 Old 04-21-2014, 03:13 PM   #1
wdautrem's Avatar
Posts: 159   (View Stats)
wdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the worldwdautrem is the leader of the world
Default Hood blisters
I'm getting rust blisters along the front edge of my hood, right along one of the bends. I tried to grind one out, rust treat it, fill it and repaint the area. It looked pretty good for about a week then started rusting right back through the damned patch. Has anyone had any luck fixing these blisters, short of buying a whole new hood?
wdautrem is offline   Reply With Quote
 Old 04-21-2014, 03:33 PM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
grinding it isn't going to fix rust. you gotta sand it out until ALL the rust is gone, then you fill it, prime it, and repaint it. if you don't get all the rust, that will happen again within a week or so.
07 MS3
The original Genpoo Hater
 Old 04-22-2014, 08:57 PM   #3
wdautrem's Avatar
Yeah, which is exactly what happened to me. I think the rust is coming through from the inside of hood somewhere. I'm just trying to figure out if it's possible to do anything about it that would be any cheaper than just buying a new hood.
 Old 04-23-2014, 07:46 PM   #4
jm211's Avatar
Posts: 943   (View Stats)
I have these too. I also think water/moisture gets behind and under the bend on edge of hood.
Raise Your Hood Easily with the CorkSport Hood Strut Lift Kit CorkSport CorkSport 285 12-10-2014 11:10 AM
Hood Pins for Firberglass Hood airhunt2 Mazdaspeed3/6 General Discussion 8 04-23-2014 10:39 AM
Official: Limited Edition Range Rover Evoque blisters eyeballs Haltech Automotive News 0 01-11-2013 09:50 AM
Hood Bra Rom_Chek MazdaSpeed 3/6 - Appearance 7 05-24-2012 10:20 PM
Page generated in 0.25788 seconds with 22 queries
