> MazdaSpeed 3/6 - Appearance > Appearance - Exterior > Appearance - COSMIC BLUE
Appearance - COSMIC BLUE All appearance mods for cosmic blue cars
 Old 09-16-2011, 12:59 PM   #1
sdiegel5's Avatar
Posts: 265   (View Stats)
sdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the worldsdiegel5 is the leader of the world
Neutral  :  -1 score
Default H&R springs finally !
I am finally getting my springs put on tonight ! will post pics
2008.5 MGM MazdaSpeed 3
GT3076R EWG // JBR Whale Penis //AFI TURBO T3 44mm EWGEx Mani // SURE Countershift
SURE Anchors // SURE Rear Sway Bar // SURE 10mm Standoffs
Speedform6manc3 Oil Breather Cap // JBR 88Duro Fully Mounted // Tial MV-R 44mm WG
Cobb AP V3// Turbosmart dual port bov // ATP DownPipe // Ksport Coilovers
Cp-e Injector Seals // Cobb EBCS // Rally Armor UR Mud Flaps // HTP Battery Tray
Autotech HPFP INTERNALS // DG Motorsports Front Lip // 3.5bar map/PnP harness
TWM Short Shifter // TWM ShitBoot // TurboXS FMIC // EBC Red Stuff F/R Pads
Techna-Fit SS Brake Lines // CNT Racing CBE // ARP 12mm Extended Wheel Studs
CP-e Center Dash Gauge Pod // Prosport JDM SERIES Oil Press Gauge // Prosport JDM SERIES EGT Gauge
Prosport JDM BOOST Gauge // StopTech F/R Slotted Rotors // Enkei Fujin 18x8 +40
SPC Rear Camber Arms // NGK Step Colder Plugs // DevilsOwn Meth Kit
88mm Wiesco 9.5:1 Forged Pistons // Eagle H beam Rods // ARP2000 Rod And Main Studs
ARP l19 10mm Headstuds // Cometic HeadGasket // JBR Oil Baffle // JBR BSD
Kosmic Vented OCC // Kosmic Full EGR Valve Delete // COBB Front Sway Bar
sdiegel5 is offline   Reply With Quote
KONI Yellows w/ Cobb springs & stock springs Fobio MazdaSpeed 3/6 - Suspension & Brakes 9 08-20-2012 08:24 PM
H&R springs, rub? shawn. MazdaSpeed 3/6 - Suspension & Brakes 14 07-14-2011 09:15 PM
NEW TIRES AND SPRINGS...FINALLY. flocheef MazdaSpeed 3/6 - Suspension & Brakes 0 02-10-2011 11:27 AM
H&R Springs V.S. Roadmagnet Springs michaeljp MazdaSpeed 3/6 - Suspension & Brakes 16 02-22-2010 09:07 AM
Page generated in 0.33529 seconds with 27 queries
