR 80 RMM | Hotchkis front & rear SB| SS brake lines | Corksport CC | MSD Dashhawk |Custom Stealth Sub Box by user: JTMS3
Last edited by keychain12; 03-12-2013 at 11:13 AM. Reason: Cause I'm dumb and didn't read
keychain12 is offline   Reply With Quote
 Old 03-12-2013, 12:00 AM   #9
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Read first post, 10 mins. Like it better on
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 10-15-2013, 01:28 PM   #10
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Sorry if this is reviving a dead thread but anyone know anything about repairing this sidemolding? All I'm finding is removing it but I like it on. Mine is coming off and gets worse everytime I open the back door.
Excuse my errors: Sent from my iPhone using Tapatalk
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline   Reply With Quote
 Old 10-15-2013, 01:32 PM   #11
ozzmannt's Avatar
Posts: 167   (View Stats)
ozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud ofozzmannt has much to be proud of
Stop opening the back door Once it's bent I don't think it will ever sit right again, I would remove.
07 Speed6 GT (Liquid Platinum Metallic) - 35/20% Tint
ozzmannt is offline   Reply With Quote
 Old 10-15-2013, 01:42 PM   #12
manila's Avatar
Posts: 1,767   (View Stats)
@Spectrum24x; Try using double-sided tape on the end that is not attached to the car. If you do this, then the molding itself will probably not sit flush like it once was.
If that doesn't satisfy you, you can always remove the molding completely and take a heat gun to shapen it back to its normal state.
'12 MS3 Black Mica w/ Tech
 Old 10-24-2013, 07:53 PM   #13
aaron88's Avatar
Posts: 277   (View Stats)
Just remove the ding guards sine they are already peeling up, makes the doors and car as a whole look so much better.
'08.5 CWP MS3 GT
aaron88 is offline   Reply With Quote
 Old 10-26-2013, 05:58 PM   #14
Playaj's Avatar
I instantly wished I hadn't taken mine off when I did but I got used to it
Spectrum24x likes this.
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 10-27-2013, 02:01 AM   #15
Put a dab of superglue and seems good as
New
 Old 10-27-2013, 10:47 AM   #16
coopsspeed's Avatar
coopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond repute
Mine starting to peel up but wasn't sure of the look without them but now seeing it I have to do this. Jealous of the white as well!
sxshep likes this.
2007 Black Mica Speed3
speedperf6rmanc3 built short block >> Manley H-beam rods >> Wiseco pistons >> BNR stage 1 >> Cobb sf intake >> Corksport TIP >> ISC coilovers >> Autotech hpfp >> Forge V1 BPV >> jbr stage 2 occ >> jbr 88d RMM >> UR tp >> CNT cat back exhaust >> Cobb AP >> Richtuned by Anthony
coopsspeed is offline   Reply With Quote
 Old 03-06-2014, 09:29 AM   #17
ms3steeez's Avatar
Posts: 312   (View Stats)
ms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the world
Did yours leave the yellowish tint where the strips were? I want to do this so bad, but when I removed my emblems, they were noticeably yellow underneath.
Sent from my VS980 4G using Tapatalk
FreekTuned GT3076R, M2 catless DP, CS HPFP internals, Custom 3.5" intake, Custom 51R battery box, Grimmspeed 3 port EBCS, CS shifter bushings, RA mudflaps, TurboXS core w/ custom piping, Devils Own 100% meth injection, JBR 88 RMM, Denso ITV22, CPE Safeseals, JBR EGR delete, Forge V1, Hawk HPS pads, VCTS Delete, 3 bar map sensor, kozmic primary EGR delete (391 whp on Vdyno, ZZB 12-17-14)
Build in progress
.020 over block, pinned and keyed, wiseco pistons, manley H beams, SP63 head w/ intake and exhaust ports, and mild bowl work. DM TB spacer, L19 studs, XSpower V1 mani, CNT catback, ACT 6 puck w/ streetlight flywheel, CS injector seals, Clevite main and King rod bearings, redefined performance PCV plate, PTP oil pan baffle w/ JBR BSD, 4 bar map sensor
ms3steeez is offline   Reply With Quote
 Old 03-12-2014, 10:32 AM   #18
smelvinwrong's Avatar
Posts: 150   (View Stats)
smelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond repute
Groaned at 3 Times in 1 Post
Interested in this as well, I don't want to remove the side molding if it will leave some uneven discoloration since it's been on there ever since 09
smelvinwrong is offline   Reply With Quote
 Old 03-12-2014, 12:12 PM   #19
jtday's Avatar
Posts: 650   (View Stats)
I have a CWP and you could definitely see the yellow underneath after removing them, although it wasn't that noticeable if you weren't looking directly at it. It eventually faded and now you can't see it. I just went out to verify and I cannot see any yellow.
I also removed them under fluorescent lighting so that likely had to do something with bringing out the yellow. Just my observations.
2009 MS3 GT
 Old 03-12-2014, 12:18 PM   #20
ms3steeez's Avatar
Thanks, I may wait until winter. It's usually so dirty it wouldn't be noticeable anyway lol
Build in progress
 Old 03-13-2014, 09:05 AM   #21
How long after you had the car did you do it? Was it just recent that you removed the side molding?
 Old 03-13-2014, 03:18 PM   #22
jtday's Avatar
Bought it Oct 2013 and removed the moldings shortly thereafter.
2009 MS3 GT
 Old 03-13-2014, 03:19 PM   #23
K tkanks. Guess ill just do it and give it a try. Hope any yellow residue eventually fades
09 CWP Speed3
COBB SRI / CPE RMM / TWM Short Shifter / Apex'i Turbo Timer
 Old 03-16-2014, 01:32 PM   #24
sxshep's Avatar
I did notice some yellow, but that may be due to applying heat to remove them with a heat gun... Or may not, just a theory. It was hard to notice unless you were really close, but now I can't even tell. I've clay barred twice since I've removed them, and also have used the Valugard ABC Neutralization process to remove some rail dust and I'm pretty sure that's what took care of the tarnish. I'm gonna have to do the ABC process again this year, can't ever seem to get rid of the f**king rail dust since it keeps coming back every winter!
 Old 03-16-2014, 04:49 PM   #25
Lol rail dust must be a pita as a preventative measure. I can't imagine worrying about future rust problems onto of everything else. I'll let you guys know how it turns out after I do it, maybe next weekend
09 CWP Speed3
how to remove side molding? MSP611 MazdaSpeed 6 - How-To's 21 07-14-2010 08:49 PM
Discoloration - Side Molding Removal JeffM Appearance - WHITE 9 06-26-2010 08:20 PM
Removing side molding on an '07 BolvangaR Appearance - BLACK 31 04-20-2010 04:13 AM
How to remove Side Molding Residue? felt MazdaSpeed 3/6 - Appearance 45 03-19-2010 09:57 PM
Page generated in 0.43413 seconds with 34 queries
