> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - RED
Wheels & Tires - RED Wheels & Tires on red cars.
Like Tree3Likes
  • 1 Post By theurgy
  • 1 Post By rfinkle2
  • 1 Post By mrsmith
 Old 04-23-2013, 01:41 PM   #1
volcomcinematic's Avatar
Posts: 274   (View Stats)
Default Another plastidip thread
Did the center caps gold..for a little something different. Probably will be bored of this in a month or so..the beauty of plastidip.
Pd tuned.
09' true red GT
 Old 04-23-2013, 06:06 PM   #2
trixms3's Avatar
Posts: 424   (View Stats)
trixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the world
Looks good
sent while pressing send....I SAID SEND!! SEND IT NOW
Sonic Tuning CO's//JBR rear camber arms//JBR 3.5" WP//Cobb FMIC piping w/ Treadstone TR6 core//Turbosmart dual port bpv//Autotech HPFP//(unbranded) DP//straight pipe axleback// Cobb AP V3// FREEKTUNE
trixms3 is offline   Reply With Quote
 Old 06-18-2013, 08:39 PM   #3
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
you went from silver to grey?
yea yea - i know i cant spell
The Following User Says Thank You to :: Gusto :: For This Useful Post:
deekspeed (06-25-2013)
 Old 06-20-2013, 07:32 AM   #4
do they make grey plasti dip? They are black. I had a shitty cell phone at the time , that and the flash was on.
Pd tuned.
09' true red GT
 Old 06-20-2013, 10:44 AM   #5
trixms3's Avatar
They make a silver metalizer and also a gun metal gray
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
The Following User Says Thank You to trixms3 For This Useful Post:
rfinkle2 (06-23-2013)
 Old 06-23-2013, 10:27 AM   #6
theurgy's Avatar
Posts: 2,580   (View Stats)
They also now have a Metallic Anthracite.
The Following User Says Thank You to theurgy For This Useful Post:
 Old 06-23-2013, 10:55 AM   #7
I'm really starting to like what the guys are doing on the plasti-dip forums. Some of the cars these cars are turning out are really nice.. and being able to simply peel the coating off is soooo appealing.
DipYourCar.com Plasti Dip Community Forum
BTW, car looks great OP.
volcomcinematic likes this.
 Old 06-23-2013, 04:48 PM   #8
mrsmith's Avatar
Posts: 85   (View Stats)
mrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud of
Groaned at 4 Times in 1 Post
I've done my car my gf mini and my 4wheeler. Amazing stuff and addicting.
mrsmith is offline   Reply With Quote
The Following 3 Users Say Thank You to mrsmith For This Useful Post:
:: Gusto :: (07-20-2013), mike w (06-25-2013), rfinkle2 (06-25-2013)
 Old 06-25-2013, 07:14 AM   #9
looks good brotha, now i want to try some new colors out. I'm thinking Orange blaze..
Pd tuned.
09' true red GT
 Old 06-25-2013, 01:29 PM   #10
mrsmith's Avatar
Make sure you do gunmetal then white then blaze. Blaze colors are a little transparent and the white is thinner then reg plasti dip, so charcoal or gunmetal are used as primers.
The Following 2 Users Say Thank You to mrsmith For This Useful Post:
 Old 06-25-2013, 01:57 PM   #11
I'll just touch these up then..thanks for the tip.
Pd tuned.
09' true red GT
 Old 06-25-2013, 02:00 PM   #12
I'm reading some of the blaze colors fade super quickly too. They are working on a fix but most of the guys with flourescent and success with custom colors are using pigments or powders.
 Old 06-23-2013, 08:55 PM   #13
VerseIX's Avatar
Posts: 7   (View Stats)
VerseIX has a spectacular aura aboutVerseIX has a spectacular aura about
Does anyone use the glossy dip over it?
VerseIX is offline   Reply With Quote
 Old 06-23-2013, 10:02 PM   #14
mrsmith's Avatar
I have on my 4 wheeler, you have to put on one thick coat but make sure it doesn't drip.
 Old 06-23-2013, 10:05 PM   #15
Kellerspeed3's Avatar
Posts: 2,518   (View Stats)
Kellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the world
Groans: 50
Groaned at 37 Times in 21 Posts
This is the gold metalizer.
2010 Velocity Red w/tech package: Cobb AP, Cobb DP, Tr8L FMIC, Auto Tech internals, BNR S-4 turbo, JBR 3.5 aluminum intake, CPE stage 2 rmm, JBR 80 duro TMM, JBR 70 PMM, JBR SSP and bushings, JBR 5mm spacers, JBR RSB, JBR By Pass Tube, Magna-flow CBE with the "fix", NGK 6510's, JBR EBCS, SSP OCC(now Kozmic), JBR EGR delete, EGR deleted, JBR IM TIG, JBR TB TIG-coolant by-pass, Turbo smart BPV, built block with CP pistons, eagle rods, ported head, pinned cams, shimmed valve springs, Spec clutch stage 3, FordMoCo full syth transmission fluid, Eibach pro kit, ported IM with VCTS delete, ported exhaust mani, Werksracing strut tower brace, TB Performance front traction bar and mid-chassis brace, Corksport adjustable struts and shocks, slotted/drilled rotors, SS brake lines, and lots of TLC. FreekTuned Kotzur built 93/E-85 Prius killa.
