| Appearance - COSMIC BLUE All appearance mods for cosmic blue cars |
![]() Join Date: Sep 2014 Location: Bullhead City, AZ
| Not Ranked : 0 score All I did for my side turn signal assembly is carefully cut the lamp housing where the edge of the bowl meets the plug receptical. There is standard 194 bulbs inside and I replaced mine with a Polar G Bulb then used epoxy to seal it back up. Turns flash bright white with slightly blue tint. Matches my front and rear turns. |
| Driver's turn signal - flashes on alarm but doesn't work with turn signal? | xcoldricex | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 03-23-2014 08:50 PM |
| Side view mirror turn signal cover | Jra2011speed3 | Exterior | 1 | 12-17-2012 12:00 PM |
| Side Markers as Turn Signals/Hazard....with LED Side Markers | meelo88 | MazdaSpeed 3/6 - Car Audio & Electronics | 27 | 08-01-2011 09:23 PM |
| HOW-TO : Install Side Markers as Turn Signals with LEDs on MS6 And Mazda 6 | meelo88 | MazdaSpeed 6 - How-To's | 12 | 08-01-2011 09:20 PM |
| Driver side turn signal not working | manofhonor24 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 07-08-2010 12:12 AM |
