> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - RED
Wheels & Tires - RED Wheels & Tires on red cars.
 Old 03-28-2019, 09:50 AM   #1
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
Originally Posted by reynellflores View Post
Glad is working for you!
So how much clearance you think you have on the front? I suppose it is tight since you are not using spacers?
I’ve got about 10mm between the shock body and rim and about 5mm between the bead protection of the tire and the shock body. The little rubber “hairs” would touch but no rubbing.
If I were running coil overs I would need likely a 10mm spacer.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
17x9 trm c3 speed3sailor Wheels & Tires - SILVER 7 10-06-2014 06:41 AM
17x9 +35 StevenW 2010 MS3 - Wheels & Tires 16 09-04-2014 06:40 AM
17x9 +45 with 255/40 TWOptSL0W MazdaSpeed 3/6 - Wheels & Tires 19 07-16-2012 02:43 AM
Page generated in 0.22088 seconds with 22 queries