Kellerspeed3 is offline   Reply With Quote
The Following User Says Thank You to Kellerspeed3 For This Useful Post:
Mast (06-29-2013)
 Old 06-25-2013, 02:01 PM   #16
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Groans: 70
How well does the plasti-dip hold up to a scrub brush for cleaning wheels and such?
Just curious, I'd really like to give this a shot to try and get a nice bronze...
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
 Old 06-25-2013, 02:08 PM   #17
I see a lot of guys waxing their plastidip with sprays like meguiars ultimate quik wax and most people are recommending using a no touch wheel cleaner.
I would think a soft bristle brush would work just fine too.
Plasti-dip seems pretty tough when you apply enough coats.
scubasteve711 (06-25-2013)
 Old 06-25-2013, 02:20 PM   #18
I used 5 cans. .5 coats total. Holds up great..even to a power washer.
Pd tuned.
09' true red GT
The Following User Says Thank You to volcomcinematic For This Useful Post:
 Old 06-25-2013, 02:22 PM   #19
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
I've never understood why people cover the tire up when spraying plastidip on the rims. Not like it doesn't come off. Lol.
Came out pretty good though.
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
 Old 06-25-2013, 02:27 PM   #20
It's ok. My sister is an elementary school teacher so I had abiut 5000 index cards laying around..
Pd tuned.
09' true red GT
 Old 06-25-2013, 02:48 PM   #21
Groans: 70
Awesome, thanks!
 Old 06-25-2013, 03:17 PM   #22
trixms3's Avatar
I've had blaze orange and blaze blue on mt genpu. Both times i use 1 can of white per 2 wheels. Just back and fort til the can was gone. Then i use 1 can of color per wheel til the cans were gone. Had the orange for 2 months never faded. Blue for about 2 months now not fading.
For cleaning. The DYC website has a product called BDP(brake dust pro) works good. I had it and was pleased. Bit pricey i think for a 32oz bottle. But its 100% touchless.
 Old 06-25-2013, 03:23 PM   #23
Groans: 70
I'm just wondering if it will survive going through the car wash I go to inbetween hand washes... Cleans the car up nice, and has brushes that clean the wheels pretty well.
 Old 06-28-2013, 10:06 AM   #24
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Just don't go where it's automatic and it moves u thru the car wash on its own cuz it will peel from the wheel slider thing. Had this happen then touched it up. It never really got back to like it was and both fronts peeled on a San Diego to Phoenix trip. I recommend index cards cuz the overspray does not come off easy like they say, there is always some left
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 06-25-2013, 03:59 PM   #25
theurgy's Avatar
scubasteve711 (06-26-2013)
 Old 06-25-2013, 04:30 PM   #26
trixms3's Avatar
It last lol. There's so many videos of it. Search man
 Old 06-28-2013, 08:57 AM   #27
I'm going to touch up the wheels soon, has anyone tried just spraying over the original stuff, without pealing and restarting? I wonder if it would stick just as good, after a good cleaning and pre dip spray? It sticks well to itself, and it should make pealing the next time even easier with how thick it would be..thoughts?
Pd tuned.
09' true red GT
 Old 06-28-2013, 01:44 PM   #28
Check this video out and there are a few others. Although I'm sure that DYC's proprietary
solvent is excellent, I've seen people do similar repairs with Xylene, which is available @ any
Home Depot.
breakfstincluded (06-28-2013)
 Old 06-28-2013, 01:36 PM   #29
theurgy's Avatar
I would NEVER use any of those car washes that use a tire rail.. those things are evil.
 Old 06-29-2013, 05:26 AM   #30
Groans: 70
That's what this one is, unfortunately it does a fantastic job cleaning up the car. Are you refering to the slider that the tire/wheel may bump into to keep the tire in the track? The tires I have, have the rim protectors and are a little wider than stock on the stock wheels, so the rim is a not really flush with the tires.
Either way, thanks for the feedback!
PlastiDip your whole Car goob_os101 MazdaSpeed 3/6 - Appearance 72 09-09-2013 02:35 PM
Yet another plastidip valence thread (with LED reflectors?) DownSideFX Exterior 20 06-11-2013 06:36 PM
Another PlastiDip Gen 2 NavySVO Exterior 17 08-30-2012 04:08 PM
Red Plastidip msalva2 Appearance - RED 7 08-20-2012 09:28 AM
Page generated in 0.51811 seconds with 31 queries
